Question about Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver
Home page I lost all of my icons on my home page but my app and sound tones (vibrate,loud, etc) I can't get them back on the screen.
I was talking on phone in the car. Made a quick call. Everything work fine. Than the screen went blank white. I can't see the screen of any application. I take the battery out to see if it would reset the phone and turn it back on. It went straight back to the blank white screen. I try another solution. I use my home phone. Call my phone. It signal as it was off mode. Straight to answering machine. Red light flashes....I then, hold #1 to get voicemail. It did work. So my service is good. So my problem is how can I solve the blank screen issue? Has it happen to anyone before. Battery strong and it's not low on battery level. Thanks for any suggestions.
Posted on Dec 21, 2008
My App Store icon has disappeared from my iPad and my apps do not show up in iTunes. My son can't play Boom Beach without updating it. Please, someone help me put the App Store Icon back on my iPad
If the App Store icon seems to be missing from your Apple iPhone or iPad, give these steps a try to find it.
Fix 1 - Double Check Everywhere
Be sure the icon is not in a folder. Check every Home screen and every folder. Also use search to see if you can find it. From the Home screen, swipe all the way to the left screen, then search for "App Store" to see if it appears.
Fix 2 - Check Restrictions
  1. Open "Settings" from the Home screen.
  2. Tap "General".
  3. Select "Restrictions".
  4. Make sure "App Store" is set to "On" (green).
Fix 3 - Reset Home Screen
It is possible that the icon is on a different home screen or in a folder. Look on other screens and within folders. If you still can't find it, try resetting the home screen by selecting "Settings" > "General "> "Reset" > "Reset Home Screen Layout". This should return your icons to default settings and restore the App Store icon.
Note: If your iPad was provided to you by the organization you work for or a school, it is possible there is software on the device that locks access to the App Store. Ask your IT department for access if you feel this might be the case.
Nov 11, 2016 | Apple iPad Tablets & eReaders
Tip
BlackBerry Tour: How to make it ring and vibrate for incoming calls
You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
on Jul 10, 2010 | RIM BlackBerry? Tour 9630 Smartphone
How do I unfreeze a Google app page?
Reset the App
1. Double-click the Home button. This minimizes the app and displays the iPad's multitasking screen.
2. Drag the stuck app upwards on the screen. This forces the app to close and removes it from the iPad's memory.
3. Press the Home button to display the iPad's home screen. Tap the app's icon to relaunch it. Any unsaved data, like words you typed in a document or progress in a game, is lost, but the app opens and should respond normally.
Apr 21, 2015 | Apple iPad Tablets & eReaders
My Samsung Galaxy Light won't vibrate anymore. How can I fix it or get it to work again. Thank you
Setup the Vibration
This option allows you to set your device to vibrate and ring.
1. From the main Settings page, tap My device tab ?
Sound.
2. Tap Vibrations.
3. Select a vibration pattern and tap OK.
- or -
Tap Create to then use an on-screen touch circle to
create your own custom vibration pattern. Tap Save to
store the new vibration pattern.
Sound Settings
From this menu you can control the sounds on the phone as
well as configure the display settings.
 From the Home screen, press and then tap
Settings ? (My device tab) ? Sound.
The following options display:
Silent mode via Device Options Screen
Silent mode is convenient when you wish to stop the phone
from making noise, in a theater for example. In Silent Mode
the speaker is muted and the phone only vibrates to notify
you of incoming calls, or other functions that normally have a
defined tone or sound as an alert.
1. From the Home screen, press and hold
(Power/End) until the Device options screen displays.
2. Tap either Mute, Vibrate, or Sound from the Device
options screen to activate or deactivate these features
(the current mode displays).
You can download the User manual from the site below
https://support.t-mobile.com/docs/DOC-9140
Feb 07, 2015 | Samsung Cell Phones
I dragged an APP to home page by mistake how do i return to APP icon
Hold your finger on the app icon until it vibrates (can be moved). Press the home button when done.
Aug 14, 2014 | Cell Phones
Sony ericsson xperia 8 phone icon & box icon on home page disappeared. How do I restore?
1.Go to "Settings" from the iPhone home screen.
2. Select "General."
3. Go to "Reset" at the bottom of the page.
4. Click "Reset Home Screen Layout."
5. Click "Reset Home Screen." The icons on the home screen are now back to the default icons, including the App Store icon.
as well as you can restore all icon on home page.
Aug 17, 2012 | Sony Ericsson XPERIA X8 Cell Phone
Frozen
What phone are you using? I suggest that you get you home screen (iPhone) and locate the app icon. Hold the icon down until it vibrates and shows a x at the side. Press the x and delete the app. Switch phone off. Switch on again, go to App Store and re- install the app. Should be ok then. Just check you have sufficient memory to install the app Settings>General>About will tell you.
Sep 27, 2017 | USAA Mobile Banking
My phone will not ring out loud and vibrate at the same time.
To turn on a ringtone and vibration, go to your BlackBerry's sounds and ring tone options by either of the following ways:
1. Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
2. In the Home folder, go to your Options folder (usually toward the bottom, has a wrench icon) and select Sounds and Ring Tones.
Select the ring tone and volume that you want, and for Play Sound select Always. Scroll down to Vibration and set it for On.
There is an option for Vibrate with Ring Tone -- set that to on in order to make your phone both ring and vibrate at the same time, then save the settings when you cancel out, and you're all set.
Jun 21, 2010 | RIM BlackBerry? Tour 9630 Smartphone
How do you change ring tone for a text message on a blackberry tour 9630
Go to the sounds icon in the upper left corner of your main Home screen (the one that looks like a speaker with sound coming out of it). Scroll down the list that appears and select Set Ring Tones/Alerts. Click Messages, then SMS Text. Select the ring tone and volume that you want for text messages, as well as any other options (like vibrate) and then exit out and save your changes.
Jun 11, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver Logo
306 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Laxman Bisht
Laxman Bisht
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
