Question about Fahrenheat Built-In Baseboard Thermostat Heater
Do the Fahrenheat Hydronic Baseboard heaters work well?
I am thinking of having installed a 90'' inch hydronic BB heater - does the tube that heats the water inside really work well and does this model throw off a lot of heat?  Are there other brands you would reccomend?
  • bessbrodsky Dec 10, 2008
    I do need to have a baseboard heater in this location. Are there other models you would reccomend?
  • Sean Lavelle
    Sean Lavelle May 11, 2010
    Is this a plug in (electric) hydronic bb heater? if so the wattage will tell you how much heat it puts off.
    A standard 72" electric BB puts out about 1500 watts.
    Another type of better heater might be Comfort Cove radiant heater (a BB heater that mounts on high on wall and "shines" heat down).
    These are hard wired like electric BB heaters and very efficient.
    Genius:
  • 1,199 Answers
No i would not recomend this model ! if you can stay away from baseboard heat alltogether it is an energy waster!,somthing that moves the air would be a much better choise
Posted on Dec 10, 2008
How do I wire 2 Hydronic 1500W 240V heaters together?
Please follow the attached wiring diagram on page four on the web link below.
Hope this helped you....Jim...Please leave a positive comment if it helps you with your project.
http://www.thermalinc.com/comfort/PDFs/LF_instructions.pdf
Feb 14, 2011 | Fahrenheat Electric Hydronic Baseboard...
We are enclosing a porch and would like to hard wire Marley baseboard heat. Found that Marley is going out of business and have been advised to buy P C. Do you have any thoughts on this. WE thought that...
that is up to u only problem is after they go out of business u wont be able to get parts so dont be surprised if u have to replace it after a while good point is most parts are universal and u can get some parts for it so i think u will be fine
Feb 23, 2010 | Fahrenheat Electric Hydronic Baseboard...
I'm replacing a non-hydronic electric baseboard heating unit with a Fahrenheat hydronic one. My old unit was 240v using 2 conductors plus bare ground wire. The fahrenheat (PLF series) unit's instructions...
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Jan 06, 2010 | Fahrenheat Electric Hydronic Baseboard...
IS A HYDRONIC ELECTRIC BASEBOARD MORE EFFICENT THEN THE STANDARD ELECTRIC BASEBOARD HEATER
I have some confusion about what you are asking......
There is no such thing as "Hydronic Electric Baseboards"......
I am assuming you are referring to the oil filled baseboard heaters. If so....
The same amount of btu's required to heat a space remain the same whether the elements heat a liquid to warm the air or whether they heat the air directly, the same amount of wattage will be consumed. So, their is no more or less efficiency between the two.
If you are referring to "Hydronic Baseboard Heaters" (these baseboards are fed from a boiler with a pump) Then....I will assume that it is a gas boiler. In which case, the gas boiler would be more cost efficient to operate. If it is an electric the same rule applies as above......the cost is the same.
Oct 04, 2009 | Fahrenheat FBE15002 Baseboard Heater
BASEBOARD HEATER NOISE
HOW ABOUT THE MARTIN HEATERS I LIKE THEM BUT DONT USE THEM THAT HIGH
Dec 04, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Built-In Baseboard Thermostat Heater Logo
1,358 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
