Question about Xerox Phaser 6110 Laser Printer
Xerox Phaser 6110MFP reports FM_IO.c 172 ROOT during startup
About 20% of the way through the start up routine my Xerox Phaser 6110MFP stops and reports an error "FM_IO.c 172 ROOT".
After that, the machine is all but useless. Nothing comes on so can't print, fax or scan. Any assistance would be gratefully received.
Ian
  • ilong583 Dec 11, 2008
    Solution - Leave the printer switched off overnight - the failed fax message in the buffer will time out and the printer will start up as normal the next day
    Novelist:
  • Xerox Expert
  • 297 Answers
Also make sure you have the machine plugged directly into the wall outlet...some surge protectors or multi-outlet strips won't allow sufficient power to properly boot up and run the machine !
Posted on Jan 17, 2009
Xerox phaser 6110mfp print light on one side
Anonymous I suspect something serious has caused a problem.
I expect you must have sorted the problem by now.
Good Luck.
Aug 21, 2014 | Xerox Phaser 6110 Laser Printer
I can not install this printer in windows7 operating system
Hello.
Unfortunately, Xerox doesn't yet offer Windows 7 support for your device. However, they announced a release of the Windows 7 driver until June 2010.
Still, you can try installing the Windows Server 2008 driver:
http://download.support.xerox.com/pub/drivers/6110MFP/drivers/win7/cs/Phaser_6110MFP_W7.zip
Source:
http://download.support.xerox.com/pub/drivers/Compatibility_Matrix/other/win7/en/Windows7_Matrix.pdf
Now ... are you sure your device is not 6110MFP? Because Xerox Phaser 6110MFP does have Windows 7 support and you can download the driver here:
Mar 30, 2010 | Xerox Phaser 6110 Laser Printer
Mac OS 10.6 Snow Leopard: Printer Driver Update for Xerox Phaser 6110 does not work ! Xerox/Apple is providing a most complicated instruction to circumvent the problem that I am not able to...
    1) Change the “Xerox” Folder Permissions:
    • Navigate to Applications > Utilities and open a Terminal window.
      • Type the following command: sudo chown -R root:admin /Library/Printers/Xerox
    • You will be prompted to enter your password.
    2) Install Rosetta from the Snow Leopard DVD:
    • Insert the Snow Leopard Install DVD
      • Select Optional Package
      • Select “Rosetta only” from the list of optional packages
      • Click install and follow instructions to complete installation; there is no need to reboot
    3) Reset Printing System:
      • Navigate to: System Preferences> Print & Fax> Xerox Phaser [6100, 6110, 6110MFP]
      • Right click on the printer
      • Select Reset Printing System
    4) Install Printer (without removing the driver):
      • Select +: add the available Xerox printer
Mar 18, 2010 | Xerox Phaser 6110 Laser Printer
Phaser 6110 mfp , the display say that the scanner is locked , I don't have the manual with maiself
Check here.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=465,E=0000000001733349606,K=391,Sxi=10,Case=obj%284350%29
Oct 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Invalid Black Toner Xerox Phaser 6110 MFP
reload the driver again and if it persists, change the toner
Jun 23, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Xerox 6110 MFP scanner locked
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
75884d7.jpg Front of the Xerox 6110MFP howing paper output tray and control panel.
7020767.jpg Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
Feb 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Xerox phaser 6110 mfp
sir,
clean the LSU(Laser Sensing Unit) with a dry cloth.
Sep 25, 2008 | Xerox Phaser 6110MFP All-In-One Laser...
Xerox Phaser  6110 Laser Printer Logo
214 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
