Question about Ariston Technologies AW 129 NA Washer With 1200 rpm max and 16 lbs/7.5 kg. Load Capacity (AW129NA, AW129 NA, AW-1...
Washing machine not working
Hi when i chose a programme and turn my machine on the red light comes on but nothing at all happens the machine does'nt even try to run the cycle. I checked to see if anything was stuck in any of the pipes thats the only steps i have taken. Do you have any any suggestions?
    President:
  • 1,294 Answers
Before switching the "on" switch select your programme, ie whether you want spin, wash, etc. Then put the "on" switch on.
Posted on Apr 11, 2007
My candy lights are on but it will not start washing
Douglas
Sometimes I think that those machines have a mind of their own. This certainly applies to my Candy washing machine and my computer.
  • What I do when the lights are on but nothing happens, is that I turn the machine off and wait 3-5 minutes
  • Choose another programme and push the button
  • Usually it starts washing but if not
  • I disconnect the electricity and wait 3-5 minutes
  • If nothing happens then, I give the machine a rest for ca 24 hours and hope for the best.
  • which usually happens
Kolbrun
Jul 25, 2015 | Candy Washing Machines
Classique dishwasher, 3 weeks old. turned it on and chose dishwashing programme. Started ok but then beeping sound and has gone to pots programme. Light jus flashes. Stopped. Cannot reset. tried turning it...
You have a warranty, call the seller and ask how to use the limited warranty you have on the machine. As long as you didn't do something to the machine, they will usually just give you a different one to save on service calls in the long run, just get an exchange, I don't see any reason they won't do it.
Sep 01, 2011 | Dishwashers
Indeset washing machine has stopped working. You select the programme the green light comes on but nothing happens. It in not filling up/ draining/ spining nothin, Can you help????
this may sound silly but just had the same problem changed the pump and it works fine now, if the pump does not work it wont let the washer start
Oct 18, 2010 | Indesit W 123 Front Load Washer
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Hi, My washing machine is not completing the washing cycle, it gets stuck when the water should go out of the tank. There is anormal noise like if something does not have the strengh to pull the water...
well Xavier, looks like you have a bad water pump in your machine, or its clogged up with debrie, either way you will have to have a qualified tech check it out unless you are extreamly handy with replacing pump motors, its not to easy to do, hope that helped ya
Jan 19, 2009 | Refrigerators
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
Hot wash programme won't work.
more than likely that your timer dial has a fault on it to replace your timer dial is alot if u need the 90 degree wash then you really are better off buying a new washer just as cheap to do it this way sorry for the bad news theres nothing you can really do sorry yet again m8
Dec 11, 2006 | Candy AQ130 Front Load Washer
Washing Machines Logo
380 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
