Question about AOC LM729 17" LCD Monitor
AOC LM729 LCD - Go to; bright white lines, blank, computer view and lines, blank. Yeah, please help!
I own an AOC LM729 17'' LCD monitor, worked great, but for some reason, it just stopped working! When it is turned on, it desplays bright white lines for about 1 seconds, it then turns black, and back to the white lines, but in the background there is the computer display, it then goes black. I have shinned a light up to it to see if it is something wrong with the brightness of the lights, but I could not see anything. I would take it apart and check all connections, but I do not know how! There are no screws, no clips, just a little space with a lock on it. So, if you have any idea on how to fix/take apart this LCD, please answer. Thank you, Cody Tousignant PaiinKiilla@aol.com
  • Cody Tousignant Jan 02, 2008
    Well, sorry, but that is not the problem, thank you for helping. . . I was able to get it open and after some more research and some other help I have deemed that it is not a dry solder point anywhere; if that comes up at all. The main problem now is the white lines, going horizontally. . .
    Thank you,
    Cody Tousignant
    PaiinKiilla@aol.com
  • pwnmarks May 13, 2009
    what is the appropriate way to go about opening the AOC LM729 LCD monitor? I have the capacitor issue that seems to plague these units. I want to replace the capacitors but I'm not sure of the safest way to open the unit. I dont want to damage the exterior. Thanks
    Problem Solver:
  • 4 Answers
This is an old post but maybe this will help someone else......
I have sold a lot of these LM729's a few years back and now, out of warranty, they are starting to show these same symptoms. I was stumped at first but finally did some real testing on them and found that in every case it it the 1000uF capacitors that are faulty. Look at the board and you will see 2 capicitors, the barrel shaped components, that have 1000uF printed down the sides of them. Both of these should be replaced even if only one is bad because chances are the other will go soon as well. You can usually pick these up for under 2 bucks each at your local Radio Shack. Get ones rated for 35 volts (35V), the ones on the board are 16vols but I usually try to go a bit more robust when I replace capacitors. The rating is just how high the voltage can go so it's okay. They are usually more durable since they are to handle higher voltages. Just take the LM729 apart, remove the power board, desolder the capacitors, clean up the holes, (Be gentle in desoldering them, you don''t want to pull the things, you will pull off and possibly tear the copper foil pad that you need to solder the new cap to) Install the new capicitors minding the polarity, as in there is a MINUS sign on the capicitor and this must go in the hold with the matching MINUS sign. Solder the leads, clip the excess off. Reassemble and you'll probably find that LM729 working just fine! These are very good monitors and very rugged. AOC isn;t at fault for this failure. The Chinese have been making scads of bad capicitors for a few years now. Anymore, if there is an electronic failure it can be traced back to bad capicitors.
Posted on May 02, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • AOC Master
  • 848 Answers
AOC LM729 LCD - Go to; bright white lines, blank, computer view and lines, blank. Yeah, please help? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
715L1103 AOC IDPC7425A3 Power Supply for TFT1780PSA LM729
Posted on Dec 23, 2014
  • 51 Answers
There should be an problem with your power card or please change your ram immedietely...
Posted on Jan 01, 2008
I have horizontal lines & bands scrolling from bottom to top
Hi
Try adjusting the contrast and brightness settings and see if that helps.
Jan 27, 2010 | AOC LM729 17" LCD Monitor
AOC 2036 LCD
You can get the drivers from www.driversguide.com
Dec 05, 2009 | AOC LM729 17" LCD Monitor
Aoc LCD monitor problem
If some of the pins inside the monitor cable are bent or broken you can losr primary colors and cause this. Check them. If they seem OK try reseating both ends of the cable. If no go, then try the monitor of a differnt computer to see wether its the videocard or the monitor thats defective.
Jan 06, 2009 | AOC LM729 17" LCD Monitor
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Jul 10, 2008 | AOC LM729 17" LCD Monitor
Inverter board
just change the 4 bloated caps on the board (2)100mfd 16v and (2) 470mfd 16v
Mar 19, 2008 | AOC LM729 17" LCD Monitor
the inverter needs to be replaced
not real hard, but must have some knowledge of the process
Feb 02, 2008 | AOC LM729 17" LCD Monitor
AOC LM729 17" LCD Monitor - Manuel
I assume you only found the 4 mount screws in the back... You also need to take off the front silver edging - it pops off with some negotiating, but if you find the right spots and don't pry hard it will come off clean without too much difficulty. Then take out the screws that hold the screen inside and it should drop out.
Jan 26, 2008 | AOC LM729 17" LCD Monitor
AOC LM729 17" LCD Monitor Logo
1,882 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
