Question about Lexmark X4270 All-In-One InkJet Printer
Printer prints garbage
Lexmark x4270 printer works fine on old 1.6 MHz clock; xp software computer. Doesn't work on new T3504 emachine 1.6GHz clock; xp software computer. Printer adds and omits characters, runs characters together smears a running path of colors over printed areas. Lexmark has no solution. They state speed is not a problem I must be hooking the printer up incorrectly. How incorrect can I hook it up. You put the interconnect cable into any USB port it only fits one way. Have tried new driver hardware from Lexmark. Also tried another x4270 printer at on my computer atOffice Depot. They wouldn't try the printer on another T3504 emachine computer. Regards: James Robinson
    Sergeant:
  • 390 Answers
Did it ever work on new system or never has. Sound like either a software conflict or similar but most likely it doesn't like new machine specs. Have you made sure no other printer software is accidentally installed. Are specs for new system and printer compatable. Some manufacturers specify their machines specifically do not like certain OS's and specs. Because pc and software tech is going so fsat it is really hard for manufacturers to keep up, just as they run off their new printer, state of the art, microsoft brings out a new OS etc, and voila, a new updateddriver is needed. Have you considered it may be the pc causing the errors, ie the registry (from malware,spyware etc) not allowing proper installation. This can and does happen. Just last week, my friends printer was perfectly fine, she had some spyware and we had to edit the registry as it had corrpted where the printer was installed but also her cd rom drive icon and use were wiped out. Run antispyware virus and registry scans to eliminate these. Also try installing printer off a back up copy of the disc not original, good luck.
Posted on Sep 03, 2007
Trying to install software for x4270 into new machine with Windows 7. Tells me software not available in English. Was previously installed with XP in old machine with no problems. Any ideas?
Uninstall the existing Lexmark X4270 printer driver from your Windows 7 by going the Start menu ? Programs ? Lexmark 4200 Series ? Tools ? Uninstall. Reboot pc when prompted. When pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system by going to the Start menu ? right-click on Computer ? click on Properties. Take note of the system type.
Download and install the X4270 driver for Windows 7 using the links below:
Follow the instructions in the software.
Thanks.
Nov 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 all-in-one problem with Windows 7
I really appreciate your patience. Thank you for choosing Lexmark glhall53!!!
Apr 29, 2010 | Lexmark X4270 All-In-One InkJet Printer
P2023 prints garbage with vista
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
Jul 30, 2009 | Panasonic KX-P2023 Matrix Printer
Bought a new computer had windows Vista on it my printer lexmark x4270 worked in my old windows XP,but it don't work with Vista. I tried to get a driver for it but no luck. where can I get a driver . I...
This usually happen with an old printer and new computer with new OS.
You can try downloading your new driver for Vista at Lexmark website here:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569478_0_en,00.html
If doesn't work, ask to customer service for assistance
But at this point:
1) is better to get a new printer compatible with Vista
or
2) Downgrade your OS to one compatible with your printer.
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Computers & Internet
Printer
My operative system is using a Vista, and my printer is a Lexmark x4270.
Sep 29, 2008 | E-Machines eMachines Desktop PC
Lexmark X4270......All in one....computer recognized it two days ago, but today it isn't doing anything. Can you help me?
The issue which u r facing is" Communication issue"
Make sure u have installed the lexmark printer software...or else download it from the lexmark website(lexmark.com)..choose the s\w for ur operation system( Xp or vista(32bit or 64bit))...
If s\w is installed...
Check the USB cable..try different port...
Clear all the docs in the printer folder...
Remove the power adaptor and replung..restart computer..
When u unplug and replung the usb cable doesn ur computer give a pop up "found New hardware" ?...If it doesnt..then (Check if USB printing support,USB composite device are present in the Device manager...i.e Right click on "my computer" ikon-go to PROPERTIES-Hardware-Device manager-Click the plus sing near and check in the list )
U can also try...
Uninstalling the s\w....disconnect the USB cable..reinstal the s\w and connect the cable when it prompts to...
Jun 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270
i need software vista instead of xp to hook up my 3 in one lexmark x4270
Apr 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 Plain Paper Inkjet Fax Troubleshooting Forum
Goto the Lexmark site and get the right driver. make sure you have the right model fax and operating system. This appears to be the wrong printer driver.
Aug 02, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Reformatted computer worked while now recives faxes wont print
Uninstall all of the software and go to this link http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:439:0:0 install the updated version of your printers software and let me know what happens.
Jul 19, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
