Question about Radio Communications
Icom706mk2g turns off on transmitt
My icom 706mk2g turns on,receives and has all functions but when i key up the rig turns itself off .
help
  • alan Dec 11, 2008
    Thanks Rob. I bought a new meter today and it appears that the power supply is down on power. So iI baught a new Watson w-45m ps and a new power lead for the rig , hey presto problem solved.
    Once again thank you Rob. by the way the old meter is in the bin hi hi. 73`s
  • 55 Answers
I have a few ideas on this. I think when you key up something is shorting to ground or drawing down the power supply enough that the logic (ie the control circuts) shutdown. that being the case I suggest checking the mike for shorts then the the relay that toggles between transmit and receive and if thats not it. I suspect the power supply is failing. I wish there was a simple solution however as I see it your going to need a meter (DMM) and the schematic.
I found this link hope it helps you.
http://www.geocities.com/k3xf/ic706.html
good luck
Rob
Posted on Dec 11, 2008
  • Rob Duron
    Rob Duron Dec 11, 2008
    I'm glad that worked and thanks for the feed back
    Rob
How do you reprogram a new key for a 2000 Buick park avenue?
Transmitter Programming
Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter. Up to four transmitters may be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number on the transmitters are for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available. Use care to program the transmitters correctly.
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. Use the scan tool Remote Function Actuation Special Function: Program Key Fobs in order to place the remote control door lock receiver into Program Mode. The doors will lock and then unlock in order to confirm program mode.
  4. Important: The scan tool must stay connected until all of the transmitters are programmed.
  5. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 15 seconds, the doors will lock and unlock in order to confirm the programming of that transmitter.
  6. Repeat the previous step in order to program up to 4 transmitters.
  7. Remove the scan tool.
  8. Operate the transmitter functions in order to verify correct system operation.
Apr 12, 2016 | Buick Cars & Trucks
How can I program my remote?
Remote for ? door unlock / lock , remote start , garage door opener .
If the door lock / unlock , panic alarm ,remote start . You can't dealer only . Need a factory scan tool .
Important: Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
Invalidate All
This procedure will erase all keyless entry transmitters from memory.
Turn ON the ignition with the engine OFF.
With the scan tool, select Body.
Select Remote Control Door Lock Receiver (RCDLR).
Select Module Setup.
Select Program Key Fobs.
Select Invalidate All Fobs.
Follow the scan tool on screen instructions.
Transmitter Slot Programming
Transmitter slot programming allows a single transmitter to be programmed into a specific slot without affecting any of the other programmed transmitters. By using slot programming, the transmitter originally programmed to a specific slot is erased and the new transmitter learned in its placed.
Select the key fob desired to be programmed.
Exit the vehicle. Operate all functions on transmitters to verify correct system operation.
Jun 05, 2015 | 2007 Buick LaCrosse CXL Sedan
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Mar 11, 2015 | Radio Communications
How do I get an icom ic f21 radio that sends a signal to another one receive from another one?
Relays are complicated.. expecially in the same band... but if you have two transceivers which do not interfere with each other, then a relay unit can be made by building a 'carrier detect circuit and relay output' to control the TX/RX of each rig and correctly adjusting the audio levels fed to each.....
Sep 26, 2014 | Icom Two Way Radio Battery Ic-f3gt F4gt...
My icom 706 mk2g transmits on VHF uhf but not on HF whats the possible problem
My icom 706mk2g does no give me hf power on the hf bands but on uhf is working wel.
On the s meter the last blok is turn on.
Reseiver is working wel.
Wat can it be?? Transistor Finals broken???
The two srfj?
May 19, 2013 | Icom IC-706MKIIG
Radio not receiving on any channel
Hi Mike,
The manual for this radio (in Adobe .pdf format) is available for download directly from Icom America, free of charges.
Since the "AquaQuake" function works and you do hear static when the squelch is off, that is sufficient to let us know that the voice coil of the speaker is functional and should produce sounds with the right signal applied.
The first thing to determine is if you're close enough to another operating transmitter for the radio to receive a signal. One of the 10 weather channels the radio is capable of tuning should be close enough produce some intelligible audio from the speaker - assuming the squelch setting isn't set too high.
If a WX channel works, then you'll need to see if there's a VHF Marine band transmitter operating nearby. You might need to set another Marine band radio receiver up to verify that there is indeed a signal present on the particular Marine band channel that you're monitoring. A list of frequencies is published on pg 27 (of the manual linked above) in case you need to convert between channel and frequency to tune on a non-channelized radio.
Outside of that, there's little the end user can do without specialized test equipment, schematics and of course, training. Many shops will be happy to provide an estimate for repair when provided with a small bench diagnostic fee. This fee is usually applied towards an authorized repair by most reputable repair shops.
I hope this helps & good luck!
Nov 27, 2012 | Icom Ic-m34 Vhf Waterproof Marine Two-way...
Alreaddy did replace new batteries for key remote but the key remote is not working properly.. What cause is that?? do you know??
I know that this procedure work for Grand Prix and Monte Carlo, tesi it...
KEY FOB PROGRAMMING INSTRUCTIONS
No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver's seat. (actually it’s much ezr from the front pass seat)
Remove the ignition key from the ignition lock cylinder.
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat step 8 in order to program each additional transmitter.
Hope helps.
Jul 16, 2010 | 2001 Pontiac Grand Am SE
1999 Chrysler Town and Country
Have you you tried just re-programming all of your remotes? I just added a "new" (from Ebay) remote and when re-programming, had to do them all. Here's how... 1. Using a functional key fob transmitter, unlock the vehicle and disarm the Vehicle Theft Security System. 2. Insert ignition key into the ignition switch. 3. Turn the ignition switch to RUN position without starting engine. 4. Using a functional key fob transmitter, press and hold the UNLOCK button for a minimum four seconds (maximum ten seconds) 5. While holding UNLOCK button, and before ten seconds passes, press and release the PANIC button. A single chime will sound to verify that the RKE module is set to receive the new Vehicle Access Code(s) 6. Within 30 seconds of the chime, press and release the "LOCK" and "UNLOCK" buttons on the transmitter at the same time. Then press any one of the buttons. The BCM will sound an abbreviated chime to acknowledge that the programming of the transmitter has been completed and was successful. 7. Repeat step 6 for all transmitters that will be used with this vehicle (up to 4 total) 8. Programming mode will last for 30 seconds. To get out of programming mode sooner, turn the ignition OFF. A single chime will sound to verify that the RKE module will no longer accept additional Vehicle Access Code(s) 9. When Vehicle Access Code(s) programming is complete, turn the ignition switch to the OFF position and verify RKE system operation using each key fob
Aug 03, 2009 | 1999 Chrysler Town & Country
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
Jun 11, 2009 | 1998 Honda Accord
Radio Communications Logo
142 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
