My pioneer turntable pl 233 not been used for years. Despite new belt, keeps slowing on playback. Does it need motor lubricant?
  • evadm Dec 17, 2008
    Many thanks. When I saw the bearing was not dry, I didn't think it would work, but it sure did!
    Scholar:
  • 142 Answers
Hello, You need to remove the platter\ remove the old bearing grease\ re-lube platter bearing with new 30w motor oil. Good luck
Posted on Dec 11, 2008
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
It needs a new belt
http://www.turntableneedles.com/Flat-Belt-Medium-236-Inch_p_255.html
Pioneer PL-990 is listed as a compatible player for this belt.
Apr 07, 2011 | Pioneer PL-990 Turntable
How can iget the belt back on my turntable pioneer pl 990
PUT IT ROUND THE PLATTER BASE FIRST,THEN LOOP A BIT OF STRING ROUND THE BELT LONG ENOUGH, SO WHEN YOU PUT THE PLATTER BACK ON,YOU CAN LIFT IT UP A LITTLE BIT WHERE THE MOTOR WHEEL IS THAT TURNS THE BELT, PULL THE STRING TOWARDS IT SO THE BELT GOES OVER IT.DROP THE PLATTER THEN PULL THE STRING OUT.
Mar 31, 2011 | Pioneer PL-990 Turntable
My Pioneer PL-112D turntable has a broken drivebelt, is it possible to buy a new one, and is there a diagram showing the belt "routing". Thanks.
I don't believe this belt is being provided by the Pioneer. So I did find another option at a reasonable price on E-bay.
http://cgi.ebay.com.sg/TURNTABLE-DRIVE-BELT-FITS-PIONEER-PL-12D-PL-112D-/290432607483
Jan 17, 2011 | Pioneer Audio Players & Recorders
PL-L50 Pioneer direct drive turntable playing records as if it had a bad belt speed variations in playback, but direct drive has no belts of course. What could be making my records playback speed...
If there is a speed adjustment for 45 and 33 rpm records the contacts or pots need to be sprayed with some electronic cleaner to remove any dust. This is done by removing the bottom of the player and finding the control knobs inside. Electronic cleaner can be found at Radio Shack for around $10 for a large can. It does not take much. Just spay inside the control knobs inside the unit. You will find a small hole where you can put the spray tube that comes with the cleaner. Work the "pots" or knobs back and forth several times to loosen any residue inside the knob casing. Be careful not to shock yourself by removing the bottom. If you are not use to working on electronics it may be better to let someone else with more knowledge tackle the job.
Dec 02, 2010 | Pioneer Audio Players & Recorders
Motor turns feebly, not enough to make the platter
Sounds like the motor is bad if you say it turns feebly. See if you can turn the drive shaft with your fingers easily. If you find it hard, it's possible that something might have worn out. You could try oil in that case.
Feb 02, 2010 | Pioneer PL-990 Turntable
My pioneer PL990 turntable, the pitch wavers.
try cleaning the inner ring on the underside of the actual turntable platter and also the motor spindle using isoprynol alcohol or use neat clear spirits like bacardi/vodka with cotton wool etc. if black residue comes off either the platter or the motor spindle that will be residue from the old belt that could cause the fluctuation in speed? good luck.
Jul 10, 2009 | Pioneer PL-990 Turntable
I need to reattach the belt under the table
Download the manual free at http://www.nodevice.com/user_manual/pioneer/other_home_component/pl-990.html
There are instructions there and pictures showing how to attach the belt.
May 21, 2009 | Pioneer PL-990 Turntable
Pioneer pl 990
Remove any tape from the belt
That is the drive belt for the turntable .
It's not that hard to set up. Take the mat off the platter and wrap the belt around the underneath -slightly-less-diameter portion.
With a pointed end needle or something like it , put the tip between the belt and the platter portion it's wrapped against.
Pull the belt away from that( keeping the rest of the belt on the platter portion) and set it over the motor pulley. This is usually a small diameter brass spindle unit
Mar 27, 2008 | Pioneer PL-990 Turntable
Belt off
Lift the platter. PLace the belt under the platter on the inside ring. PLace it back on the turntable, and you can stretch it back onto the motor with your finger or black stick through one of the holes on the platter, while the platter is positioned where it is accessible. if you need a replacement, try...
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES-Drive_Belts/c271_272_278_398/index.html
the technics belt #2 seems to be universal. The staff there is top notch and can get you the correct belt. Call them with your model.
Keep me posted.
Nov 03, 2007 | Pioneer PL-990 Turntable
127 people viewed this question
 Grubhead
Grubhead
