Tv won't switch on its a grundig lenaro 32inch lcd tv
It comes on and goes straight off again i think the on off switch is faulty and wondered were to get one from
vizio tv won't switch on
  • jarren Dec 11, 2008
    I have the same issue with mine. just under two years old. I really am getting desperate for a solution. If you find anythjing out will you please let me know via email:
    jarreny@gmail.com
    I will do the same for you if i hear anything.
  • paco007br Dec 23, 2008
    same as me! klv-32s400a!!! have no idea what is it!
5 Suggested Answers
Bappa170873
  • 505 Answers
SOURCE: tv turning off
Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Posted on Oct 08, 2008
SOURCE: remove stand of bottom of tv
I need to take the stand off my 42" jvc to mount it on the wall. How does it come off
Posted on Feb 14, 2010
ginko
  • 19396 Answers
SOURCE: I have a Grundig Lenaro
Hi.
If the flicker is given by backlight, then the problem is either inverter board or power adapter. In some case a defective PC board may also be responsible. A defective inverter is the part that gives this problem more commonly.
Parts for most models can be purchased online entering model number in one of the websites below:
ShopJimmy
PartStore
Here a summary description showing how to test inverter and PSU.
Parts must be tested before replacement. The job must be done by a trained technician.
Call Grundig to check warranty status or to get a quote on repair.
See: Welcome to Grundig
Regards.
Ginko.
Posted on Oct 31, 2010
jdvillanueva
  • 2098 Answers
SOURCE: my grundig lenaro has sound
Hi Mike,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 06, 2011
  • 159 Answers
SOURCE: i have grundig lenaro 32"tv
Sounds like you're only viewing analogue channels.
Go into Menu and find Inputs and select & choose DTV. This will restore reception of Freeview (Digital TV) channels.
Posted on Sep 26, 2011
Picture break up
There is some loose contacts to the connection wires inside the TV. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 27, 2013 | Grundig Lenaro 26 in. LCD TV
Tv turning off
Thanks
Oct 08, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
How to manually turn the subtitles off on a grundig lenaro tv
Turn subtitles language to... turk... o another language ...Solved problem!
Dec 03, 2012 | Grundig Lenaro 26 in. LCD TV
My grunig lenaro 32inch screen freezes whilst on channel sometimes in minutes,sometimes after an hour and I have to switch off /on to proceed- what do I need to do to fix it?
Hello
It is due to its mother board fault. Digital signal processing section hangs up. There is no repair other than replacing the main motherboard. OK.
Jul 18, 2011 | Grundig Lenaro 26 in. LCD TV
Hi, My Grundig Lenaro tv keep freezing every time I try to change a channel, I have to turn it off and on with the button on the tele (not remote) to get it going again... any idea what that could be? It...
Hi. I have had the same problem for the last 6 weeks on my Lenaro 32"
Have contacted the Grundig Support and they are balaming it on the Digital Receiver. They say that the receiver component is made by Beko and thay have carried out an Over The Air upgrade which has caused this problem. Grundig contract out their services as this is just a trading name.
Their support is not willing to do anything and say that it is down to Beko.
I am now trying to get hold of Beko. After that I am going to contact trading strandards and Watchdog.
Apr 28, 2011 | Beko 324250WN 28" TV
I have grundig lenaro 32"tv
Mar 30, 2011 | Grundig Televison & Video
Remove stand of bottom of tv
Feb 04, 2010 | Televison & Video
Need software upgrade
Contact Grundig directly for available updates. Check their website & download directly if available.
Nov 07, 2009 | Grundig Lenaro 26 in. LCD TV
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
Electro Med Services...
