Samsung PN50C550 50 in. TV Logo
Posted on Jul 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem downloading firmware
Using both USB and LAN connection "no updates available". Bought tv late 2010
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Jul 14, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292257
Points
3377
The firmware might be the latest available and no further updation found necessary.
1helpful
Update firmware lcd tv toshiba 32pb10e
How to Update Toshiba TV Firmware
  1. Plug a USB flash drive in to an available USB port on your computer and copy any files from the drive that you want to keep into a separate folder on your computer.
  2. Format the drive as a FAT32 file system. This erases all of the files currently on the USB flash drive.
  3. Click here to open the Toshiba Support home page.
  4. Click "Product Support" in the menu along the top of the home page. The Product Support drop-down menu opens.
  5. Select "Televisions" beneath Choose Category.
  6. Select your type of Toshiba TV beneath Choose Family. For example, options include 3D TV, LCD TV and LED TV.
  7. Select your Toshiba TV model beneath Choose Model.
  8. Click the red "Go" button to the right of the Choose Model section after selecting your Toshiba TV model. The product support page for that specific TV model will be displayed.
  9. Select the "Downloads" tab. If there are no downloads available for your TV model, either your won't be able to click the tab or there will be a message within the tab that says there are no downloads at this time. If this is the case, no firmware updates are available for your Toshiba TV. Check back periodically, as firmware updates are released as needed and aren't scheduled.
  10. If there is content in the Downloads section, look in the Category section for an item titled TV Firmware. If this option doesn't appear, no firmware update is available. However, if this option does appear, click the clickable link associated with the firmware. The TV Firmware Update and Release Notes dialog box appears. In this dialog box you can see the size of the firmware update file, when it was released, exactly what it addresses and more.
  11. Click the red "Download Now" button and save the file to your connected USB flash drive.
  12. Extract the contents of the ZIP file on the USB flash drive.
  13. Disconnect the USB flash drive from the computer after the firmware update file saves successfully to the device.
  14. Power on the Toshiba TV and then connect the USB flash drive to the USB port on the Toshiba TV.
  15. Wait a few moments for the "Firmware file is detected in USB" dialog box to appear on the screen. Select "Yes" to update the firmware. A progress bar displays on the screen. Be careful not to turn your TV off while the firmware is updating. The progress bar changes to a "Success!" message after the update successfully installs.
  16. Disconnect the USB flash drive from the TV and then restart the TV. After the TV restarts you can resume using the TV as you normally would.
Update firmware
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
DIR 503
Change language back english
Dlink dir 600 firmware corrupted
6helpful
Windows 7 AutoCAD 2010 HP DeskJet 1280 All the programs on my compute are printing just fine except for my beloved Auto CAD When selecting the printer, a massage comes " this plotter...
Install the Driver Using Windows Update with a USB Connection (Downloadable Driver Not Available)
As suggest by HP, try this,
HP All-in-One Printers - Installing the Product with the USB Cable and Using the Windows Update Driver or the Driver Located in the Windows 7 Operating System.
Hope it helps.
I have a desktop HP connected to internet Broadband service via a "2wire" router thru my Windstream phone account. I have a Dell laptop that I'm able to use with the wireless connection...
you wont see the pc screen on the tv if that is what your expecting, if the tv is capable of receiving netflix then it will pick that up seperately from the pc, it will only need a wireless connection to access the broadband, you will also need a valid subscription to the netflix service. The fact you have proved you have a valid wireless connection means its connected. There will be an options button to select the internet content to view on viera cast
quote from panasonic ---
VIERA Cast's assorted online content just keeps getting better - in addition to the popular contents such as YouTube and Picasa Web Albums, it now offers Pandora Internet Radio, movies streamed from Netflix*, exciting sports from FOX Sports, tweeting web communications with Twitter, and even home video and audio conferencing with Skype. It also provides USB terminals for a keyboard and Wireless LAN Adaptor. No PC required. Skype function requires an optional communication camera TY-CC10.
Skype service will be available late June 2010.
*Netflix unlimited membership required. Service on Viera Cast TV will be available summer 2010.
*Keyboard and Wireless LAN Adaptor are not included.
1helpful
2answers
I ripped Bluray movies using "ANY DVD HD" to my hardrive then playing them through "WD TV Live HD Media Player" (using HDMI cable to Sony Bravia HD L.C.D.TV) some movies work good but others play the video...
Either check around in Any DVD HD or the BluRay menu to set audio output to PCM, which doesn't require any decoding to play back properly or you will have to convert them separately.
2helpful
2answers
How to i update my psp & my psp not suported the video....give an
you can go to the nearest gaming store to update a new firmware. pls remember not to download any firmware update from the internet, this will corrupt your console. Mostly, internet firmware update are not safe.
Hp_laserjet_4250n_printer
Please reseat the memory DIMM of the printer
Then perform cold reset
NOTE: The Jetdirect LAN (such as the IP address of the printer) settings will be reset to defaults by this operation. Record LAN settings before resetting the printer. Reconfigure LAN settings after the reset if you are using a LAN connection). To avoid resetting the LAN settings disable the embedded Jetdirect before performing a Cold Reset by choosing the Disable LAN option from the choices available when you get to step 5 below. Note that after choosing to disable the LAN it is necessary to reboot the printer and then choose to perform the Cold Reset . During the power up sequence only one operation can be performed at a time. In this case, first disable the LAN, then reboot the printer and perform the Cold Reset followed by another reboot to reenable the LAN.
To perform a cold reset:
  1. Turn the printer power off.
  2. Power on the printer and watch for the memory count to begin.
  3. Hold down the SELECT (Checkmark) button, when you see the memory count begin.
  4. Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
  5. After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until COLD RESET appears on the display
  6. Press the SELECT (Checkmark) button. The printer performs a cold reset and then continues its power-on sequence.
  7. Check all I/O settings and reset any user-set printer configuration values.
Please upgrade the firmware of the printer:
1. Download the firmware file from the following website and extract it.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=412144&prodNameId=412158&swEnvOID=54&swLang=8&mode=2&taskId=135&swItem=lj-25065-13
Expecting that the printer is connected over the network:
Remote firmware update by using FTP through a browser
Complete the following steps to update the product firmware by using file transfer protocol (FTP) through a browser.
NOTE: The following instructions can be used on Windows or Macintosh operating systems.
Take note of the TCP/IP address on the EIO-Jetdirect page. The EIO-Jetdirect page is the second page of the configuration page printout.
Open a browser window.
In the address line of the browser, type ftp://<IPADDRESS>, where <IPADDRESS> is the TCP/IP address of the product. For example, if the TCP/IP address is 192.168.0.90, type FTP://192.168.0.90.
Locate the downloaded .RFU file for the product.
Drag and drop the .RFU file onto the PORT1 icon in the browser window.
NOTE: The product automatically restarts the firmware to activate the update. At the end of the update process, the Ready message appears on the control panel.
The following describes how to upgrade firmware in the LaserJet 2400, P3005 and 5200 Series Printers using a USB connection only.
To send the firmware upgrade via USB, you will need to know the name of the computer the printer is connected to, and the printer will need to be shared.
To find out the name of your computer:
Click the Start button, Programs, Accessories, System Tools, then choose System Information.
You will find your computer’s name in the right window-pane next to System Name.
Write down this name as it will be needed later.
To share the connected printer:
Click the Start button, Settings , then choose Printers ("Printers and Faxes" on WinXP).
Right click on the printer you need to send the upgrade to and then choose Sharing.
On WinXP, if you encounter the following link "If you understand the security risks but want to share printers without running the wizard, click here.", click the link.
Select "Just enable printer sharing" and click OK .
Select Shared As: ("Share this printer" on WinXP) and type a name for the share.
Click Apply and write down the share name as it will be needed later.
To send the firmware upgrade using a USB connection:
Go to a DOS Command Prompt and locate the directory where you saved the firmware file. (To open a Command Prompt inWindows 2000 or XP, go to the Start button, then choose run, then type CMD and hit Enter, in Windows 98 or ME, go to the Start button, Programs, Accessories, then choose MSDOS Prompt). This will bring up a small black screen as displayed below:
If connected to a USB port, Type: copy /b filename \computer nameshare name (for example, copy /b ozfw.rfu \computer1printer).
Press ENTER .
The control panel displays receiving upgrade followed by performing upgrade . The download may take several minutes.
The control panel displays processing job .
The download is complete when the printer reboots and "READY" message is displayed on the control panel.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
