Question about Intel Motherboard
Intel D845GRG no video!
I got this board and the onboard OR video via PCI
or the AGP slot works
Is there a jumper setting that i need to attend to?
  • 2,351 Answers
HI madpanic_att, there is no jumper for the onboard graphics card,
82845G Graphics Memory Controller. If you add an AGP video card it must be 1.5volt compliant & can only function at a max speed of 4x. The Intel motherboard will automatically detect the AGP card & boot the card. If you no longer have your manual, click on this Intel link & download it; (Bottom of page).*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
You will need Adobe PDF reader to view the manual.
You can download Adobe for free at this link;
Look & read page 16, (Accelerated Graphics Port (AGP) in manual & PCI Auto Configuration. Bios configuration, see page 53,
(Video Configuration Submenu).
See a list of 4x AGP cards at this next link;
Remember the AGP graphics card can only run at 1.5volt in your Intel D845GRG board.
Example, here is an AGP card. Notice the separations between the contacts. (This is an 8x card).
This next AGP card is 1.5volt, see the contact separations.
This is also an AGP 1.5v card;
If you add a PCI card you will not have to worry about the 1.5volt limit.
Here are some PCI graphics cards;
Good luck madpanic_att!
More questions?
Thank you for using fixya.
Posted on Dec 11, 2008
Can a PCI video card be installed on the Intel SE7501BR2 server board? My onboard video has color problems. I tried a known-working PCI video board after turning off onboard video, but got no video...
Most of the time you'll need to change a setting in the BIOS to force the computer to recognize the PCI slot first. Try going through your BIOS settings until you find it. It should be something like "Display First" or Primary, and it should be set to onboard graphics. Try changing that to PCI and see if that fixes your problem.
Aug 29, 2011 | Intel Server Board SE7501BR2 Motherboard
hi i have recently fix the problems i had with my intel d845grg onboard
sound card,after downloading 10 drivers for the ad1981a soundchip
i found it wasent the driver.fix located your soundchip and just above
it you will see a bank of jumper plongs on the pcb put a jumper over the
the last two jumpers nearist the pci slots, reboot your pc and you now have
sound this has taken up a large amount of time to find this simple
regards john sykes
on Jun 30, 2009 | Intel D845GRG Motherboard
Gateway E-2000 series wimpy video needs upgrade
according to the manual it also has an AGP slot so you could start there.
That is the manual for the board you listed and has the spec for the AGP slot etc.
Hope its of help.
Jul 16, 2010 | Gateway E-2000 PC Desktop
Syntax 635MP no PCI video?
You don't move it away, you install the new video card in the pc, you connect the monitor to it, you start the pc and go in the BIOS and in there you disable the onboard video. After that it will work just fine.
Jun 01, 2010 | Computers & Internet
Need jumper pin config settings for imperial gv 2003 i need to know what j-5 is for mostly
This MB is very similar to Intel 845 boards. The info is similar & if you had mentioned which jumper's, then maybe.. otherwise this is the specs of imperial:
143159 Imperial GV 20030812
Mat,no:143XXX IMPERIAL-GV200XXXXX E-Machines Socket 478 Processor Socket Type: mPGA478 Memory Type: Unbuffered DDR Synchronous DRAM (DDR SDRAM) Memory Speed: PC2100/PC1600 Memory Sockets: Two 184-pin 2.5 V DIMM sockets Maximum Memory: 2 GB 256Mbit Memory Support: Yes Front Side Bus: 400MHz Intel: Extreme Graphics (845) AGP Manufacturer: Intel Bus: AGP Chipset: Intel 845 Video RAM Type: Uses system memory Onboard Audio Configuration: Intel ICH AC 97 CODEC AC'97 Codec Device: AD1886 Audio Jacks: M, LI, LO, (Header) SO Speaker CD-In Connector: 1 Internal Spkr-Out/Line-Out/Headphone-Out/Mic-In Header: Yes Onboard LAN Onboard 10/100Mbps Ethernet LAN Supplier: Realtek RTL8100(B) Ethernet Configuration: Down(PCI) Wake-on-LAN, Wake-on-Ring: via PME#(PCI) .....................sodeep
Sep 13, 2009 | E-Machines Computers & Internet
Hello there I have a P4 2.66 intel D845GRG chipset 2gig Ram and would like to upgrade my MSI GeForce4 MX440 Video card, I play CS1.6 online and would like to improve video quality and performance
Well the board and chip are fairly slow...
But... not too slow... so you can buy a new graphics card..
Luckily for you, the AGP slot cards have not completely disappeared off the face of the earth yet, and you could buy a cheap used one or even a new one if you like to waste money on old computers.
I suggest a 6600GT used or something similar.
try to get a 6 or 7 series or decent radeon 2900 or 2600xt or 3850 if you really want to blow the cash.
BUY AN AGP BOARD!! do not buy a PCI-Express board, as it will not plug into your motherboard.
Also check if you have an AGP slot before you buy a board.
Mar 13, 2009 | Intel Motherboard
Graphics card
Hi Harikris, no you can not install just any graphics card. You're Intel D845GLLY board uses an onboard graphics card. (It's an AGP graphics card).
If it's you're intention to install a new graphics card you must use a PCI graphics card. (Understand that the AGP onboard graphics is faster than a PCI graphics card). However, the PCI cards do use their own memory. (Which fee’s you're system memory to run windows.
The Intel D845GLLY has 4 PCI (White) slots, onboard. You can add a video card into the system. You're onboard video card does use you're system memory to function. If you're PC has 512MB of system memory & you're video card is set to use 128MB of memory. Than you're system is left to run with 128MB. One would think you're system is running a little slow.
The Intel D845GLLY motherboard can use up to 256MB of system memory. You can set the amount of system memory in the bios as shown on page 49, table 18. In you're manual. If you do not have you're manual you can download it from here:
May I suggest you increase you're system memory to 1GB. Than increase you're graphics memory to 256MB. You're system will run faster & so will you're graphics card. These older Intel motherboards require memory current for you're board. Click this link:
If you still feel that you want to use the slower PCI graphics card you can choose from any listed on this link:
You will also need to change a setting in you're bios to boot to the PCI card instead of the AGP onboard card. Page 49.
Good Luck!
Jun 04, 2008 | Intel D845GLLY Motherboard
Vga display problem
There is one pin/wire on the VGA connector that translates to the color red on your screen. If you aren't seeing any red, I would suspect that there is damage to the integrated VGA connector on the motherboard, or a component failure in the circuit.
These are great desktop boards.
The Video bus on these boards are shared between the integrated (onboard) video card and port and the AGP slot. This means that you can only use one or the other. When you install an AGP card in the slot it overrides the integrated video including your problem.
If you are good with electronics I'd take a look at the board under the scope and look for damage.
I would rist check with intel on the warranty. You may be surprised. I've had several of these replaced via RMA through intel. They are a bit older but still by desktop board of choice.
May 21, 2008 | Intel D865GBF Motherboard
GeForce4 MX 420 Video Card
First question: Are you sure you have a PCI card?
there are several points here:
Make sure you have the monitor connected to the correct output on your computer. (In this case to the output of the graphics card, not to your onboard output)
If you have a PCI card set bios to PCI
Setting it to AGP means the computer is looking for a graphics card in you AGP-slot on you motherboard.
I cannot help thinking, that you actually have a AGP card in a AGP slot and that you computer is not working on onboard, but on AGP. But you can check which graphics device is used, in display properties (right-click Desktop, Properties, Settings)
Please post some feedback
Apr 04, 2008 | VIA P4MA Pro Motherboard
Intel Motherboard Logo
327 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
