Question about HP Computers & Internet
My internet card is not getting a valid ip address for my modem. verizon says my line is good. my computer is a HP Pavilion 6642f
  • 340 Answers
Hi and welcome to FixYa
You most likely have set some security, and forgot all about it.
Access your router and se if I´m right.
If you still have this problem, come back, I´m here to help.
/Teis
Posted on Dec 10, 2008
  • Teis Thomsen
    Teis Thomsen Dec 15, 2008
    Hi, back again,
    Wondering if you got your problem Fixed,
    - if not, let me know,
    - if it´s Fixed, then vote “FixYa” to close this case,
    Thank you
    /Teis
What is the default ip address for hp 2510-24 j9019B switch ?
Switches don't have an address, think of them more like a traffic intersection with 24 roads.
When you plug a device into the switch, that device gets assigned an ip address.
For example:
  1. Phone line comes in to your house and stops at your modem, your modem is plugged into the switch. The modem picks up the private network address 192.168.0.0
  2. Your computer is plugged into the switch. It picks up ip 192.168.0.1
  3. Your friends computer is plugged into the switch. It picks up ip 192.168.0.2
This carries on until you have filled all the sockets on the switch.
The ip's here are only on your personal network, to find what your external ip (your modem -> internet) is just type 'whats my ip' in the google search and it will show you your public ip address.
Nov 24, 2015 | HEWLETT-PACKARD Hewlett Packard HP...
I can't reset a 169 series IP address on my 4600C in order to direct connect to a cable modem (and internet).
Provided there is no hardware problems, this issue is fairly easy to resolve.
  1. Completely shutdown the system
  2. Unplug power to the cable modem.
  3. Wait 3 minutes (This allows the temp memory of the cable modem to scrub)
  4. power on the cable modem, let it reset (Takes about a minute)
  5. boot the system.
Normally this will force the cable modem to renew the MAC address of the device connected and give you a valid IP address.
If you still have an APIPA address, try right clicking the local area connection ICON and click REPAIR
If still no connection, reboot computer in safe mode w/networking and try again. If you get a connection then the issue is software (Firewall, Virus, Malware)
If you still are not getting a valid IP address, check your cabling and connection (Replace cable with a known good one if available) or try a different network card.
Jan 08, 2011 | Dell Dimension 4600 PC Desktop
Not providing valid IP addresses
make sure that your router is acting like a DHCP server.
also make sure that your pc's ip is set to "obtain automatically" under local area connection->properties->internet protocol->properties
Jan 25, 2010 | D-Link DSL-G624M (0790069285783) Wireless...
Lost connection
1. check ip address in command prompt
2. If unable to find valid ip address , reset ipaddress , in command prompt type ipconfig /release and then ipconfig /renew
3. Ping default gateway in command prompt
4. then ping www.google.com in command
5. If u can ping in command prompt issue with Internet explorer or with Operating system.
6.Try using different browser.
Aug 17, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
How do I get my HP Pavilion N5150 to recognize my modem for roadrunner internet.? I don't know what kind of external modem it is, DSL or cable, but from what I understand I should just be able to plug...
If the modem connect to a coaxial cable its cable, if connect to a RJ11 aka Telephone cable is DSL. Most of the modems connect the computers via RJ45 aka Cat5 or network cable. For this type of connection you do not need drivers.
If the computer not connect to internet, check for the NIC card driver in COntrol Panel. If the drivers are good, then open the command prompt (go to START | Run.. | Type cmd and press ENTER) and type ping 127.0.0.1, if you not have a success the network card is bad. If successfull...
Type ipconfig, if you have return IP of 169.254.x.x then your computer is not getting an IP. reset the router and check again.
When type ipconfig you have to display one of these IP address . 1) 192.168.x.x 2) 172.16.x.x 3)10.0.x.x. If you cant connect check for third party software installed.
Jul 08, 2009 | HP Pavilion N5150 Notebook
Change modem
First, I would try resetting the modem by unplugging for 10 seconds or so and then plugging it back in. To be on the safe side, I would also reboot computer. AFter that, I would try to see if it picks up valid ip address. If it doesn't, you may need to call your cable internet provider and perhaps get the mac address of your modem in their system (if it's not already)
Dman
Dec 29, 2008 | Computers & Internet
Cant get my internet to work
go to control panel and open network properties.
Go to the properties of your network card and then the properties on the TCP/IP settings.
It should be set to obtain IP address automatically
Post back if that doesn't work
Dec 10, 2008 | HP Computers & Internet
Verizon Westell 327w modem cannot connect to internet
hi. i work for verizon tv, internet and phone. and the tech was wrong. it is the unit it self how old is it?
Aug 07, 2008 | Westell Wirespeed VersaLink...
Ip address 169.254.113.88
hi
go to network properties see you your network setup properly.
then ip adderss 192.168.1.1 press tab ok.
go to internet wirzad setup internet properly.....
Feb 27, 2008 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Wireless internet connection
You haven't specified if the host computer is able to access the internet. Ip Address confict can be one of the reasons why the laptop isnt able to connect and we can have a series of reasons why we have this IP Address conflict - 1) There is no wireless encryption defined. So, we have neighbors connecting to the wireless network causing IP Address conflicts. 2) The laptop is not able to renew the IP Address after the lease expires. This can mostly be resolved by restarting the computer and in certain cases flusing the TCP/IP stack. 3) There is a static IP Address assigned to the laptop in the router's DHCP range which is conflicting with the host computer. I would suggest you may initiate a chat with me or anyone else who has expertise in routers to get this successfully resolved. That would definitely save your time. Good luck
Apr 22, 2007 | HP Pavilion dv8000z Notebook
Computers & Internet Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
