Question about Kenmore 43142 Front Load Washer
Washer Walk I have a HE2 plus washer that has moved around during the spin cycle from day one, the washer is level and on a solid tile surface. It is mounted on a 15" pedestal, could this be my problem?
  • jaydocheff Dec 11, 2008
    The pedestal is a Kenmore made for this machine.
    Genius:
  • 1,199 Answers
No it sounds like the belt that drives the washing barrel has come off its alinment track or has broken!
Posted on Dec 11, 2008
    Genius:
  • 1,550 Answers
Yes your correct you need to place your washer on proper stand .
  • SAM ANDERSON Dec 11, 2008
    Too much vibrations during spin cycle causes this kind of problem . Just unmount from the pedestal and check whether it works properly .
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Spinning cycles on my Kenmore HE2 plus shaking so hard it's breaking my washer apart. . Help?
An answer from this Sears appliance expert emphasizes all four feet must make solid contact with the ground and only then worry about leveling. Good luck.
If problem persists, Sears offers a free online expert capability to help you diagnose a solution.
my he2 plus automatic front loading kenmore washer has been leveled has...
Dec 02, 2014 | Washing Machines
How do I balance a Kenmore HE2 Front Load Washer.
You need to level the washer. They also have things to put under the feet to keep it from moving. Or try to block the feet.
Jul 05, 2014 | Kenmore HE2 Plus Front Load Washer
Spin cycle shakes whole washing machine
have you tightened the jamb nuts on the legs after leveling the machine so they can't move from where you set them initially when you leveled the unit?
Mar 21, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 washer shakes violently
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2009 | Kenmore HE2 Plus Front Load Washer
Why does my EPIC z walks during spin cycle even after I used the rubber pads? It moves from the right back corner out to the left.
Make sure that the leveling feet are secure with the jamb nut tight against the BODY of the washer. If not, the washer could walk during spin. Make sure that washer is flat level front to back and side to side with a 24" level. Just set the level on the top near the front and then on both sides as well. Adjust the feet and jamb nuts so that they are as low as possible. If washer is on a stand, remove drawer to adjust feet. Also, if on stands, washer will vibrate more due to increased height and natural flexion of stand. What kind of flooring? If ceramic tile, rubber feet may not couple to surface and provide enough friction to stay in place. I have had success with......I know it might sound stupid.....but buy a couple rubber jar opener pads and cut them into small pads. Put them under the rubber feet of stand or washer. These seem to make a better connection to the floor.
Aug 01, 2009 | Washing Machines
The washer bounces during spin cycle
Front loaders don't like small loads. There's not enough clothing to settle around to balance it. Only do large loads.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
Major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Apr 13, 2009 | Maytag Neptune MAH6700A Front Load Washer
Frontload washing machine makes noise during spin cycle
call sears 1 800 4myhome they can walk you thru some troubleshooting. First thing pull back the rubber ring between door and barrel to see if anything like pens etc feel into the gap underneath. If not call for troubleshooting. Get a plan with sears then wait 30 days and call in the problem. Fix will cost less.
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 43142 Front Load Washer Logo
15 people viewed this question
Sal De
fordexpert
Robert Rankin
