Question about Abit AN8 32X Motherboard
Abit an8 32x post error code 5.2
Can anybody help. i have just taken my pc apart to install a new drive ready for vista. i reasembled the pc and when i now power the pc up, i get a beep error with the code 5.2 or it could be 25 depends which way you look at it? i have taken my graphics card out and started up my pc again and recieve the same message. i think my gfx card may have just died (7800gtx) but am not sure. what else could i try??? i have removed each stick of crucial memery in turn just in case this was error 2.5 but with no luck?? please help a desperate man? chris
    Sergeant:
  • 310 Answers
Is it when you are installing vista or on the black screen with white writing you are getting this error? if it was your graphics card you wouldnt get any picture so cant be that mate. and if you can give me the exact message it displays i will try and help you.. All the best John
Posted on Mar 02, 2007
What does code 7f mean on kv8 pro
Did you ever resolve?
This is the board with the external OC monitoring panel, right?! I owned this, too. I had a similar KV8 board from Soltek, as well--post codes, also. My Abit died several years ago.
The ABit's manual still exists online. According to the code, It's hanging on the onscreen logo--it says to switch to text. Here's the page describing your code: http://www.manualslib.com/manual/615/Abit-Amd-Athlon-Kv8-Pro.html?page=69#manual
If I remember correctly, that's not a serious error code--popped up often after new installs.
If it's a hard drive error--do you have the master/slave configuration jumpers correct? (Hard drive vs. Optical drive? Probably, you want the hard drive as master--optical as slave)
Is cable orientation (Pin 1--from PATA cable and at drive(s)/board) correct? Perhaps I remember now--maybe the BIOS can't get to the hard drive and OS.
Is your floppy light always illuminated (it shouldn't be)--is that cable installed correctly?
If your onboard hdd controller is dead--and, you worked with AGP over the years--you likely have a PCI card that will take its place. (If not, you may purchase that pretty easily. still.) Syba, Siig, Sabrent, StarTech, etc.
If your controller is OK, have you tried running a live i386 (32-bit) or AMD 64(64-bit) Linux disk or an old Bios upgrade/DOS floppy--to see if you get some type of OS posts? Is your proc 64-bit or 32-bit?: If I remember correctly, 754 CPUs generally were 64-bit--some were 32-bit, though (I still own one of those, too).
Did you clear your CMOS first (move the jumper for a few seconds and back)? Is the jumper correctly installed now?
Ah, the days of socket 754 (I never obtained Socket 939.....) Socket 754 still is a good value--you may obtain such a proc for about $5 on Ebay. (Used boards are a little pricey--considering.) I get the sense that 754 was the business board--939 was the gamer board.
Recently, I resurrected my old Shuttle Athlon XP board--considering its age, it holds up pretty well. Works fine with 32-bit Linux Debian distros. Dual-channel. Great OC board in its day. Currently, I have a 9800XL card in--soon, I'll put in a 3850 AGP....
May 23, 2014 | Abit KV8 Pro Motherboard
Error code 800fo900 windows vista
To download and install the System Update Readiness Tool, follow the steps below:
1. Click Start
Collapse the imageExpand this image
, and click Control Panel.
2. If you use Windows 7, click System and Security. If you use Windows Vista, click Security.
3. Under Windows Update, click Check for updates.
4. The System Update Readiness Tool (KB947821) is offered, only when
5. Click Install updates.
hope this helps
Jul 14, 2012 | HP Compaq Presario SR5010 Desktop PC...
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Windows Vista: I cannot install anything at all.
Is your Vista a 32 bit or 64 Bit O/S
open this link and run the Windows readiness tool, This will help the PC unblock any failed updates for Windows and help you install the new updates.
http://www.microsoft.com/downloads/details.aspx?FamilyId=b4d90b06-c27d-4483-bc1f-04d43fa7b293&displaylang=en
Windows installer for Vista is Installer version 4.5, so the updates should fix the issue.
Jun 29, 2010 | Computers & Internet
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
Hello. I'm portuguese and i have an abit fatality an8 soket 939 and i have a problem with the motherbord. She stop in the error "9.0" " AWARD BIOS TAKE OVER BOOTING JOB". What i have to do? What are my...
This seems to be a common problem with this board. That error could mean any number of things from a loose cable to a fried chip. Flashing bios will not get rid of the problem.
Take a look at this article.
http://techspotlight.today.com/2009/06/03/abit-motherboard-post-code-error-90/
Good luck,
Hank
Jul 29, 2009 | Abit Fatal1ty AN8 SLi Motherboard
Two cd's stuck in player
Easy fix, just take apart your unit, it is very simple if you have taken anything apart before. Once you get the screws out of the casing and you take the top off the main thing will be taking the top off the cd drive. Hopefully you will not have bent arms from the jam on your cd drive like I did. Because now I have to either get a new drive or send it to Bose for a complete refurb which is only 100 dollars and for what they offer its a great price! I could fix it myself but I cant find the drive anywhere and Bose don't sale internal parts! Anyway once its taken apart remove cd's carefully and reasemble. Easy as that unless you encounter the same problem I did! Good Luck!
May 22, 2009 | Bose Wave Music System CD Shelf System
Abit AN7 motherboard does not boot - POST code AF
i think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
May 09, 2009 | Abit AN7 Motherboard
Manual and Bios for Abit AB9 Pro Motherboard
Hello seany187,
What I'm doing since your system doesn't want to download from Abit, is creating a zip file with all the drives, manuals, utilities and bios updates for both XP, XP64, Vista, and Vista 64, since I don't what OS your on, and you will be able to download them from this private site HERE. And because the files are so large, I split them into, I'll post the second one as in a comment as soon as it's completely up on the site.. You shouldn't have any problems with these downloads, unless you have your IE settings to high.
Good Luck & don't forget to leave a rating based on my Solution.
Thanks Mark
Stay tuned for the second file!
Apr 06, 2009 | Abit AB9 Pro Motherboard
Have a Abit A17 mother board that posting a 25 or 5D error code
I picked this up from an abit forum, It appears that it is quite common, look here, http://forums.hexus.net/abit-care-hexus/104674-abit-ab9-pro-code-25-error.html
Dec 21, 2008 | Abit A17 Guru Motherboard
Abit AN8 32X Motherboard Logo
389 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Daniel Dollive
Daniel Dollive
Mike
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
