My icom 706 mk2g powers up, receives, but when i push the mike ,the radio turns off, help
  • Carlgme Mar 20, 2009
    HI, I was look around the internet and found this and was wounder if a new power supply fixed your problem wih the radio. when I transmit the radio cuts off. i tried cleaning the contacts and on the plug as well as on the mating surfaces on the removable head but none of this worked so can you tell me if the power supply fixed your problem
    thanks
    Kf4pcp
  • 3 Answers
Hi
I had a similar problem on my 706 MK1. The problem was corroded connections on the white power connector at the rear, When on tx the voltage drop across this connector was great enough to switch the radio off. try cleaning/re-seating this connector
EI4HO
Posted on Oct 16, 2009
    Habit-Forming:
  • 9 Answers
Also, if you haven't yet replaced your power supply, try just running at lower power, or f'r instance 10 watts a.m. and see if it works. That will test all the transmit functions while drawing less current from your supply. If you're patient, you can meter the voltage at the radio's input terminal as you increase power output and see the output power level at which your input voltage drops. But assuming you've got a 20-amp supply that hasn't died, it's likely that you've got a loose or corroded connection, even inside the big Molex plug on the rear of the rig.
Posted on Jan 03, 2010
Sounds to me like your power supply isn't able supply enough current for the radio when it transmits. The 706 needs 20A to transmit. The radio will cut out as described if it's not getting enough current.
73 de EI5GVB
Posted on Apr 26, 2009
  • 44 Answers
Hi There,
I think your power supply is not rated high enough, Try using a 20 amp power supply.
Regards
Paul
Posted on Feb 18, 2009
I followed the instruction to reset my ICOM 706 by holding the up and down button when turning the radio on. but it will not reset. the radio just shows the frequency.
When a device or appliance doesn't behave as per the instructions there is little doubt that it is faulty.
Whether the item should be repaired or replaced depends on various factors, though it is worth contacting the manufacturer in case there is special advice they can offer.
Oct 21, 2017 | Icom Radio Communications
706 mk 2 shutting down on fm high power
sounds like voltage drop. check that your power supply isn't dropping in voltage when transmitting. FM draws a large amount of current all the time, and not just on peaks. The 706 will shut down if the voltage at the radio drops to about 11 volts
Feb 05, 2014 | Icom Radio Communications
My icom 706 mk2g transmits on VHF uhf but not on HF whats the possible problem
My icom 706mk2g does no give me hf power on the hf bands but on uhf is working wel.
On the s meter the last blok is turn on.
Reseiver is working wel.
Wat can it be?? Transistor Finals broken???
The two srfj?
May 19, 2013 | Icom IC-706MKIIG
Icom 7000 switches off when the mike is keyed up and then relay chatters
Check for shorts and opens on the antenna with a meter first.
Mar 31, 2013 | Radio Communications
How can i do a factory reset on an icom ic-706, basically i want to clean it all off and have it like it came out the factory, it this possible??
Hi Paul,
The best I can come up with is Try this: join yahoo group Specific to your radio Make/Model, the experts there will help you with useful info and you can download manuals, schematics and software, if available, for your radio and all this is free.
I hope I have been of assistance to you.
Regards,
Peter
Nov 29, 2012 | ICOM Informatique Icom IC-F21 16ch UHF...
Icom ic720a ham radio not transmitting, pliz help
upon what frequency are you trying to transmit?
Perhaps the radio is blocked from trying to TX on said frequency.
Mar 17, 2009 | ICOM Informatique Radio Communications
1,048 people viewed this question
 Grubhead
Grubhead
