Question about Electrolux Centralux Vacuum
Can't get the filter to stay up inside the cannister
I removed the filter from the CentraLux cannister on the wall, cleaned it and now can't get it to go back in and stay!
    Scholar:
  • 44 Answers
This may seem obvious, but do you still have the retainer for the filter? I'm not sure how old your unit is, but in the newer ones there should be a black piece (the retainer) that pushes in to the cylinder that the filter slips over. You should push this piece up until it stops, and then turn it so that it locks in place. I have had people throw this piece out by accident when they empty the container.
Posted on Dec 29, 2008
Centralux
Low suction is either a clogged pipeline (very rare), a broken or open inlet valve in the system, a clogged hose or wand system, a clogged washable filter, the small screen behind the filter when removed needs cleaned, or the motor itself. Would need more detailed info. to pinpoint but hope it helped!
May 31, 2014 | Electrolux Vacuums
Eureka lightforce 300 poor suction, power paw doesn't spin and self cleaning duster doesn't clean its self when the button is depressed.
When this happens to me I do two things. The first is to empty the cannister but when you do (with the vacuum unplugged) stick your hand up inside of where the cannister goes.Sometimes that is filled with debris. Pull as much as you can out. There is another part inside there that you can twist and pull out - this will help you pull out more of the trapped debris. Replace that part and the cannister - usually there's a blockage and just removing some of that debris will cause a bunch more to dump in to the cannister. You may have to repeat this process two or 3 times untill no more debris comes out when you turn the vacuum back on.
The second tip solution is to clean the filter which can be found on the front of the vacuum.There's a clear plastic cover, a black rectangular this that hold the filter sponge and inside of that, the filter sponge. I just rinse the little sponge inside and shake off the thing that holds the sponge (Sorry, don't know the technical terms). Put it back together and you should have suction - viola.
Hope this helps.
Oct 28, 2012 | Eureka 4718AVZ LightForce 300 Bagless...
Hoover powermax s3530 spitting out dust
recently had same issue with friends. remove the filter and see the other thin filter there that goes to your motor compartment.. remove that and clean it. also check inside your tubes make sure not partially clogged.
Apr 17, 2009 | Hoover Powermax S3530 Bagged Canister...
Getting a Eureka central vac cloth bag back in after cleaning
The easiest way is probably to take the unit off the wall turn it upside down. This will give you some leverage. I would not try to get the ring in all at once, but leave a little out and then that piece that is left out you might need to bend it a little to get it in. There really is no trick that is why I am not a big fan of filtered central vacs. I prefer true cyclonic.
Feb 21, 2009 | Vacuums
Suction
hi!!! clean motor blower blades ,they collect alot of duct and the air in chopped,Good luck.Clean blower fan blades..
Feb 04, 2009 | Electrolux Centralux Vacuum
I want to know how remove the filter to clean or replace on my fm744h fantom vacuum
The hepta filter has a place on each side to push in.The top
comes off and the filter is inside.The new one is about 24.00.
Remember to clean the dust filter .This is located in a chamber
below the cannister . Remove the cannister and there is a grey plastic tab,it will comes up and dust filter is right there-pinch
it and it will peal out.It can be hand washed and air dried.
Parts at TotalVac.com
Nov 28, 2008 | Fantom Vacums FM744H Vacuum
If the light came on when you plugged it in, then you have power to the unit. You can take a coin and short across the two pins where the small, low voltage wires connect to the unit. Just remove the two wires, they should just pull off, and touch the two pins together with the coin. The unit should come on. If it doesn't, and the light is on, you may have a bad motor or a bad relay on the board inside the unit. Another thing to check is the filter. It has to be installed properly or the unit will not run. The top of the filter depresses a switch so that the unit cannot be operated without a filter in place. Good Luck!
Jul 20, 2008 | Electrolux Centralux Vacuum
Hoover mach 3 cyclone vacuum shut off during useage. can't turn it on. cleaned it out and let it sit thinking overheated? this is 2 months old. help?
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Jul 12, 2008 | Vacuums
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113669&thid=657359
Posted by Brucebob on Jun 09, 2008
I have an Electrolux Centralux. When I plug the hose in at one of the wall outlets the motor will not start. If I go to the motor and slap the unit it will start.....then...it will not stop unless I unplug the power cord to the motor.
If I plug the power cord back in, the unit will not restart until I slap the motor unit again. The unit has only been used 20 - 30 times.
Any suggestions? Thanks, Bruce
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You may have a bad inlet or household outlet; try all the inlets in the house too. But it sounds to me that your carbon brushes are dirty and need cleaning or replacing would be my 1st suggestion. Take a good wire brushes or pipe cleaner to clean the inside of the carbon brushes if they stick then replace them. So if the unit has only been used 20 to 30 times I would suggest some one to come and look @ it who did the install because it is still under a factory warranty and if you start messing with things you will void the factory warranty on the motor. And then if it is the motor for some reason then the factory or vendor will eat the cost of the repair. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Electrolux Centralux Vacuum
Electrolux Centralux Vacuum Logo
98 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
