Question about Grundig YB 300PE AM/FM/SW Radio
YB 300 PE
I have had good service from this radio until suddenly this week it would not turn on. Thinking it was batteries, I replaced them. However it appears to be the on button itself, as the light works. Can anyone shed some light? Dave
  • 2 more comments
  • Busk Dec 23, 2007
    I have the same problem and I still can't get it to work. I can't understand why the light would still work but not the radio. I'll probably never buy a piece of Grundig gear again.
  • Anonymous Jul 08, 2008
    I had this same problem. Tried the reset button suggestion and it worked!
    Before this I would just keep taking out the batteries and putting them in again and eventually it would work again.
  • Anonymous Oct 23, 2008
    It has a split second switch of the display like it wants to turn on, but it won't. Replacing batteries and resetting multiple times doesn't seem to help.
  • jbayless Nov 08, 2008
    On/Off button doesn't respond, despite pushing the reset button
    underneath the batteries and rearranging the batteries. Light
    works, and I am able to set the time just fine. But otherwise the
    radio is inert.
The reset button didn't work for me.
Posted on Oct 25, 2007
Thanks... the reset button worked for me!
Posted on Jan 26, 2012
I had the same problem. Changed batteries but no on/off response. Light worked fine. Finally read some solutions here and found the little red reset button under the batteries. Used a ball point pen to push it in, heard it click, replaced the batteries and all is good. Love this little radio.
Posted on Jul 12, 2009
The reset button worked fine for me, too,  BUT now the volume is too high to listen to.  The volume control knob makes the volume go from very high to very very very high.  there is no soft setting any more.  Any help PLEASE?
Posted on Aug 08, 2008
DOES ANYONE HVE THE MANUAL FOR THE YB 300PE?
THANKS
GOLDBERGJOE2004@YAHOO.COM
Posted on May 07, 2008
Same problem. Plugged in an external power supply and it worked. Reset button didn't help. So for now I have to use it with external power. It is odd that the batteries are OK and the light works from batteries, just not the power button.
Posted on Dec 25, 2007
There is a small reset button underneath the batteries on this radio.  You might try removing the batteries and press this button with the head of a ball point pen.  I have had to do this several times with mine.  Once I put the batteries back in, it seems to work properly.
Posted on Oct 20, 2007
Need manual for Grundig YB-400-pe radio
You can use this copy of the user manual for this unit from this link just click HERE.
May 16, 2011 | Audio Players & Recorders
Moving home resulted in our loosing the AC adapter for our Grundig YB 400 PE, any sugestions where we could aquire a replacement?
its a 9V power supply
you should try Radio shack take with you the the radio to make sure the power supply have the correct connector
Aug 23, 2010 | Grundig YB 400PE AM/FM/SW Radio
My 4 year old YB P 2000 suddenly quit broadcasting AM. I took the radio apart and cleaned everything. Now only some FM stations and no SW reception. Can you help?
Look at the front case and locate reset hole. Insert cocktale stick or similar and listen for slight click. Insert new batteries, ensuring correct polarity and that there has been no leakage from old batteries on terminals. If leakage ie green/ uneven appearance, try to scrape clean with suitable implement when disconnected from mains only.
Feb 10, 2010 | Grundig Yacht Boy P2000 AM/FM/SW Radio
My Grundig 300PE was a Christmas gift, 2009. One week later, it won't turn on. I've installed new batteries and it won't work on the external power source either. The "light" works, but nothing else will...
Lets find that receipt and get it fixed under warranty pronto. as it's a gift and you may not be able to get the receipt, go back to the place of purchase and plead plead plead!
Good Luck
Jan 14, 2010 | Grundig YB 300PE AM/FM/SW Radio
Grundig yacht boy 400 radio does not work with mains operations
I had the same problem. Examined the wire from the transformer,and found a break. Repair of the wire solved the problem. WLD
Mar 01, 2009 | Grundig YB 400PE AM/FM/SW Radio
YB 550 PE
When radio is first turned on, it goes into "sleep" mode that you can set between 1 min to 2 hrs. (You'll see the number on the screen). If you hold the "on" button longer, you'll see (yb-550) on the screen and the radio will remain on until you turn it off.
Jun 16, 2008 | Grundig YB-550PE AM/FM Radio
No am radio
You realize that the MW is the AM stations....I don't know
why they didn't just put AM on the band select...
Also I could not get MW (AM) on my set once and the
reason was that it was too close to my laptop...
It was interfering with the radio.....
May 07, 2008 | Grundig YB 300PE AM/FM/SW Radio
Buttons Don't Work
I would strongly lean towards factory service. Sounds like the circuit board has problems.
Good luck.
Oct 04, 2007 | Grundig YB 400PE AM/FM/SW Radio
Grundig YB 400PE operating instructions
http://support.radioshack.com/support_electronics/doc69/69536.pdf there ya go
Jun 27, 2007 | Grundig YB 400PE AM/FM/SW Radio
Grundig YB 300PE AM/FM/SW Radio Logo
1,351 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Jim Goldsmith
Jim Goldsmith
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
