Question about Sony Handycam CCD-TR517 Camcorder
Partial static in playback and record even after head cleaning
My Sony TR517 showed signs of dirty heads, so I ran a cleaning cassette several times and even meticulously checked and cleaned the drum but it still shows partial static in both record and playback (sort of like a VCR with the tracking not adjusted). Once in a while, in the record mode, it gives an error message of C--.-- I forget which numbers, and with the transport still moving, shows a message in the viewfinder of "cleaning cassette." This message stops if I press the pause button, and resumes normal operation again, still with the "tracking" looking static. Any suggestions?
    Sergeant:
    Champion:
  • 326 Answers
Replacing the cylinder with video heads part number A7048897A will cure the problem. If you need more help please advice. Arpi
Posted on Mar 17, 2007
Sony handycam ccd-tr9 video playback is distorted
sir,
the video head problem, try to clean it with head cleaner cassette. play the cleaner cassette several times, test, if still problem must change the video head.
Jan 20, 2016 | Sony Video Cameras
How do I eliminate droput of audio/video upon playback?
If it is an old tape which has been used before, there may be creases caused where the pinch wheel pressed against the roller. Try again with a brand new tape. If this is not the issue, he a service is called for.
Jun 17, 2017 | Sony Handycam DCR-TRV310 Digital Camcorder
Won't playback. acts like it's locked up.
This may be corrected by fast-forwarding the tape for a few seconds and then rewinding it back to the point where the issue first started. However, if the issue continues, this could be a sign that the video heads are dirty and need to be cleaned. Use a Sony MiniDV head-cleaning cassette (DVM-12CLD) to clean the video heads.
If the movie continues to stop at the same point even after cleaning the video heads, this could be an indication that there is a problem with the recording on the cassette tape. If this is the case, the data on that portion of the tape cannot be recovered.
NOTES:
  • It is recommended that a high-quality Sony MiniDV tape be used for recording.
Aug 07, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Won't playback and menu won't respond. Acts like its locked up.
Hi, i have a sony z1...
I assume that you can see live view to record on mini dv cassette but can't see recorded image in playback.
Let me know when you playback mini dv cassette, does time counter run time intervals or stays blank on LCD / eye finder?
If this happens, you have dirty / clogged video heads in camera and need to use good quality mini dv head cleaning cassette to clean heads. This will resolve problem.
Need further help, let me know please.
Thank you.
Nov 26, 2008 | Sony HVR-Z1 Mini DV Digital Camcorder
Play back fuzzy
It looks like dirty video heads. Put brand new tape on camera and play it all the way to the end several times if necessary. It will clean the video heads. Good luck!
Nov 24, 2008 | Sony Handycam CCD-TR517 Camcorder
Sony handycam dcr-pc106e pal
Video head is dirty / clogged, please use good quality video head cleaning cassette.
Sep 06, 2008 | E.Digital DCR-PC106E DIGITAL CAMCORDER
Playback problem
Video Head is dirty/ clogged. Use good quality Video Head Cleaning Cassette.
Jun 08, 2008 | Sony Handycam CCD-TR517 Camcorder
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
appear.
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
appear.
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
Samsung SC-D107 digital camcorder
The lines you see in recording and playback are from dirty heads, most likely. Purchase a Mini_DV head cleaning cassette and use it following the directions on the package. This should clear up your problem. You may have to use the cassette several times in succession to get the heads clean.
Nov 18, 2007 | Samsung SC-D107 Mini DV Digital Camcorder
Sony Handycam CCD-TR517 Camcorder Logo
304 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
