Question about Brother MFC-7820N Laser Printer
TONER LIFE ENDED
My printer's toner life ended, so I replaced with a brand new one that has been working in our second printer. It still says the same thing, "Toner Life Ended, Replace Toner".
Any suggestions?
While you have the door open, you have to press some buttons on the menu which will reset the counter. Sorry, I forget what they are right now (it's been a while since I've done it), but you can google and I'm sure you will find it.
Posted on Jun 22, 2009
Brother DCP-9020CDW - How can I reset the toner life?
Hi there
You can reset the brother dcp 9020cdw toner cartridges using the printer menu. Its simple. see video on the link
http://www.zinetic.co.uk/Blog/resetting_the_brother_dcp_9020_cdw_toner_cartridges-blog.aspx
Nov 18, 2013 | Brother DCP-7020 All-In-One Laser Printer
Toner life
You need to reset your Brother printer to get rid of the message
Mar 26, 2008 | Brother IntelliFax-2820 Laser Fax
Says toner life end and it's not ended. thanks. I also never reset drum button when got new drum how do i do that as well? thank you :)
hello
hen the toner almost end it will give you notice toner near end and you have to replace the toner and there is small button to be slide to clean the drum and also sometimes even if your replace new toner it will still appear the toner near end you have to shutdown the printer remove the powr at th wall and also at the back of the printer and wait for some time and plug it back and turn on.
thanks
Apr 14, 2011 | Brother DCP-8065DN Black and White Copier
Toner Life has ended
Did you pull the plastic tape on the cartridge?
Feb 11, 2010 | Brother IntelliFax-2820 Laser Fax
The toner life ended and then we got a refill. Earlier on refill, It was working fine, But this time it still says , TONER life end, replace toner. We tried loading 2 different refilled toners and cleaned...
we can refil toner many times but we should reset cartage, while we refiling toner to open cartage we should sides white rings middle plastick flate white plate make adownof cartage it is first methode. when we put reffiling cartage put on printer and do on at that time we push cartage right side pointo re set. look on www.brother.com
Nov 05, 2009 | Brother MFC-7820N Printer
TONER LIFE END BUT TONER IS NEW
first print out a help page. i beleive that this is in the reports section, scroll down to drum follow the promps the same for toner good luck brother sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Toner life end
Try removing the new toner cartridge from the machine, and shake it up and down and sideways, over a newspaper. Then, put it back in the machine and see if that helps. Sometimes, especially if the new cartridge was exposed to high temperatures or humidity before you got it, the toner SETTLES inside. Shaking it up can usually help.
Jul 06, 2008 | Brother MFC-7820N Printer
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Toner life
where and how to find the reset actuator?
Nov 06, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC-7820N Laser Printer Logo
800 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
