Question about Logitech Harmony 880 LCD Remote Control
Logitech Harmony 880 LCD / TV screen ''check signal cable''
When we press TV, the TV screen displays ''check signal cable''.
No CBL SAT station appears automatically on the screen.
We have to use the source button on the TV remote.
How can we fix this problem? Thanks in advance.
    Novelist:
  • 76 Answers
This is a configuration problem. My guess is that when you set up the "Watch TV" Activity, the input source was not properly selected. Remember, you should almost never need to control devices separately,(as you would with a typical remote). In fact, the only time you need to specifically control a device would be a situation where you need to access a little-used function that was not programmed as part of an 'activity'. Sometimes, you may need to control a device to tweak an activity that did not start correctly, but apart from these situations, you will almost always be concerned with starting "Activities". This is very different from your typical universal remote! Instead of operating 'devices' like your TV, cable box or DVD, you configure and select "Activities" that automatically control the devices that are used during that activity. So, go back into the Logitech software and make sure that your Watch TV activity is selecting the appropriate input. If everything is setup correctly, and you still are unable to go to the correct input, you may need to adjust some of your delay settings, especially the Power-on Delay. Power on delay is the amount of time it takes for the device to turn on and start accepting IR commands. On most electronics when you first turn them on if you hit other buttons too quickly the device will not respond to them. This delay helps to keep that from happening. Hope this helps!
Posted on Mar 10, 2010
Logitech Harmony 880 Screen
well..that's an issue..most of these small device folks have no strategy for this sort of thing..only suggestion is find one that's been blown internally, disassemble it, and swap the screens. welcome to the new disposable electronic strategy
Apr 25, 2008 | Logitech Harmony 880 LCD Remote Control
Tip
Harmony 880 Manual Download
Download Logitech Harmony 880 Remote Control Manual
Have you misplaced your Logitech Harmony 880 Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 880 Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
on Apr 30, 2010 | Logitech Harmony 880 LCD Remote Control
Trying to sync my dish remote to a Harmony remote but it doesn't sync. Have a Dishdvr 522
Hi. For most Dish Network devices, you will have to ensure that the remote address is set on 1 in order for it to be controlled by the Harmony remote.
To reset your Dish Network device to remote address 1, you can do the following:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
That should get the device working with your Harmony 700!
Hope it helps :)
Mar 10, 2010 | Logitech Harmony 700 LCD Remote Control
Harmony 880 display is backlit but menu won't display. It seems to still work (pressing the button I know to be "Watch TV" turns everything on ok). Is the LCD broken?
Sometimes the LCD screen fails on the 880/890 series. But, there are a few tricks you can try that have brought the LCD back to life.
Some LCD problems have been solved by updating the remote's firmware while the remote has been placed in 'safe mode'. To do this, launch the Logitech Remote software on your computer and click on "Downloads" (on the top menu bar). Then, take the battery out of your remote and at the same time you connect the USB cable to your remote (it should be already connected on the computer end) press and hold down the Off button at the top of the remote. This will put the remote in "safe mode". Continue to hold down the Off button until you see the message "safe mode requested" on the remote's screen and the screen starts blinking. Now, since your screen is not behaving properly, you may or may not see this message, but after about 5 seconds you can release the Off button. Now, go back to your computer and click on "Firmware". If the software is able to communicate with the remote, an update to the remote's firmware should be executed. This has solved many a 'blue screen of death' problem. Good luck!
Feb 27, 2010 | Logitech Harmony 880 LCD Remote Control
Safe mode came up and I took the battery out and
connect to a computer but first you'l need the harmony software from logitech then it should come back
Jul 06, 2009 | Logitech Harmony 880 LCD Remote Control
Where can I get a replacement USb cable for a Harmony 880 remote in Sydney Australia?
Try this support number: 1800 726 063 (Toll free)
Monday to Friday 11am - 11pm AEST Saturday & Sunday 11am - 8pm AEST
Hope that helps!
IrishDruid
Jun 20, 2009 | Logitech Harmony 880 LCD Remote Control
I cannot set the time, my 880 remote want allow me to set the time!
I saw these posts recently and decided I would try and figure out the time on my Harmony 880.
First, using your Logitech Harmony remote software, version 7.5.0, log on using your login ID and password.
Next, select the remote settings tab, and go to display settings. Select time/display format and check the 24 hour format. (Note: the assumption is that you have already set the 12 hour time before hand, even though is says A.M.) I made this change to my own remote when it was actually was 7:30 P.M.
My remote actually reported 7:30 A.M. at this point. Save your changes online and plug in your remote to your USB port and let the Harmony update your change. Now your remote should be in 24 hour format.
Finally, log back on using the same procedure above only this time, click the check box for 12 hour format, save your changes and update your Harmony 880 one last time. Your finished, your remote should now be displaying the correct time in 12 hour format.
Oct 14, 2008 | Logitech Harmony 880 LCD Remote Control
Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
May 11, 2008 | Logitech Harmony 880 LCD Remote Control
Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Mar 03, 2008 | Logitech Harmony 880 LCD Remote Control
Logitech Harmony 880 LCD Remote Control Logo
500 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
