Question about Kodak EasyShare One Digital Camera
Tells me to add paper to print picture, already has paper
Not pulling the paper through
    Genius:
  • 1,199 Answers
Try cleaning rubber rollers inside of unit
Posted on Dec 11, 2008
My hp 1200 printer tells me out of paper on windows 8
I think Paper try sensor not working properly. Check the sensor, is it on normal position?
Jul 30, 2014 | HP PSC 1210 All-In-One InkJet Printer
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    Media is not picked up from the media tray
    save the document to your desktop or copy and paste into word or notepad..
    tell ya printer settings to clean nozzles.
    remove paper.
    place paper into tray area but not a whole lot....15-20 sheets...
    now print...hows that..:-)
    Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    Add Paper / PC Print pending message on LED message
    it is problem your printer paper sensor it was broken lever or open
    Jul 23, 2009 | Samsung SCX 4200 All-In-One Laser Printer
    Phaser 8400 won't print.
    pull out the paper drawer and look on the ceiling of the compartment. you will see a little orange rubber roller that should be clicked inplace. it feeds the paper up into the roller. also, the drawer itself contains two sensors. if you go to the xerox page you can download the pdf that lists all the parts and the errors and how to disassemble the whole thing. i have the same printer and got a print head error and a paper jam that required complete disassembly. feel free to email me for additional help.
    katriscomputers@hotmail.com
    Jun 19, 2009 | Xerox Phaser 8400 Laser Printer
    Out of paper notification
    Where is the copier asking to add paper to? Is it looking for paper in the manual bypass tray. Try to add paper to that tray and let it make it's copy from that tray.Some body may have chosing that tray to print from. Also, check to see if may be some one was adding paper to the paper trays and changed the paper tray input size to another paper size. Lastly, I would pull out the paper trays and look to see it you may have some paper jamed behind the paper trays them self, just remove the jammed paper and that should do it. These are basic things to check. Good Luck
    Jan 14, 2009 | Office Equipment & Supplies
    Add paper message
    you will be glad to know, this is not your printer's fault. We went round and round with dell support when we first got 150 dell 1600n's. We sent in copies of documents that were causing the problem. Finally, they figured it out for us. Embedded in the document was junk that was telling the printer to pull from tray2. All you have to do to fix the problem, is take the word document, go into file, page setup. on paper tab, select default tray for first page, default tray for all other pages, and apply to whole document. to clear the message, you will have to delete the print job from the queue, and turn off the printer, then turn back on, and you should be set. The message add paper, is really what the printer should be telling you, except that it should add to tray2, so you know it is trying to pull paper from the manual sheetfeed port on the front.(you could add paper there, till the document finishes printing, but our docs are hundreds of pages, so that is not practical. Barry Smoke Network Administrator AR Division of Legislative Audit
    Feb 25, 2008 | Dell 1600n All-In-One Laser Printer
    Konica Bizhob c350
    you have to in printer, in witch tray what size and kind on paper is and when printing you have to choose the same settings. in user manual there are description how to print different media.
    Nov 29, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
    Kodak EasyShare One Digital Camera Logo
    22 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Jerry Greenberg
    Jerry Greenberg
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
