Question about Philips 170S4FB 17" LCD Monitor
Screens says aging and brightness is automaticly turned to 0
I have a phillips 190wv monitor and it says aging when there is no periphial connected or if the pc/labtop is on standby.
also when the screen is turned n the brightness display from the osd menu is displayed and also if i try and press the menu button on the screen it pops up and stays there and i cant turn bright up or make it go away unless i remove the power and turn it on again and the the brightness thing show up again ,,
so i basicly want to know if i can reset the firmware on the scren or update it or if anyone knows any solution
2 Suggested Answers
SOURCE: philips 170s6fs monitor: OSD menu blocked
.well i had the same problem but my dad fixed it.
.he opened the monitor [like unscrew it.] and just clean it. brush it. and it will work fine.
if it didnt i dont know.
Posted on Nov 14, 2010
Desktop Stand ,any ideas ?
  • You can get a universal wall mount if the stand is no longer available or you cant find one
May 10, 2014 | Philips 190WV
I have a Phillips 190wv pc monitor and I am looking for a desktop stand for same as the original broke. Any ideas ?
got wood I would just build my own...cheaper and you can customize it to your like..
How to open a phillips monitor
with a flat screwdriver inserted at the slot, there are several clips all around on the inside but do it carefully
Nov 15, 2013 | Philips 190WV
No light in Philips lcd 190WV
Has it got power? Is it turned on? Is the PC attached to it? First check all your cables & power outlet.
Feb 06, 2013 | Philips 190WV
White screen appears at start up
A laptop suffering from a blank screen can fully impede all computer productivity, but fortunately there are a number of common problems that you can swiftly troubleshoot for in your own home, even if you have no prior computer troubleshooting experience. The power adapter, monitor brightness settings, inverter cable or otherwise may all be possible causes for your screen's problems, but all can be repaired with only a Phillips screwdriver and a potential replacement screen.
Check the power adapter of the laptop and ensure that it is still properly plugged into the back of the machine. Check the monitor brightness settings for your screen. There are dedicated monitor brightness keys on the keyboard, typically located just above the numeric keys. If the brightness has accidentally been turned all the way down, this will result in a screen that appears completely dark or blank. Turn the brightness up. Open up your display to check on the backlight's functioning. Remove the screws that run around the bezel, or perimeter, of your laptop's screen. Use a Phillips screwdriver. Pull the bezel carefully off the display, starting at one corner and working around the bezel until it is completely detached. Find the inverter board, which will now be visible with the bezel removed. It lies at the bottom of the screen. A black inverter cable connects into this board via a connector that lies atop the board. This cable is instrumental to the operation of the screen's backlight, so if the cable has come loose, then the backlight will fail to function and the screen will be dark and blank. Reconnect the inverter cable into the connector by inserting it and then snapping the connector down into the flat, "locked" position, which will put it parallel to the inverter board. Consider full replacement of the screen if the inverter cable fix does not restore the screen's proper operating state. Ensure the inverter cable is disconnected, then remove the metal brackets on either side of the screen. These brackets are held in place with two screws that must be removed with your Phillips screwdriver. Pull the laptop's screen slowly up and out. Slide in the replacement screen, then restore the screen brackets and reconnect the inverter cable. Slide the bezel back into place over the display and replace the bezel screws. Hope this helps
Dec 10, 2012 | Computers & Internet
I have an philips 190WV monitor. From times to times the "brightness option shows up and changes to zero without pressing any button on the monitor. Any ideas ?
i got the same opposite problem. my contrast goes up 100 and i can't change any thing.
have you figured out your problem? if yes, how?
Sep 05, 2010 | Philips 190WV
COMPAQ 7500 monitor, MenuBar/Brightness Bar, Keys not working
replace Menu buttons (Microswitches) and check 5v path
check dry points.
Oct 11, 2008 | Compaq 7500 17" CRT Monitor
most monitors get darker with age -- for a while you can counter this by turning up the Brightness and Contrast controls, but this only gives you a little extra time (and probably speeds up the decay process anyway).
Sep 16, 2008 | LG Studioworks 563N 15" CRT Monitor
Phillips 190wv 19inch monitor keeps on flickering leavind the display not in its full glory?
look at you video output speed.
<Control panel>::<display>settings tab::advanced button::monitor tab
once there it should shown you a slow refresh rate, set higher & the 'flicker' should dissipate, you may find that you'll want to update your video adapter as well.
Jul 18, 2008 | Computers & Internet
Philips 170S4FB 17" LCD Monitor Logo
429 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
