Question about Whirlpool Washing Machines
Need to find a store to find parts for my washer Model 6LSP8255BQ3
  • 370 Answers
Go to sears.com and then to the parts section. Then type in your model # and you can get any part for your washer.
Posted on Dec 10, 2008
I have a model 51012 washer..I need replacement nozzles. where can I get them? thanks.
Go to their website and check out support. Some outfits will only sell parts thru their "authorized" dealers.
Jul 19, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
O Ring in pressure washer MOdel FH 140 a Keep blowing out In the wand handle need to order parts. Thanks
These are generally the same sizes for most pressure washers, except for small light duty ones. You can generally buy a set for around $6 try a pressure washer store or Home depot or Northern
Jun 09, 2011 | Garden
Water was seeping thru the front opening while weasher was not in use. not an external leak. turned off both water suppiles and the water leak stopped. siounds to me like an internal valve leak
you need to change out the water valve on the washer.open the door and look for the model number.call your parts store and give them the full model number off of the washer,look around the opening on the frame where the door closes into and they will sell you the correct part
Feb 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What type of washer fluid do I need for a toyota corolla 2000 model, and where can I purchase one?
Washer fluid is washer fluid, so any brand will work. Washer fluid can be purchased at any auto parts store, there are lots of them, Kragen, Autozone, Sears has it as well as any Hardware store like ACE or Orchard.
Jan 27, 2011 | Toyota Corolla Cars & Trucks
The washer will run but won't drain or rinse
it has a bad lid switch... its a 20 dollar part at your local appliance parts store...take the model and serial number down and call the parts store ask them for a lid switch for your model...if you need help installing the part you can call me at (925)470-5975 my name is kelles
Oct 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer wont drain or spin
it has a bad lid switch.....a 20 dollar part from your local appliance parts dealer take the model and serial down and call the parts store ask for a lid switch for your model
Oct 25, 2010 | Kenmore 23822 Top Load Washer
Need part number for craftsmanriding mower drive belt model 917255277
Go to Searspartsdirect.com and enter the full Sears model number (minus the decimal point). That will take you to a series of parts drawings, and part numbers of all available parts. You can also order parts through them. Some things are better bought in a hardware store as their nuts, bolts, and washers are outrageously expensive. Other parts seem fairly reasonable. Hope this helps!
May 18, 2010 | Garden
The seal behind the door tore and water is everywherE!!!!!!!!!!! cAN'T FIND A REPLACEMENT PART ANYWHERE!!!!!!!!!!!!!!
If you need to replace the door bellow (gray rubber seal), the following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. If the model number you have this question listed under is correct, the part number you need is 8182119. The bellow is listed as item 5 under the "Door and Latch Parts" section.
NOTE: Although the bellow DOES wear out with age and can develop holes, overloading the washer can contribute to the premature wear and tear on these seals. Please follow your owner's manual recommended loading procedures.
If you have any questions about this repair, or need additional assistance, please post and let me know. I hope this helps you.
Mar 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
TOP AGITATOR NEEDS TIGHTENING
You need to get an agitator repair kit from the appliance parts store. Number ap3138838 This has a new thurst washer that will fix the loose upper agitator. Remave cap under fabric dispenser, it pulls up and you will see bolt. This kit also has cam parts to repair the worn ones on upper agitator too. Take model number to the store with you.
Jun 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Washer timer dial is not advancing
ok " timer has a small stepper motor in it, and it can be replaced
take stepper motor out .
appliance parts store will have it
or just replace timer
take make and model number with you
Jan 13, 2008 | Washing Machines
Washing Machines Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal De
