Question about HP Compaq Presario SR2011WM PC Desktop
When I try to turn on my computer the monitor reads: VGA input: no input signal
  • pandababe124 Dec 20, 2008
    I have an Compaq Presario sr2011wm PC Desktop.
    It just says No Input Signal. I've checked for ben pins and plugged the same monitor into another computer and it works just fine, so its not the monitor. I've turned the computer on and off and unplugged it and plugged it back in. I don't know what else to do. Help...
  • Anonymous Jan 16, 2009
    same problem after upgrading ram. please help
    Sergeant:
  • 324 Answers
The monitor is telling you that it does not see the computer. First, remove the monitor cable from the back of the computer, check for bent pins on the connector and replug in the connector.
If that doesn't work, try swapping to a different monitor to see if it sees the system. If this works, you have a bad monitor or monitor cable.
If that doesn't work, open up the computer remove the video card, clean any dust from around the card and socket and replug the video card.
If these ideas don't work,get back to me and we'll go from there.
Have a good day!
Ron
Posted on Dec 10, 2008
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
I loaded Windows 7 and now when I turn on the computer, the monitor says DVI input no input signal and goes to sleep. Can you help?
Do you have the correct driver loaded? Are you using DVI output on the computer? Is there a VGA output? If so, try using a VGA cable while you troubleshoot the video issue.
May 11, 2011 | HP w2207 Monitor
I have a Samsung SensR470 laptop and i have linked up the VGA, audio, and power cables but the monitor is not showing anything. when i turn it on, it just goes into sleep mode or otherwise shows the...
its because you failed to read the Samsung manual on your PC
go there and read, it has HOT key , all laptops have a hot key
Fn key that turns on the external display VGA jack.
on rear of this SAMSUNG.
SLEEP MEANS THE PC IS NOT SENDING THE HORZ AND VERTICAL, SYNC SIGNALS. AT ALL.
THAT MEANS WHAT>?
It means the PC, VGA jack is turned off.
bad cable
bad monitor.
The PC can also be bad VGA chips, or worse,.
your first failing here is not saying why you are using VGA jack
is the Laptop screen dead too> (my other shoe falls off)
dang that be nice to know , no?
or like we do run that VGA to a projector? for say doing power point presentations, (done many before retired)
RTM, the manual is free to read any time of day, 24/7
each PC maker uses there own rules here, its there call
there design and their rules.
my HP its, Fn+F4, (toggle:, internal, external ,both or auto)
but yours is Samsung, ask them. or learn to use google?
Jun 10, 2017 | HP w1907 LCD Monitor
My dell inspiron 530 shows a block with red, white, green, and read, can't get to the my programs????
That "red white green and blue" block is a color pattern tester. that means the monitor is on, but is not receiving a signal, so its running tests. If your monitor has Digital input and VGA input, you may just need to switch inputs. Look for 1 or VGA if youre using the blue hook up. look for 2 or digital or dvi if youre using the larger white hook up. Some monitors also have 'auto detect'. If you are in "auto detect' bbut the color box is still there, then your monitor is not receiving video signal from the computer. It could indicate a bad cable or no signal being sent by the machine. If you try another monitor, you can see if the machine is working. I would try a monitor setting for VGA-1 first, since thats most common.
Jun 25, 2010 | Dell Inspiron 530 Desktop Computer
When I turn on the computer and the monitor, the monitor does not recognize a signal from the computer. I have tried restarting the monitor and the computer, unplugging all cables including the power...
kkjsr00, You must narrow down the faulty component!!! You must prove what is working and what is not working!! Beg, borrow, steal a "known-good" monitor to prove your pc is operating perfectly and will display the WIN-desktop screen on it. If your pc is A-ok then visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ kkjsr00, when strange and weird stuff starts to appear on the screen of "cold-cathode-fluorescent-lamp" back-lit lcd displays the first place I would look at would be the units internal "switch-mode-power-supply/ccfl inverter supply".. No, No, No, unit not going to sleep!!! SMPS/inverter going into SHUTDOWN mode having detected a fault condition with itself or other circuit and is trying to save itself from catastrophic, nonrecoverable failure. e.g. smoke, fire, burn down house, etc. Do some reading in my profile and those of other fixya tech's and you will find more than enough info to help with your problem. Good luck with repair of "flakey" solder joint or bad electrolytic filter capacitor PLAGUE problem. Yes, you sure have a lot of reading to do!! 12fixlouie or old file is louie12fix also try "buddymc" , "budmrtn" profiles for more info.
Apr 26, 2010 | HP w2207 Monitor
HP Compaq Presario SR2011WM PC Desktop Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
