Question about Acer Aspire 5050-3242 Notebook
Acer eData Security Management
I have Acer TravelMate 5510. Every time I switch on , I am asked to reboot or download the above Software
F Sway
my machine is always asking me to reboot or install acer data security.
  • 61 Answers
Turn off the automatic shutdown option and turn off the automatic update befor that try to run msconfig from the run command and disable the start up items adn try it should work
Regards
Samson Ved
Posted on Dec 10, 2008
    Scholar:
  • 149 Answers
Acer edata security management software covers a whole range of security issues from webcams to intenet browsers....do you get message after windows loads ? what version of windows ?
    Sergeant:
  • 399 Answers
Its any of the viruses issues reformat the machine. --------------------------------or just off the machine and check out for any loose card or wires on the mother board of the machime/cpu
  • 6,487 Answers
There can be some missing file for your operating system that's why you're always having that problem, first thing that you can try here is to run a recovery CD for your computer so the missing operating systme component can be retrieve....
    Genius:
  • 1,142 Answers
Did you make any changes recently to the computer may be hardware or software ?
  • Maanita Chadha
    Maanita Chadha Dec 10, 2008
    You need to run a recovery for your system but that will erase all data and in case you dont have much data then run the recovery.
    Note: These steps will return the system to the
    original factory installation including all factory installed drivers
    and applications.
    Back up all data prior to using this procedure.
    1. Plug in the AC adapter and battery.
    2. Turn the system on
    3. Immediately, press ALT on the keyboard and start tapping F10.
      Continue holding ALT and tapping F10 as the unit boots up.
    4. A screen stating "Starting Acer Erecovery" should appear.
      (Release ALT and stop tapping F10 at this point)
    5. There will be 4 options:
      1. Restore system to factory default
      2. Restore system from user backup
      3. Restore system from cd/dvd
      4. Exit
    1. Enter the password created when eRecovery was first started.
    2. Read the on-screen warning and choose Yes.
    3. Click Next. The recovery process will start.
    When recovery is complete the system will re-start and will need to complete the setup of Windows.
    When setup is complete a process will clean up the recovery files.
    Please be patient as this process can take 5-10 minutes or longer.
  • Maanita Chadha
    1. If you have created a user backup, this option will be available.
    2. Select the backup file you wish to restore
    3. Follow the prompts
    1. If recovery cd/dvd's were created, they can be used to restore the system.
    2. Insert disc 1 and follow the prompts.
How to reinstall the acer edata security data management.
To reboot the system click on Start and then on the shutdown menu choose restart or shutdown.
If this error happens with a bluescreen and white writing then you will have to press the power button for about 5 seconds to force it to shutdown.
To reinstall the eData software use the Acer software CD that came with your computer to reinstall it or download it from Acer :
http://support.acer-euro.com/drivers/notebook/as_5520.html
Select it from the Empowering Technology and Utilities section.
Good Luck
Jun 16, 2009 | Acer Aspire 5520-5908 Notebook
delete/uninstall edata security completely.
Then download a more stable security like AVG, McAfee or Norton, check this site some are having the same problem and this seems to be the best solution.
Apr 09, 2009 | Acer Aspire 9300-5349 Notebook
Mein Problem besteht darin, dass neuerdings beim start die ansage kommt installieren sie acerdatasecurity management neu. wie kann das passieren und wo kann ich dies onlie runterladen ?
Mar 31, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Sounds like you have either a virus or spyware, you can boot into Safe Mode with networking and download Malwarebytes from Malwarebytes.org and run a scan to see if it finds any roue software. When in safe mode run MSCONFIG from Start, Run and uncheck enything that looks suspicious and then reboot.
Mar 01, 2009 | Acer Aspire 4315 Notebook
I have searched the Acer website and the user guide for your model and can find no reference to the edata software referenced. I think that a system restore is what you need. Per the manual press alt-f10 to enter the utilities and create a system restore cd and an application restore cd reboot with the system cd and restore the computer to a factory fresh condition. Remember that no user data will be saved so if you have documents or pictures etc. make a copy first. Good Luck
Dec 18, 2008 | Acer Aspire 5500 5570-2609 Laptop
try logging in safe mode and reboot the pc after loading safe mode I have had programs crash installing and I loaded safe mode and restarted pc and in safe mode it fix the problem.. so when I restarted pc it worked ok.. the program mighted of corrupted and you might have to uninstall it and reinstall it I dont remember if acer has a app disk like dell,emachines(new),gateway or ifs a full restore disk.. Im thinking that its a app disk.. you might also want to check for viruses. with a program like house call free scanner from trend.. and spyware scanner free adaware. both are good.
if you still cannot login to windows you can run msconfig in run box and disable it in startup but becareful with what you disable
Aug 05, 2008 | Acer Aspire 5100 Notebook
Well, reinstall eData Security Management.
Aug 04, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Malfunction warning - reboot Acer eData Security Management
Dear Team,
the warning is as follows: "this software is malfunctioning.please reboot the computer. and try again,if the problem persist, please close all running programs and reinstal Acer edata security management"
This warning is beeing shown several times a day.
Thanks for your help!
rgds
Aug 02, 2008 | Computers & Internet
Acer Aspire 5570Z
Ok that is just a program that comes with the Acer laptops, it really is Useless and I dont use it on my computer, its part of the acer e management , e recovery, and etc programs that acer made. To fix this you can uninstall it under the ADD/remove programs or if you want to keep it you can then goto the acer website and under support put your model number in and download that particular software again and it might fix itself if there where some type of missing files on that particular software. Secondly if this is a vista machine it could be the software is not compatible and it causes the OS to crash which then comes with that error to the user and never goes away . Hope my answer gets you closer to a solution.
Jul 30, 2008 | Acer Aspire 5500 5570-2609 Laptop
Everytime I open certain docs. I get told that "eDataSecurity was not properly installed! Please re-install the software" I then click Ok and the it says Windows explorer has stopped working.
It's becoming an anoyence considering I can't use my windows2007 anymore :(
Is there anything I can do to re-install eDataSecurity,so I can live out happy days with my computer and not decide to throw it out my window??
Jul 02, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5050-3242 Notebook Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
