Question about Hisense TL-3200 Television
Hisense 32 LCD tv color balance display using ariel input is poor
The color on channels via the ariel is mainly red / green , while the input from scart1 and scart2 is normal. I checked the ariel using another TV and its not the problem. Hisense manual or remote control does not seem to have a way to change the individual color channels. Does not make sense if the color balance on other inputs are fine. TV is approx 1yr old.
5 Suggested Answers
  • 224 Answers
SOURCE: INPUT GOING CRAZY
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Posted on Oct 01, 2008
SOURCE: Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
Posted on Oct 12, 2008
  • 4 Answers
SOURCE: Channel will not change
Unfortunately You need the remote! Here is a remote that will work. http://www.amazon.com/Logitech-Harmony-550-Universal-Remote/dp/B000EUGX70/ref=pd_cp_e_3?pf_rd_p=413863501&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B00093IIRA&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0ACHP3B2Z1XPGGZHPA28
Posted on Jan 04, 2009
  • 11800 Answers
SOURCE: need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Posted on Jun 04, 2011
LT32HVE only in black and white with component inputs...definitely the proper red is plugged in because we swapped it just in case and it did not change the problem. Also when trying to bring up the menu...
On component inputs the color is carried by the green connection. I would check your green cable. It also carries the video which you seem to have. Since the menu comes up black and white also does it do this in composite also? If it does it is most likely your main board. If your green blue and red cables are ok and you still have black and white it is also most likely your main board. Component uses digital portion of main board. Composite does not
Oct 22, 2010 | Olevia LT32HVE 32 in. LCD Television
I have a Insignia 32 inch LCD TV Model number NS-LCD32. It recently started displaying no inputs. The backlight comes on but no inputs/ no sound. Green lines display if you press the menu,input, channel...
The first troubleshooting step would be to measure all the voltages from the power supply to the other circuits boards specially the 5 volts going to the main board. If you have the following: Insignia 6HA0112010 Power Supply, check FU502 for open conditions.
If all the voltages appear normal, then the main board should be replace since is hard to find individual components for a component level repair.
Let me know if you need further assistance.
Aug 21, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
I have an Envision AOC 32 tv monitor and want to hook my WII up to it, It has yellow white and red wires. The back of the monitor has HMDI, PC Cable, and coax connectors. It also has speaker out puts and...
Yellow Is VIDEO, Red & White is your AUDIO. (Stereo). They should go color to color on the TV's AV input. This is AV, and you use 3 wires to connect this way.
The Red, Green, & Blue, is called COMPONENT, & is ONLY VIDEO, the AUDIO, still must use Red & White. So to connect with Component you use 5 wires, altogether, 3 for Video, 2 for Audio.
Plug them in color to color & choose the right INPUT on the TV, and turn on your input device.
Feb 26, 2010 | Envision L32W761 32 in. LCD TV
Sony Bravia 40'' LCD 240Hz TV can't get video signal from DVD
Are you absolutely sure you have it wired up right? Are the Cable RIGHT wires color to color, is the "Correct Input" selected? Remember you do NOT use "Channels" but an AV, AUX, or External.input. Most DVD etc, use AV, IE: Yellow, (Video), Red, (Audio), White (Audio) for the OUT connections. These go color to color at TV end. And uses 3 Cables. The "Other" type of Output/Input is Component Video. This is ALL Video, Red, Blue, Green, these go color to color as well. BUT you MUST also send the Sound, Via the AV, IE: The Red & White, AV, Audio IN/OUT connections, So you in this case would have 5 cables/connections in all.
Feb 13, 2010 | Televison & Video
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
Sony V lcd 32 inch losing digital channels and after doing a resetting scan it is ok for about 30 mins.... then screen image breaks up totally and message 'weak signal' shows on screen. Help,please.
You answered the question in your question.
''weak signal' means exactly that, however it can also mean the signal is too strong.
If you have a booster installed into the ariel remove it, if not, try one. Make sure the TV is directly connected to the ariel, not via a DVD recorder or any other devices which require an ariel input.
Sony tv's have very sensitive tuners installed so its just a case of making your aprticualr settings compatible.
Check signal strength over at www.digitaluk.co.uk
Thanks
Nov 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
Televison & Video Logo
75 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
