Wega Mininova EPU Espresso Machine
Problem for Wega Mininova EPU Espresso Machine
My little Mr. Coffee maker........don't have the model number handy is not running.
By Beresford - usenet poster
Same Problem
Feb 17, 2009
-   I have a Krups ProAroma that I can't take apart with any screwdriver I have. It starting leaking, got increasingly worse, and I assume it's a little gasket. But I can't get to it. -   pbougeus
Jul 02, 2008
-   My Saeco aroma stopped pumping and then it would not go on at all when it was switched on. -   jamieos
Best Solution
posted on Aug 08, 2005
Helpful)
Ryan
Rank: Apprentice
Rating: 0%, 0 votes
I am assuming that it is either the burner plate or the on/off switch that is the problem.
My problem is what kind of tool do I need to even take it apart. It doesn't use any of the screwdrivers that I have. Any ideas?
Some FAQ's from Mr Coffee..... [url]http://www.mrcoffee.com/faqs.asp[/url]
Was this helpful?
Yes
No
Solution #2
posted on Apr 07, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Try torx T15 the rest are usually phillips
Solution #3
posted on Jun 05, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the model number should be on the bottom of the machine
Solution #4
posted on Apr 05, 2008
Not Rated)
Lordenrod
Rank: Apprentice
Rating: 0%, 0 votes
The cover has six or so snap-on latches. You could pry them off their catch one by one and the cover will come off easily.
Was this helpful?
Yes
No
Popular Solutions for Wega Mininova EPU Espresso
Questions and Unsolved Problems for Wega Mininova EPU Espresso
Do you recommend Wega Mininova EPU Espresso Machine?
Answer
Answer
how do I hook up reservior? No longer have it plumbed into wall.
Answer
Hi, I have a older black and decker spacemaker coffee maker odc150 and I need parts black and decker... (More)
Answer
is there a video that shows how to install a black and decker spacemaker coffee pot
Answer
what I will install in www.mininova.org if other downloads are have a problem...
Answer
It's less than a year old and will turn off cup by cup of brew.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
