  • 324 Answers
My suggestion is for you to contact the Radio Shack store that you got this from, explain your problem and see what they offer as a solution. Maybe not what you were hoping for, but seems the most reasonable way to go.
Posted on Dec 10, 2008
Magicjack doesn't always work right sometimes the phone works , sometimes I get an error 3002 message when I try to call out.
Actiontech what, they many vast models, and routers, and mix.
what are you exact connections here>
NO PC stated, HP model number, this is HP forum. so.....what?
no OS stated, opr. system , windows WHAT?
No modem models stated.
No ISP service stated,
what ISP, what service,? DSL> must I GUESS that?
My guess is not DSL no land line but it is possible to buy DSL
with Landline, disabled, I did for years.
or cable modem, ? uses COAX ! not 2wire twisted like DSL.
or are you doing the MAGIC jack , with NO COMPUTER owned
The magic jack does not plugin to any modem ethernet port
ever. its usb.
Broadband, high-speed internet, cable internet, DSL - WiFi, Fios fiber. and more , dial up? nah you dont have LAND LINE./
error codes,. the first page in the manual states !
Contact your Internet service provider to verify your modem allows more than one device to access the Internet if you receive error 3002 when trying to use MagicJack Plus. Some modems and modem/routers-in-one may not be compatible for use with MagicJack Plus if multiple devices are connected to your network.
We dont know what ISP you have nor the connection type
cable tv modem, DSL, FIOS what?
nor the modem you have , you never said,
this is far more complex
its not magic at all,
fire walls set wrong
ISP blocks you, at your mixed, router and modem
using the routers, USB port is a FAIL.
if you want great help answer what you have and what is connected
in details.
the MAGIC jack as 3 ways to connect,
USB or ethernet.?
Jun 11, 2017 | HP Computers & Internet
Cannot connect to my Internet. On my 2Wire modem at home, The Power LED light is solid green, the Ethernet LED light is green, the DSL LED light is continually flashing, and there is NO Internet LED...
With the DSL light always flashing, it means that either the ADSL signal (synchronization) does not reach your modem, or your modem cannot 'read' the signal.
You need to determine if the problem is from one of the following places :
  • outside of your house (your land line or ISP equipment) or from the modem;
  • your telephone-cable inside your house or
  • one of your equipment;
Try the following manipulations to determine from where the default comes :
  1. Determine if the problem is in your house or on the land line
    • Unplug each and every equipment which is connected to your telephonic installation (Fax, phones, answering machines etc);
    • Using the shortest telephone cable (RJ11) you possess, plug only your modem to the main telephone jack of your house.
    • If the DSL LED still flashes continuously, the problem is somewhere between your ISP's equipment and your house. You should call them and expose the situation. At this stage, you can't do much else.
  2. Determine if the problem is in your house installation
    If the DSL LED lights up when it is plugged to the main telephone jack, then it is either one of your equipment which is at fault, or the house installation. To pinpoint the problem, do the following :
    • With all the other equipment still unplugged, try the modem on all the other telephone jacks you have around the house.
    • If the DSL flashes continuously on one of the jacks, you will have found the source of your miseries. Depending on your ISP's terms and conditions, you will either have to call them of call for the services of a third-party technician to solve the problem.
    • If the DSL lights up correctly on all the telephone jacks, then your house telephone installation is good. Proceed to the next series of tests.
  3. Determine which equipment is at fault
    • Plus your modem to one telephone jack and wait for the DSL line to light solid.
    • Use a splitter (ADSL filter) to plug the equipments you possess (telephone, fax etc) one by one. Verify each time if the DSL LED is still lit or flashes continuously.
    • If one of the equipment causes the DSL LED to flash, it is that equipment which causes your problem.
    • If every equipment causes the DSL LED to flash, the it is the splitter (ADSL filter) which is causing the problem. You can confirm this hypothesis by testing each and every ADSL filter you have in your possession.
    • Replace any faulty equipment and you should have eliminated the problem.
If nothing of this solves your problem, you won't have any choice but call you ISP. Don't hesitate to tell them all tests you will have done.
May I also make some recommendations :
  1. Use a power surge protector (not a UPS though) to plug your modem to the electric outlet BUT plug it directly to the telephone jack;
  2. Make sure your modem is plugged in as far as possible from UPS, television, etc.;
  3. If possible, don't plug the modem in the same electric outlet as other equipments;
  4. Don't use any telephone extension cable to plug your modem to the telephone jack.
Hope this helps you. Let me know what happens next.
May 11, 2011 | 2wire (1000-000057-000) Modem
Trying to access DSL with HP modem
If you mean you're trying to use DSL service with the modem that came built into an HP computer, you can't. That modem is for dial-up Internet service only, or if you want to use your computer as a fax machine along with a scanner or all-in-one printer.
To connect to DSL, you'll need a DSL modem. If you're just getting service, your service provider should have supplied one. (Actually, I think you have the option now of ordering DSL service and not getting a modem if you already have one. Maybe you did this.) The DSL modem has a telephone-type jack to connect to the phone line (same as on the HP modem), but the connection to your computer is through a different, larger, jack usually labeled "Ethernet" or "Computer". If you don't have a modem, you can easily find them for sale. You can buy new ones at retailers who sell computers, and many used ones are available on eBay or on your local Craig's list.
Another possibility is that you already have a DSL modem and are asking how to connect an addtional computer. If this is so, you don't connect the new computer to the DSL phone line. Instead, you need to share the network connection coming from the modem. This is done using a router, which allows several computers to use the same connection either through a cable or wirelessly. The DSL modems typically supplied now have the router built in, with 4 connections for wired computers and wireless capability as well. If your modem is an older one intended for a single connection only, it will have just one network connection. If this is the case for you, you'll need to supply your own router.
Apr 26, 2011 | Computers & Internet
When I use my telephone there is a sound as if I using dial up.
You used to have dial-up, so I guess you've switched to something better. DSL, perhaps? If that's the case, you need to have DSL filters on all phone jacks except the one your DSL modem plugs into. If you use a phone on an unfiltered jack, you'll hear a rushing noise in the background, and it will almost always severely degrade or cut off your DSL connection as well.
If this isn't what you're hearing, please post a follow-up with some more information about what noises you hear and problems you have, and I'll try to help further.
Mar 31, 2010 | 2wire 2700HG-B Router (2700HGB)
The dsl light on my modem isn't lighting up?
The dsl light is physical connection to the internet. If your dsl is a line share with dial tone and it sounds clear with no humm or static, your lines are most likely in good working order. So you may start with the telco tech support or better yet borrow a friends working modem and see if you get dsl at your place. This will tell if a dsl signal is making it to your jack. If it is then your modem is toast. If no dsl with a known good modem the issue is with you isp/telco. Most telcos charge a $60.00 isolation fee if the dsl signal is good to your home/business. So a little work on your part can save some cash.
Mar 20, 2010 | Arris High Speed DSL Modem
I have a hard wired wall mounted telephone (not modular). I need to insert a DSL modular filter into the circuit. What do I need to do convert the hard line to a modular line so I can insert the DSL...
Here's a thought. The DSL filter doesn't have to go on every phone, just the phone line that FEEDS the phone. In old residential, the phone line is looped to each location. If you open up another jack and break the loop, you could possibly find out where the first jack is in your house, put a duplex jack there, feed the DSL modem, and filter all the rest of the lines in the house at that location. Or, go outside, bring the dial tone in on the black/yellow or orange pair, install your DSL modem on that pair, and filter the dial tone back into the green/red pair for the rest of the house.
You can also buy a wall plate with DSL filter in it. Screw your chair closer to the floor before you go here :-)
Nov 13, 2009 | Bell Lands Phones
I am trying to use the fax facility on my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
I lost my manual and would like help in connecting to phone jack
Each phone or dial-up modem or fax machine needs a DSL filter attached to the phone line/socket then each phone or dial-up or fax machine is then plugged into this filter.
The DSL modem does not require a filter.
If your fax is part of the computer's modem then a filter is also required on the line-in on the modem.
The instructions for sending & receiving depends upon your system/dial-up modem (the make & model, is it stand alone or a modem adapter on the expansion slot or built-in on the motherboard) and the software you are using. Cannot help you without these details.
Apr 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
No Dial Tone on phones or modem
if you have a dial tone when your computer is not plugged in, then the problem ls with your computer[ a possible short in the computer] the phone cord to the jack, or anything in between such as a dsl modem.if you have dsl, be sure your ethernet cord [ that's the wider plug cord] is in the wider jack in back of the computer. it wont fit in the regular phone jack.if you have dial up, be sure the phone cord is in the regular jack not the ethernet port.[if you have one]
good luck
Jan 30, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Speedstresm 5100 modem
check for physical setup between your modem and the wall jack
if u don know how exactly the physical setup is pls contact your isp for help for u to run through the steps
Jan 29, 2008 | Efficient Networks SpeedStream 5100 Modem
Computers & Internet Logo
David Payne
David Payne
