Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
My refrigerator is sending a signal on the control panel that says pe0-000, any one knows what it means, the compresor is dead, and i am trying to know what that code means, thanx jorge
Dear jorge, I had the same problem when my refrigerator was broken. You need to re-program the control panel as follows: 1. First you need the Program Code for your fridge. It is on the plate on the inside of your fridge, on the same plate that has your Model # and Serial # on it. 2. Programming is done with the refrigerator doors open. 3. Press and hold the Door Alarm keypad on the control panel. 4. Then press and hold the Freezer Temperature Down keypad. 5. Then release the Door Alarm keypad and wait 3 seconds. 6. The control pad will then display PE to indicate it's in programming mode. 7. Entry is confirmed by pressing the Freezer Temperature down keypad once more. 8. The control panel will display the current program code. It should be the same one that I asked you to find in Step 1. 9. If the program code is the correct one, exit the programming mode by closing the refrigerator doors. 10. If the program code is not the correct one for your refrigerator, press the Refrigerator Temperature Up or Down to change the value with each keypress. 11. The decimal point indicates the selected digit. Press the Freezer Temperature Up or Down to select the next digit. 12. Once the desired program code is displayed, press and hold the Freezer Temperature down keypad until the program code begins flashing, indicating that it's been saved. 13. Again, when you're done, exiting the program mode is done by closing the refrigerator doors. Hope this helps alot of people out there. I'm not sure what the problem is at Maytag, but they're extremely slow in getting parts shipped for their units. The local Maytag repair people have indicated to me that they are seeing an overwhelming number of Maytag refrigerators needing repairs that are around the one year age range. They say the quality of the new units is terrible.
Posted on Jul 08, 2007
HOW DO I ACCESS THE CONTROL PANEL ON MY MF12568AES
You probably need a new control panel - need to call your home warranty (if you have one) or call Maytag. Can only get one thru them.
Jun 08, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
Thermostat location ed2fhgx
Your model does not have the old style thermostat. It uses a=> 12002355 Thermistor
and located inside the control panel and freezer compartment. The thermistors connect to the control board. Here is a parts list and the list shows the thermistors=> MFI2568AES.pdf I am here should you have questions, Sea Breeze
Nov 27, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag model MFI2568AES not making ice
8869f6a5-d8bf-4729-a06a-b1440ff441bc.jpgThe water dispenser control is only part of the dual water control valve. If water did not refill the empty ice maker tray after dropping ice into the ice bin the=> 67006322 Water Inlet Valve will need to be replaced. Let me know should you have questions, Thanks Sea Breeze
May 25, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag refrigerator stainless steel french door bottom freezer...lights flashing and ice maker opening and closing/making sound
Im thinking maybe a power surge was felt by the refrigerator.
Try unplugging from wall for a couple minutes and then plugging it in again.
Hope this resets it...
Jul 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
My Maytag MF12568AES Refrierator control panel flashes on and off and the door flapper to te ice maker opens and closes uncontrolably. Whats up?
this is a very common issue the control board on the back of the unit is bad, you will need to replace it to fix this issue, let me know if you need more help,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Control panel not lighting up
this maytag may have a main board failure this board is called the jazz board . replace it and i think it will correct problem. board comes with instructions . to complete job .. hope this helps mm
Oct 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
767 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
