Question about Dual Bravo HRC-0703 DVD Package Mobile Video System - 7" Headrest LCD Monitors ¿ In-Dash DVD / MP3 P... Car Video Player
Blue screen will not go away
I have a Dual in dash dvd player that I brought from walmart. I'm trying to install it in a 2001 chevy tahoe but the blue screen will not go away even with the parking brake wire grounded. If I separate the parking brake wire from the ground wire a few times and hook them back to gether the screen will play but as soon as I turn the ignition off or restart the vehicle the blue screen comes back up. So everytime I want to watch dvd I have to take the dash out and unhook the wires and rehook them. I don't understand what the problem is.. please help!
  • 1 more comment
  • Anonymous Nov 04, 2007
    i have a dual screen mobile dvd system, and one screen works but the other screen is just blue,it has sound but no pitchure. i dont understand why? please help!
  • Anonymous Mar 23, 2014
    How do I get my graphics back All I get is a blue screen can hear static on the radio but on cd/DVD in it tells me no video signal Got the pink wire grounded an no remote can I get this thing back or not?
  • Tasha Wilkins Mar 02, 2018
    What did you do to fix it
When I installed it the thing does nothing then when I turn my lights on the screen comes on but it's blue and does nothing else
Posted on Mar 02, 2018
This REALLY works i was about to give up and I tried the code now im able to watch whenever I want thanks!
Posted on Feb 14, 2008
Thanks for the Help that worked like a charm!!! That code did the job!!
Posted on Dec 15, 2007
These methods have worked on a variety of Dual DVD systems (mainly XDVD8181, also XDVD710), unsuprisingly, since Dual stated to me that most installations have the same codes. WARNING! It is usually ILLEGAL and most of all UNSAFE to drive while watching video. I only watch video while parked, and I suggest you do the same. This is for demonstration purposes only, if you use these codes, you do so at your own risk. STEP ONE. Ground the E-Brake wire. No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground). 1. FACTORY RESET METHOD (Temporary) (This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.) ** Go to the Menu ** Get to the Settings Menu ** Select to Reset to Factory Settings. Credit: DKA Have recently heard complaints of this method not being permanent, as this is needed everytime they want to watch a DVD. Also, radio and screen angle presets are lost. ---------------- 2. AUDIO CD METHOD (Permanent) ** Insert Audio CD ** Press PLAY ** Press STOP twice on remote ** Enter 26604 on remote ** Press ENTER ** Take out Audio CD and Insert a DVD Credit: Myself via a DUAL Tech ---------------- 3. DVD METHOD (Permanent) ** Insert a DVD ** Let it play until you hear sound ** Press STOP twice on remote ** Enter 26604 ** Press ENTER Credit: Adam P. The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
Posted on Oct 01, 2007
You need the by pass code type it in and watch it for ever with no problem
Posted on Aug 11, 2007
  • 156 Answers
The problem is that you're trying to bypass a safety feature. Newer video head units are smart enough to know when you've just grounded the brake switch wire so you can watch it while you're driving. Try hooking it up to your parking brake wire.
Posted on Mar 07, 2007
I get no image or sound on the screen even though the dvd seems to be playing
Sounds like you changed the input. Were you using the tv remote or the actual blue ray remote? make sure your tv is on the proper channel, that you have the correct input selected. i.e. HDMI-1 for example.
Oct 12, 2014 | Televison & Video
Where can i buy a wire harness that will fit a 95 tahoe?
Wire harness can be purchased at many locations. I would start out at Bestbuy, CarToys, Walmart, or even auto parts stores. Cheapest place to start might be ebay.
Dec 12, 2010 | Power Acoustik PTID8400 Car DVD Player
Audiovox PVS69701 Dual Screen DVD player monitor has blue screen
I had the same problem, and it seems to be a short in the video cable between the two monitors. I can bend my cable until i see the second screen and then tuck it under the headrest. I am currently looking for a replacement cable. I see it at 1800customersupport.com, but will also check the local radioshack since I need it quickly.
Jul 30, 2010 | Audiovox PVS72901 Portable DVD Player
No dash lights in 2001 chevy tahoe. i replaced the light switch. still no dash lights
check and see if you have power to your switch, it might just be a fuse. worse case is you'll have to change the actual lights. was it starting to get dimer and dimmer?
Jun 04, 2010 | 2001 Chevrolet Tahoe
One screen is blue but the DVD will play you can hear the movie but no picture on the screen
open the cover the dvd player,try to check connector from mother board thru lcd,if loosed connctor.
Mar 11, 2010 | Power Voice System Venturer 7" Portable...
I have a 2005 chevy tahoe it was broke into and the theives stole my indash dvd player now my tahoe wont start. it appears to have an electrical issue ....HELP
hello ther have you chekt the fuses if the have just puld the dvd player out a broken cabel can have toucht the body and chort surcet somthing
Jun 08, 2009 | 1991 Honda Accord
Dualav bypass e-brake
you have to toggle swicth the ground, make it think the brake is on
Jun 25, 2008 | Dual XDVD8181 Car Video Player
Smoking DVD player
Throw it away an buy a new one. WalMart's dvd's and all their electronics stuff are produced in china without any quality control and from the cheapest components. They aren't even worth repair.
Buy a branded DVD (SAMSUNG, Sony) to avoid future problems.
May 05, 2008 | Durabrand DVD-1002 DVD Player
Dual-in-dash dvd player/ receiver with
The revised cord is simply a ground wire just splice it to you ground wire and you can have the video playing while you are driving try not to watch it while your driving though
it is a yellow and blue cord i have this Sterio and soled the problem the same way i discribed if you want to be able to turn the screen off for any reason you can hook up a switch in the yellow and blue wire then run it to the ground wire
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Car Audio & Video Logo
1,571 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
