Question about Dishwashers
We recently bought a house with a Kenmore 363.16222100 (?) dishwasher. No manual. Monday night it didn't drain properly and leaked some water on the kitchen floor. The cycle had finished when we saw the water on the floor. We bailed out the excess water. I took off the drain cover and insert. I couldn't see an obvious clog problem, but cleaned it out. Then I tried a short cycle, interrupting it to shorten it. No problem. Water seemed to drain fine. I did find a part that looked like a straw and another part that looked like a sewing machine bobbin. From the dishwasher? Need to be replaced? Is it safe to try a full cycle now?
  • 750 Answers
Hello
Welcome to Fixya
My name is Huum,
You can find your model dishwashers manual here at this site. this site
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0801624.pdf
I feel you should not invest blindly in someone else s old dishwasher with no history.
Buy your self a new one
It will be much more energy efficient too!
Please remember to leave a rating before you leave
Posted on Dec 11, 2008
Bosch shu8805 (2002 model)
HI,
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Aug 18, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Leaks water from under dishwasher, some one suggested the fill valve assembly needs replacing???? kenmore
Hi
Thanks for using FixYa. If your dishwasher leaks, check these:
Main tub seal
Lower rack
Spray arm
Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher leaking water on the floor
Check the drain hose connection under the washer. make sure the hose hasn't separated form the drain housing. if the drain hose is not the leak spot, move on to the water valve assembly. check the connection there thoroughly. check the seals on the connection hose as well. if all checks out, this will most likely be a faulty water valve assembly.
Jun 19, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Does not fill or drain.
Test the timer control board and the impeller pump.
pump is tested by energizing. Board is tested using a multimeter.
Observe strictly safety rules.
May 21, 2009 | Kenmore Dishwashers
Dishwasher doesn't drain fully
Hello. Are you using liquid or powdered soap? In some models liquid soap will foam up and the drain motor can't pump out bubbles. Foaming can also happen if you pre-clean your dishes with liquid soap used for washing by hand. If it is foaming, you can poor non-dairy creamer or cooking oil into the bottom of the unit while it is in the wash cycle.
If foaming isn't a problem then the water level switch may be bad, the pump may be not pumping out as quickly as it should or you may need to take the hose off completely to make double sure that there isn't anything in it.
Did you check the air-gap next to your kitchen sink faucet. If you don't have an air-gap it may be hooked up to the garbage disposal and if you don't have a high loop in your drain hose the water can run back into the dishwasher especially if the disposal backs up.
Dec 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Won't drain water out?
Regardless of the brand, all dishwashers operate on the same principles.. in this case you said you checked for clogs and there are none..however.. have you checked the fileter screen for the drain, the hoses to the pump, the pump itself, the exit hose off the pump, the drain hose coming from the dishawasher to your house drain and is your house drain restricting water flow? Also.. is the pump actually operating at any time? These are the funadamental items to check..any one of them can cause your dishawasher to not drain properly. Hope this helps..
Sep 21, 2008 | Kenmore 24 in. 17594 Built-in Dishwasher
Dishwasher Leaking
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Aug 27, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Water seeping in dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Leaking water on floor in front of dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Dishwashers Logo
133 people viewed this question
Top Dishwashers Experts
