Question about Amphion Mediaworks AMW M510
DC input port broken.
The port for the dc input is broken. It is soldered to the pc board inside the dvd player. Where can I find this part? Thank you.
Try Part# CP-040CH-ND
Posted on Apr 09, 2009
Radio Shack can get it... Call 304 925 3992 and ask for John
Posted on Dec 25, 2008
How to replace charging port
Gateway Nv57h73u notebook jack issue check:
1) more common issue is changer ( ac adapter) DC core broken inside, please change a adapter to fix. also you can repair adapter DC core wire. if still no charging that could be DC jack issue inside notebook.
2) disassembly keyboard and top cover of your laptop looking for a wire it connect to the DC jack, check is the wire broken close to the jack soldering pot. you can soldering it to fix, or other issue is jack damaged, you can order and change the DC jack with wire easily, the parts see picture
Oct 20, 2014 | Gateway Nv57h73u With Autodesk Maya...
Acer aspire one charging port loose
If I recall this model line uses a fixed DC power jack directly soldered to the main board. When they become loose, you can visually inspect the jack itself (without the cord plugged in), and use a pen or probe to see of the center peg is excessively loose. The common result is the solder connections have been broken between the DC jack and the main board. Often the jack itself needs to be replaced (involving complete disassemble, de-soldering old jack, cleaning, repair PCB if needed, and re-solder new jack in place.
TIP - if it is not charging, remove battery, and gently put pressure from different angles with the power cord plugged in, and try to turn it on. If it turns on with pressure from a specific angle, it would indicate the DC jack is indeed loose, and likely needs to be replaced. It works becomes the pressure is making the electrical contact that has other wise been broken. ALSO, if it turns on easily, yet losses power at certain angles, its a similar issue.
TIP2 - If it still indeed charges regardless of the angle, and does not lose power, it may be a "Modular" DC jack, meaning the jack connects to the main board through a wire harness, and is less prone to breaking the electrical contacts, and the jack is simply loose inside it's retaining clips/slides. Minor disassembly and hot glue are quick fixes for this since usually the plastic clip/slide in the chassis have broke.
Dec 06, 2013 | Acer Aspire One PC Notebook
I have XPS M1530 DELL Laptop. DC JACK(power charging port has broken from mother with a very small piece of mother board)....I had tried to call customer care ..he told you should change the motherboard...
If this motherboard is a multi-layer motherboard then it is impossible to repair.
You can try to repair the motherboard by glueing the broken piece onto the motherboard with epoxy glue. Then identify the broken power circuit tracks between both parts of the circuit board, and then solder wires across these tracks or to the closest solder connections to re-establish the electrical connections on the motherboard.
If this does not fix the problem then most likely it is a multi-layer motherboard and you cannot bridge the internal connection inside the motherboard.
Jun 22, 2011 | Dell XPS M1530 Laptop
How to replace dc power jack for toshiba p15
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
May 19, 2010 | Toshiba Satellite P15-S420 Notebook
This is not something you can do yourself. It requires soldering. You first have to remove the old jack then solder the new one to the board.You can,t over heat the board and alot of other stuff. We repair jacks for 110.00$.Look us up on facebook...rippy computers or call 704 820-6433.we would be glad to help you if we can.We do alot of mail order repairs.
Apr 28, 2010 | Toshiba Satellite A105 Notebook
We can't get the NS-PDVD8 to power on when it is plugged into the car power outlet. The light to the power cord is on and we know the power outlet works. Any suggestions?
Most likely your DC power supply input jack on the NS has cracked loose from where it's soldered onto the circuit board inside.
Nov 28, 2009 | Insignia NS-8PDVD
Magellan maestro 5310. when pluging in th power
yes it can be fixed
you can go here for help
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 15, 2009 | GPS
Need new car charger adapter and cords for Coby Twin DVD Players
i need tis car charger adpter and relating cords to my twin coby dvd players replace how to do htis; where to buy im in jacksonville florida .thank you
Jun 25, 2009 | Audiovox PVS72901 Portable DVD Player
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
DC input jack broken
you need to buy a new jack for replacement. then solder the broken one out of the mainboard and clean the place and solder the new one. or some acer have a separet jack then that one is easy only to change.
Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
Amphion Mediaworks AMW M510 Logo
510 people viewed this question
Top Amphion Mediaworks Televison & Video Experts
Are you an Amphion Mediaworks Televison and Video Expert? Answer questions, earn points and help others
