Question about Kenmore 24032\24036 Top Load Washer
Broken Belt--kenmore 70 series dryer
My dryer stopped tumbling. After research, I think it is the thermal fuse. I wanted to do more research so I pulled the front panel off the dryer. I found a belt that was loose. This belt was very skinny and was located at the front of the dryer. There is a thicker belt securely fastened located in the back of dryer. My question is are there two belts and how hard is it to replace this skinny belt? The belt has not torn apart?
  • 179 Answers
It is not that hard to replace the belt if you have the front panel off of the dryer. place the idler pulley in the holes located below the motor pulley put the belt around the drum pull the idler back and the belt loops around the idler and onto the motor pulley
Posted on Dec 20, 2008
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
Kenmore 70 series dryer. Heats up but quit tumbling.
belt is off or broken here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
routing of belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Good Luck Tim
May 11, 2011 | Dryers
I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Jan 24, 2010 | Kenmore 63942 Dryer
My kenmore 70 series dryer tumbles but doesn't dry because there's no heat. what should i do first?
get a meter and read out the thermal fuse located on the blower wheel housing,if filter is inside it's in the front,if filter is on top it's in the back,next time send model number.if the dryer hasn't had a clean out in a while it's probably the thermal fuse,you'll need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and make sure there isn't anything blocked inside the vent line,if it's a long run from the wall to the outside use a leaf blower to clean it out,if it is the fuse and you don't do this you'll pop the fuse again,if the fuse is good check the heating system with meter,good luck
Jan 20, 2010 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
probably a broken belt,,
Apr 11, 2008 | Dryers
Dryer stops tumbling
Thermal is opening for the motor or elements.. (May be 3-4 diff. snap-disks depending on model)..If the motor stops the heat will quit and Vise versa on most units..
Jan 18, 2008 | GE Profile Harmony DPGT750EC Electric...
Kenmore 24032\24036 Top Load Washer Logo
614 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
