Question about HP Photosmart C3180 All-In-One InkJet Printer
C3180 HP Out of Paper cleaned machine, the cartridges, power off/on, restarted the computer, cleaned rollers HELP
  • 53 Answers
Give it a shake.  There is a little switch that detects when there is / isn't any paper in the printer. It may be stuck.
Posted on Dec 10, 2008
Hp photosmart c3180 will not feed paper to print
Might be paper pick up roller warn out, clean or replace it.. For tech guys only: check for separation pad acting while service station performing? if not remove service station check separation pad leaver notch not in proper position in service station, position it. remove total mechanism up to pick up assm.. check pick up roller spring.. tension the spring. fix it back.. verify the print ...
Jan 09, 2012 | HP Photosmart C3180 All-In-One InkJet...
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
I need to know HOW to clean the rollers. Do I have to take the machine apart?
This link's Solution two: Clean the rollers; shows you how:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00652863&lc=en&dlc=en&cc=us&product=1146331&rule=13638&lang=en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 19, 2009 | HP Photosmart C3180 All-In-One InkJet...
The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Problems with the hp c3180 all-in-one printer
Did you clean the contacts inside the printer as well as the ink might be built up where cartridge contacts touch the printer contacts in the housing. You have to be quite careful here as there is a small metal spike which grips the printer and you do not want to push this into the contacts in the housing. Just get some damp tissue and rub it over these contacts to clean up any residual ink( turn off the printer first)
Fred
Jun 14, 2008 | HP Photosmart C3180 All-In-One InkJet...
Paper Jam!!!
hi,
try this...
> unplug the power chord from the printer.
> open the rear access door.
> you will get full access to the rollers.
> remove the jammed paper gently.
> clean the rollers using a lint free cloth.
> close the rear access door.
> try to make a copy.
thats it.... if still u have the problem... contact me
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart C3180 All-In-One InkJet...
Hp 4l will not print
just a silly question I take it you have removed the tape from the toner cartridge. Well do have to make sure of these things. It is possible that the transfer roller has come out of position to check it should be a black roller that sits under the toner cartridge when install. The roller is in the machine at all times. The other thing are you using HP originals cartridges as this could be a factor.
Hope this is some sort of help
please rate me
Cheers
J
Dec 31, 2007 | HP LaserJet 4L Printer
HP c3180 inkjet printer problem
apply two or three drops of 3 in 1 oil to top of the big silver rod (inside printer cover)on which the ink cartridges ride.
UNPLUG RESTART AND Print
Dec 25, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP C3180 all in one printer won't realign
We've encountered several problem like this. Hope this gives an idea; I understand the cartridge will not moved back to park tray or flash ink tray back and forth because the return pick-up guide were not properly placed into each original position. It will block the ink tray moving back and forth. You can roll back the roller into the original place by removing the back cover if it has, then turn the pick-up roller slowly allowing the roller to turn and backed to its original position. Removed also remains of jammed paper pieces.
Best regards,
Rosener Guyano
Nov 29, 2007 | HP Photosmart C3180 All-In-One InkJet...
TRACTION PROBLEM
The cam that keep the pressure between the roller pick up and the lower feed is the solution
Oct 22, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
76 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
