I have a Monitor 2400 oil heater. I would like a more detailed description of all the parts for this heater. Also I would like to find a listing of the possible error (e) codes that this heater may display and the solutions. Presently I have a display of e 13.
  • markb4819 Jan 18, 2009
    Monitor 2400 quit running, displayed e14. I thought I was out of fuel so I had the tank filled. Tank was not empty, had about half a tank left. Shut off and restarted the unit several times, primeing each time. Unit ran for an hour or 2 then shut off showing e14. Tried the same thing again and the unit would try to run for less than a minute then display e13. This is only the second season for this unit to be used. Thanks for any help you can give.
  • dr80215 Feb 23, 2009
    mechaniac -
    Can you explain further. I am using the same piping that I purchased with my monitor for exahst and intake. The change is instead of going directly through a wall I am using a window kit with an extension kit, only one elbow at the unit and an elbow at the window. The size of the air intake pipe is only diminished by the minimal size of one pipe fitting into the other.
    (Your combustion air may be low, due to a wrong sized oifice in the air intake pipe.)
    How do you determine this? where is the combustion ring or burner cloth?
    (your flame pattern may be distorted due to damaged combustion ring or burner cloth. Both can cause sooting up problems.)
    Where is the flame rod and how do you remove it?
    (The flame rod has to be removed and cleaned, which is pretty simple.)
    Thanks for your help!
I cleaned the fuel screen located on the unit and replaced the filter on the external fuel tank. The external filter can freeze if it accumulates enough water and the temp is cold enough, or it can just get full of debris. I also unplugged the 2400 for 30 min to let the factory preset settings come back. Filter(s) caused the e14 error, preset settings cured the e13 error caused by me fooling with the start stop function so much. Thanks for the help!
Posted on Jan 26, 2009
I've been researching the same problems with my 2400. Your combustion air may be low, due to a wrong sized oifice in the air intake pipe. Or, your flame pattern may be distorted due to damaged combustion ring or burner cloth. Both can cause sooting up problems. The flame rod has to be removed and cleaned, which is pretty simple. Running the heater on high a couiple of times a week may help keep it clean, I am told. I set my timers to run the heater on high for 30 minutes a couple of times a week. So far, so good.
Posted on Jan 24, 2009
Monitor 2400. Where can we get a parts list and related assembly diagram?
sad but when the manufacturer is out of business there are no parts , lists or otherwise .total replacement is the only option .
Oct 20, 2015 | Heating & Cooling
Repair manual for a Monitor 2400 kerosene heater system
I just bought a use Monitor 2400,it will run and then start to beep,has E 14 on it, What does that mean? Don't have the manual for it.
Feb 02, 2012 | Heating & Cooling
I need ignitors for heater model number 3e219e
The part number for the ignitor kit is PP200 (new number) Old number was PN HA 1000.
Also from the parts list, this PN: 102548-03
Parts list:
http://www.bealsmotor.com/105553_219E.html
Burner head parts: (Ignitor is item 5)
http://www.bealsmotor.com/105553_burner.html
Actual Ignitor Kit:
http://www.amazon.com/Desa-International-Hot-Surface-Ignitor/dp/B000DZDPVI $39.95 + shipping
Downloadable manual: http://www.desatech.com/manuals/Construction%20Heaters/105553-01.pdf
Dayton Portable
Oil-Fired Heaters
PARTS:
Ph. 1-800-323-0620
24 hrs / 365 days a year
105553
2E510F, 2E511F, 3E218E, 3E219E
Please provide following information:
-Model number
-Serial number (if any)
-Part description and number as shown in parts list
102548-03 (part you need)
Thanks for choosing FixYa,
Kelly
Nov 19, 2010 | Dayton Heating & Cooling
Service, 2006 toyota corolla 80,000km
You need to get the Haynes repair manual on your vehicle. It will show you all of these things and how to properly do the jobs as well as when to do the changes.
Jul 30, 2010 | 2006 Toyota Corolla
I'm getting an "E 13" code on my Monitor 2400; what does that mean? I don't have a manual to tell me.
E 13 means ignition failure. You can see a list of error codes at www.monitorproducts.com. What happens when you try to light the heater? You can contact me at nitensheaterservice@embarqmail.com.
Jan 06, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
We have a monitor 2400 kerosene heater, it will start up and after a few minutes at most it shuts down and starts beeping and many times has a message "error 13"
Next time you try to start the unit listen to the pump on the lower right side of the unit. Just before the E13 message if you hear a thumping noise, you have a fuel problem. If you don't hear a thumping and there is a flame you have a problem with the inside of the burner. I would say since it's a 2400 you have a fuel problem. Low fuel, no fuel, dirty filter or blocked flue pipe.
Tom Hawkins
hawkins111@gci.net
Jan 19, 2009 | Heating & Cooling
Monitor 2400 heater will shut down when I run My generator
A UPS unit might work. Electronics need steady clean power.
Dec 18, 2008 | Intel CASE 350W PWRS ALLIED W/ 24PIN +...
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Defective plug Honeywell HZ 680C
Question:
*All Heaters*-Where can I get parts for my heater? Answer: Unfortunately, we do not have any replacement parts available online for heaters. You can obtain parts by calling consumer relations at 800-332-1110. The only parts currently available are replacement wheels for oil filled heaters. If you are looking for any other parts, please call us or send an email to ConsumerRelations@kaz.com and let us know the model number of the heater, the length of time you have owned it for, and a detailed description of what is wrong with it.   Question: All Heaters-Can I use an extension cord with my heater? Answer: You should avoid the use of an extension cord as it may overheat. However, if you have to use an extension cord , be sure it is a polarized cord of 14 AWG minimum and rated no less than 1875 watts.
http://www.kaz.com/kaz/support/FAQ/?ProductCategoryFAQAction=renderProductCategoryFAQList&ProductCategoryId=1bc8ee52577f77289f9a193ce1ba3ee3
 I could find no recall on you product. They do not supply parts. I am sure you can match up the plug and cord at any good hardware or appliance parts store. Are you sure it is the cord?  The element could be shorted out.
DO you have an ohm, meter or small batter light tester to tes t the cord and eliments with?
Dec 06, 2007 | Honeywell HZ780 Oil Filled Radiator Heater
Heating & Cooling Logo
2,300 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
