Question about Singer 5050 Mechanical Sewing Machine
I have a Singer 5050. I got material jammed and once I got it out the bobbin thread will not catch on the sewing thread. I'm wondering what I could have broken. I love that machine and would like to get it reapired instead of buying a new one. Help!!
Had machine serviced.
Posted on Dec 11, 2008
SINGER CURVY: It jammed while sewing felt. Taking apart the bobbin area, I can see that the needle hits the bottom of the "floor". The bobbin is not catching or moving.
I think that your should try a new needle, it may be bent or have burr on it. It problem persists call Singer at 1-800-4singer, good luck
Sep 12, 2010 | Singer Curvy 8770 Electronic Sewing...
I have a singer 5050 how much tension do I need for sewing as the thread keeps breaking when sewing
Top tension about 4 or 5, use a good mercerised thread only, make sure you do not have the bobbin tesnion too tight, slacken the screw anti clockwise on the bobbin case if it is
Jun 24, 2010 | Singer 5050 Mechanical Sewing Machine
Singer 5430C bobbins thread always loopy
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Feb 15, 2010 | Singer 5050 Mechanical Sewing Machine
I purchased singer bobbins to use in my singer 5050. I thread the machine and bobbin per manual instructions, but when sewing, the thread severely bunchens and knots up on the bottom side of the item I'm...
Sep 30, 2009 | Singer 5050 Mechanical Sewing Machine
Bobbin thread will not catch
This is really one for an engineer. It involves loosening the bobbin race and moving it slightly till the hook catches the thread,and then retightening. Can be an awkward job requiring 3 hands,even for an expert!
Feb 13, 2009 | Singer 5050 Mechanical Sewing Machine
Asinger model 5050 will not make stitches,checked all points,
your machine sound like it is out of time you need to take it to a service center
Jan 15, 2009 | Singer 5050 Mechanical Sewing Machine
Thread jamming at bobbin
Check to be sure the thread is not catching on the bottom of the bobbin. If it is, replace the bobbin because it is sprung. If it is not catching there, then you need to check your tension to see that it is working properly. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}. Pull the thread through the tension assemblyand test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.) If it doesn't do this, you need to remove the thread or lint that is stuck between the tension discs. Open them with a small screwdriver and clean them out.
If this doesn't solve your problem, remove the bobbin case and check the hook for rough spots.. If you find some, buff with an emery stick until smooth.
sewman7
Oct 03, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
66 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
