Hello, my gas heater stops working after turning on for a while please help. Thank you, Nem
  • 182 Answers
Check your filter first
Posted on Dec 11, 2008
GE SmartWater Hot water tank. Water heater will not stop heating.
Hello Anita:
1) For gas water heater: Turn off gas to heater:
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
2) For electric water heater: Turn off circuit breaker.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#veryhot
3) For gas: Copy following link to identify gas control valve thermostat, and troubleshoot by type of gas control.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
4) For gas: Gas control valve thermostat has probably gone bad.
5) Add comment and give clear description of water heater.
6) Call plumber.
Feb 17, 2013 | Water Heaters
My fridge will only work on 220 volts but not on 12v or gas anymore. the fridge worked perfectly then the gas stopped working one day, i discovered that the gas pipped was blocked, after unblocking it the...
Your refrigerator has a freon that we call R-717 which is amonia. You have to heat the amonia to have refrigeration. using the 12 volt side will cause power drain on batteries. If you had to close the gas valve most of the way down this is telling me that he gas pressure regulator went bad. The 220 volt heater is still working that is why this is working. change the regulator and you should go back to gas for operation. If the helps give me a rating please. thank you.
Apr 08, 2011 | Refrigerators
I have a Lennox Gas Heater that will work for a while and then stop working (or fail to turn on when it cools down in the house). I changed the thermostat in the hallway about 6 months ago so I don't think...
Hi, i've found out that the flame sensor (rod that sits within the flame) is fouled with carbon on the surface. I believe this shields the rod from proper heat detection and the sensor reports that there is no flame and to shut off the gas valve to avoid explosion. Once you pull out the rod and cleaned it with a wire brush, it should fix the problem whatsoever.
Mar 05, 2011 | Heating & Cooling
Hi. I have a Cozy CDV255B wall-mount heater. The burner stopped working suddenly. The pilot is on. I jumped the two wires connected to thermostat and that did not help. Then I replaced the thermostat and...
Did someone possibly turn the control knob from ON position to the Pilot Position. If that's the case, the burner won't come on.
Another thing that might cause your problem is low gas pressure. If you have LP Gas, the regulator on the gas tank may be frozen or the tank may be almost empty.. This happens frequently when temperatures remain well below freezing. To test this theory, soak a bath towel in hot water, ring it out and quickly place it around the LP tank's regulator. This will thaw the regulator and allow gas to flow smoothly to your heater. Remove the wet towel from the regulator once it has thawed.
If the freezing continues to occur, wrap insulation around and inside the bonnet of the tank. You may also want to contact your propane provider about this. As they may need to add some ethanol to your tank.
Jan 27, 2011 | Cozy Heating & Cooling
Please help! Our draft inducer on our gas water
You are OKAY!!!
If the inducer connot run the gas valve will not turn on.
You will be fine till morning the way you are.
Just be sitting down when they tell you the price of a new inducer...
Heatman101
Jan 20, 2010 | Fasco GSW Hot Water Heater Exhaust Draft...
Gas not coming through lines on patio heater
change the turn on swich it has bad connection due to moisture and rust inside it,if my info was of any help to you please leave a comment,thank you
Sep 02, 2009 | Sport & Outdoor - Others
1998 Rockwood Tent Trailer
check connections -test and check ignition ,gas valve ,thermocouple for proper placement ,dirty or damaged
May 03, 2017 | Heating & Cooling
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
