Question about Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System
Sony Bravia DAV-HDX275 installation question
I have a Sony Bravia TV and bought this particular sound system so it would match and hopefully be easy to hook up. I was wrong. I am getting crystal clear sound from the subwoofer and the left and right speakers, but the center speaker and both surround speakers that go to the back of room don't make a sound. I did the initial quick setup and all the speakers worked so I must have something hooked up wrong. Also in order for the speakers that do work to mahe noise I have to turn the TV volume up as well as the surround sound volume. If anyone can help me I would be more than appreciative!!!!!
  • 492 Answers
Sony DAV HDX275 manual
You may download the manual and more from Sony BRAVIA Theater System
Oct 07, 2010 | Audio Players & Recorders
I have a Sony DAV-HDX275 Theater System that I'm trying to connect to an old 17 LCD Dell Monitor. The cable I have is a HDMI to DVI connector. My monitor will pick to the digital signal but nothing appears...
This is because it is transmitting an compressed encrypted signal and the monitor is made to recieve uncompressed signals,You can sometime get around this by changing the output to vga or analog on the theater system.
Aug 25, 2010 | Sony BRAVIA DAVHDX275 Theater System
How to connect the bravia, ps3, and dav-hdx275
i reccomend buying an amp (Reciever) . and hook everything you have up to it . i suggest a big amp. the bigger the more you can run through..
Mar 25, 2009 | Sony Audio Players & Recorders
Can't get XBOX 360 to have audio through surround sound speaker
Make sure that you have the RC Cables (red and white) plugged into the audio ports that coincides with the component video inputs. If that wont work then try plugging the audio and video cables into the inputs for the satellite, since that works. That way you can isolate the issue. If it still wont work try using the XBOX 360 HDMI cable. That has both audio and video.
Jan 03, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
Nov 05, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
No sound when trying to connect PS3 to DAV-HDX275
It's likely the sound settings on one or more of your items are not set right or switched off.
Oct 16, 2017 | Sony BRAVIA DAV-HDX267W Theater System...
Codes for DAV-HDX275 BRAVIA
Amigo conseguiste resposta para trocar a regiao do home theather de 1 para 4? No aguardo, em.maciel@ibest.com.br
Aug 11, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony Trinirton TV and DAV-HDX 275 System
Here are a couple of the most common reasons for your problem:
Make sure you have selected the right input source on the DAV-HDX275 that your TV station source (cable, satellite, direct TV or whatever you get TV stations from) is connected to on the DAV-HDX275.
Also make sure that if you are using a digital input (HDMI, optical, or coaxial) from the TV station source, that the DAV-HDX275 in set for a digital input and on the right source.
If you are using an analog source (red and white RCA jacks) for the TV stations , make sure you do not have the digital input activated for that source on the DAV-HD275. You need to select the analog option.
You must also be sure that you have a cable, whether it is analog or digital, connected from the cable box to the DAV-HD275.
I hope this was helpful to you, it is always very important to double check all the connections and make sure the stereo is set to the right type of input (digital or analog).
If you have found this to be helpful, a good rating is always appreciated. Thanks and let me know if you need any more help.
Jun 22, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System Logo
289 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
