Remote start will not work
The alarm is working just fine, but when I try to remote start the vehicle nothing happens. On the display it says inhibit but no doors or windows are open. If advise you have is appreciated.
  • 71 Answers
Hi is this a car remote if so what make and model regards kirk
Posted on Dec 10, 2008
I have the Audiovox CA425 remote start and keyless entry system and had service done on my vehicle. The door locks and auto start and alarm all worked perfectly. The auto shop disconnected the battery and...
Usually it`s happens with any alarm system when you disconnecting the battery, try to put key in the door and open manually while alarm on, check the fuses
Dec 17, 2013 | Audiovox Vehicle Parts & Accessories
I bought a used Ford Crown Victoria with an Avital system installed and the seller told me the way the system was setup was using the keyless entry to unlock the doors as the only way to start the car
The way the system was set up?! Here is what it sounds like. If you cannot start the car with the key but, you can start it with the remote starter means two things; the car has a starter inhibit installed and it's active or, the starter wire is cut and isolated from the ignition cylinder and the remote starter is connected to the starter side only of said cut wire.
About the keyless entry; Ford vehicle have a battery save mode that, after 10 minutes or so, the GEM module goes to sleep. The installation of a keyless entry system on these vehicles require connections at the unlock, driver's door ajar/latch wire and factory alarm disarm and programmed to double pulse. This will wake up the GEM and unlock the doors.
Nov 19, 2012 | Avital Vehicle Parts & Accessories
Loose green wier ?
Apparently, you do not have a starter inhibit relay installed. If the loose green wire is part of the alarm, it is for the door trigger.
Aug 28, 2012 | 750i5 Car keyless entry and security...
Have a prestige remote start that was installed and only worked for one week. now the remote beeps but doesn't start or lock/unlock any doors. remote says inhibited . all doors are closed as is hood and...
If this is the Prestige 997C, there is a remote starter disable feature that can be activated through the programming switch. When it is active it will display "inhibit' on the screen. To deactivate this feature, press and hold programming switch, turn key on, off, on, off, on then off. When the hood pin switch is not making contact with the hood when closed, the screen will display inhibit. When the brake shutdown wire is active the screen will display inhibit.
Feb 27, 2011 | Prestige Remote Start
My alarm light blinks twice stop then twice and stop its continuous and my alarm shows a picture of the hood and trunk door up. when I press the green button to remote start my vehicle my alarm sounds. I...
The LED blinking twice and, the trunk and hood being displayed on the remote indicates trunk/hood trigger. Now, when you attempt to remote start the vehicle and nothing happens, it's definitely the hood pin switch. By the way, the remote should be displaying "inhibit" as well at this point. Check for the hood pin switch under the hood; it's probably bent downward, not allowing the pin to make contact with the hood when it's closed. If it's a bracket, bend it upwards. If it's a pin, unscrew it upwards a couple of turns so it makes contact with the hood when it's closed.
Dec 12, 2010 | Prestige Remote Start
Hello, I have a Viper 5701 in Mazda 3 2006 several times my car car did not start when I crank it, absolutely nothing happens. The same thing happens if I open my car with factory remote and try to crack...
What type of transponder bypass was used? You will need to check with your installer. You will want to know if the data bypass module is coming ON upon remote starting. And NOT coming on during regular starting.
Aug 16, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper remote stopped working!
First things first. Check the fuse that powers your alarm system. If that seems to be ok then try the next simple option. Open the hood and disconnect the negative battery cable. Then turn the ignition to the start position for approximately three minutes. This will allow for any remaining energy to dissipate from your system. Now you can reconnect the negative cable. *** Before trying your alarm *** turn the ignition on and off 3 times quickly. Make sure you don't start the vehicle. Now you can exit the vehicle and try your alarm. FYI you can always stop at a nearby Best Buy store for additional assistance. They are usually very helpful. Good luck and best regards, Rico...
Sep 13, 2009 | Viper Security and Remote Start System...
42 people viewed this question
