Question about Motorola Mobility RAZR V3
Dropped in Water Razr V3r
Last night phone would not work at all. Today screen is on, network found, but keypad will not work at all. None of the buttons. Is it junk or is this something that can be fixed?
This happened to me the other day. And the advise I found here fixed the problem. The motorola manual found here http://www.lovehopefaith.com/V3.files/V3-repair.pdf Should help out a great deal. I had to open the back , take out the battery & SIM chip, take out the screws, pop the shell open disconnect the flex connector and leave it that way for a few hours. After I put it back together it took a couple of times turning it on and off before it worked like new. The manual for the razor is key. Good luck.
Posted on Mar 06, 2007
Ok take the circular malfuntioning pice from the key pad take out blow dry and then take out the nuclear rector funtioning log and do same with that
Posted on Mar 03, 2007
I have a Motorola Razr V3r mobile phone.The only key that works is the power up key & There is no display.Changed display,keypad & flexible keyboard connector.Still no joy .Any suggestions
Hi, No one will give you free unlock code for your motorola Razr v3r mobile phone unlock code
but you can get motorola Razr v3r mobile phone unlock code at cheapest rate from others or 100% money back guarantee from this third party Thanks http://motorola.imeiunlockcode.org
Hi, No one will give you free unlock code for your htc wildfire but you can get htc unlock code at cheapest rate from others or 100% money back guarantee from this third party Thanks http://htc.imeiunlockcode.org
Oct 14, 2011 | Motorola Mobility RAZR V3
Speaker (ringer) stopped working after phone was dropped at waist
firstly try the new speaker then if it not works chek for breakage of prints if prints r ok then change the patta beyond lcd.
Aug 07, 2009 | Motorola Mobility RAZR V3
Razr V3r; Any key pressed turns off phone
Try Replacing the keypad. It's tricky to do exspecially on a GSM phone if you need directions how do do it email me at hoferron@hotmail.com. I need to know if it's a GSM or a CDMA phone before giving you directions. You can get cheap keypads off from ebay
Sep 01, 2008 | Motorola Mobility RAZR V3
Razr v3r lcd
I would first try resetting the phone through the settings menu. Make sure you backup your data first, since the reset will wipe it clean.
If that doesn't work, you most likely have a loose cable inside of the phone. You can take it apart yourself and find the culprit, or take it to a shop for a cheap repair.
Dec 17, 2007 | Motorola Mobility RAZR V3
New razr v3
chane the flex cable or try and reflash the phone firmware.
Dec 06, 2007 | Motorola Mobility RAZR V3
Razr troubleshooting
none of the keys work and key pad is not locked. Recieved phone last night worked fine. Today I can only answer calls and only by flipping phone open.
Nov 22, 2007 | Motorola Mobility RAZR V3
Dropped in water
the water probably caused a short in the screen conector.
sorry but liquid and electronics just don't mix
Nov 07, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Phone shuts down when closed...
the phone's firmware needs to be reflash so take it to a mobile service center and have them fix it for you.
Sep 04, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
131 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
