Do you have audio? If so, your backlight inverter may have failed. As for why the remote won't work, could be coincidence or it could be a power supply problem that is causing both.
the red picture is because the optical block is bad now this part cost about $500 plus labor , when you took the lamp out you need to put the door back otherways the tv wont wort
It could be the temp sensor going bad. This sensor sits on top of the
metal housing which the bulb assembly slides into. The bulb assembly
will have a hole on top and this is where the sensor is above. There is a
small blue and white wire that plugs into it. If you pull the wire out
and put a paper clip or wire in the coupling you will basically bypass
the sensor connecting the blue and white wire. If your tv turns on then
that is your problem. Its cheap too. Here were my symptoms..1] Turn tv
on 2] Bulb would light up..(which eliminates the ballast) regular
picture would show up (which eliminates the bulb and color wheel) 3] 30
seconds later tv would shut down with 3 flashing lights. After bypass
the tv turned on as always and hasnt shut down yet. Always un plug tv
first. Get the replacement part to avoid overheating and possible fire
Well first of all you can tell us the Brand and the Model number of your TV? and tell how old is your TV? Anyway you can try to reset your TV first unplug (switch off) your TV for 24 hours and then turn it again........... let us know if further you have the same problem.......
symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
