Question about Olevia LT42HVi 42 in. LCD Television
Olevia 1080i My 1080i is showing 480p. How do I change this? It can't be right... when I press display it says 480p. Ive read the manual, reset to factory settings, everything to no avail.
  • Bill oz Mar 29, 2009
    the OSD nor the remote will allow me to change from 480
How do you you enlarge the picture to show on a full screen, and not black on the sides?
Posted on Jan 06, 2009
Front panel switches and inputs disabled
Yes it is, it is, after all it is an input. Here is the owner's manual that should tell you how to reset:
tv.manualsonline.com/manuals/mfg/olevia/olevia_flat_panel_telev
Jan 13, 2013 | Olevia 32" 232v 1080i widescreen lcd hdtv...
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
My Viewsonic N3751W 37-Inch LCD HDTV always shows 480p
your dvd is set to 480p. if it is a convertable dvd player set it to 1080i. the tv sets itsef to whatever the dvd player displays. if not all dvd is 480 to 720 p. blu ray will get you top notch 1080 display.
Jul 07, 2009 | ViewSonic N3752w 37 in. LCD TV
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
How to change from 480i to 1080i
The TV has a automatic scalier chip installed so it depends on the input signal that you are using. For example you are using a HDMI connection with a xbox 360 and you set the display setting to 720P then the TV will display it in 720P. If you set it to 480P then it will display it in 480P.
Apr 01, 2009 | ViewSonic N2635w 26 in. LCD Television
Sound Noise Using HDMI Cable
The first solution was to use the remote controls on the recorders and shuttle from 480p to 720p to 1080i.
The other solution was to run left and right audio cables from the output of the DVD recorder to the audio inputs of the tv. Then, go into the setup menu of the recorder and tell it not to output sound using the HDMI cable.
The first solution has to be done each time the machines are turned on for the first times of a day.
The second solution fixes the problem once and for all....
Feb 17, 2009 | Olevia LT32HVM 32 in. LCD Television
Blurry Text
you'll im afraid have to go the newer tv. the older models dont have the capacity to keep up with the high def out put of a ps3. id personally recommend a bravia, or vivo as i have not had a problem with either, since ive worked 9and played0 with them. please leave rating
Dec 08, 2008 | Sony Playstation 3 (PS3) Console
HD WONT WORK ON MY PS3!!!
Hi
Try This links and follow the instructions! CLICK HERE
Thanks!!
Nov 12, 2008 | Philips 27PT8302 27" TV
HD tv with the mitsu
Well if your refering to the right tv (check your model number) then this tv only supports 480i, 480p and 1080i. Ive never seen anywhere that it supports 720i.
The component wires should include three lines for each corresponding color, red green and blue, and finally white and red for left and right audio. I think that is what your refering to.
If everything is right, it should work, the fact your seeing green could be a number of issues... maybe its a direct tv box issue?
Apr 03, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Pink HDTV screen PS3
check that you have all avalubal resulutions sulected in your displt settings i.e. 480p 720p 1080i and 1080p all the ones your tv will support my ps3 was doing the same thing untell i checked 480p as well as 720p and 1080i now when I play a dvd my tv swiches to 480p and the dvd will play.
Dec 30, 2007 | Sony Playstation 3 (PS3) Console
Olevia LT42HVi 42 in. LCD Television Logo
266 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
