Question about SEH Computertechnik IC107-FAST-EPSON-TX (4037863030109) Print Server
How do i open a IC107 phone jack - SEH Computertechnik IC107-FAST-EPSON-TX (4037863030109) Print Server
Connecting the majic jack go phone to my closed caption phone.
Make sure both jacks are connected together.Some are not. Open all the wall jacks in the home to insure they pass the red and green wires on to the next jack. Connect any that are not, color for color. When all the jacks look like the wiring is OK then try the CC phone again.
Jul 28, 2016 | Televison & Video
All of the lines are steady red, which means the line is in use by another set. However, no other phone is using those lines. Can you shed some light on what I need to do.
You need to find where your phone line has a problem. This could be a sign of a wiring problem inside or outside or a problem with the phone itself. First try another phone at the current jack (I prefer to use an old corded phone with a different phone wire). Since this is a 4-line phone, you will need to check each line separately. Check for dial tone. If the test phone works, try the second wire with the ATT-974. If it still doesn't work, replace the phone. Modern phones aren't meant to be user fixable. If neither phone works, continue below.
Next try both phones at a different jack. If the phones both work and the jack is for the same line as one of the lines to the first jack, then you probably have a wiring problem at the jack or leading to the jack for all of the lines. You can open the faceplate and check for loose wires. If it is the wires to the jacks, you may want a professional to deal with the issue.
If you get the in use message at other jacks on both phones, find where the telephone service comes in. If you are lucky, that will terminate in RJ-11 jacks. Then open the service box and use your test phone there. If the problem occurs at the service box, call your phone company. They should fix it for you. If the dial tone is normal, it's an inside wiring problem. The phone company will fix it for a fee. (If the service uses a non-RJ11 jack, you should have the phone company do this test.)
I hope this helps.
(who has gotten a line in use error when mice chew on the wires or a crew dug too deep near the underground wires. Sometimes we'll hear a fast busy signal when the handset is picked up with the problem. Although with 2 line service, only the digging humans usually cause a problem with both lines. Animals only damage on line at a time outside.)
Apr 18, 2011 | AT&T ATT-974 Corded Phone
How to remove an email account from a samsung jack cellphone?
  1. Open Messaging and click Menu > Options.
  2. Under the Accounts tab, check "Display account picker when opening Messaging"
  3. Close Messaging and re-open.
  4. Select the outlook account using the d-pad and click Menu > Delete.
Nov 13, 2010 | Samsung Jack Cell Phone
Everything works, but i HAVE NO DIAl tone
Does another phone work at that jack? Try a different phone cord (RJ-11). I like to use a simple older phone for testing. Do any of the other jacks work?
Find where your telephone service comes in and open the box. If you are lucky, you will find RJ-11 jacks in the box. Test for dial tone there. If there is no dial tone, contact your provider and have them fix the line. (If the service box doesn't have an RJ-11 plug, you will need the provider to test the incoming phone line.)
If the problem is only at the one jack, open up the outlet box and check for loose or broken wires. Some use a screw connection; others use a keystone jack (which requires a special tool to press the wires into the connection). For the screw type, you strip the insulation on the individual strands. The keystone has teeth to penetrate the insulation so don't strip it back. http://www.lanshack.com/wire_phone_jack.aspx shows how the jack should be wired.
If none of the inside jacks work, you need to check any exposed wiring for damage. After that you need to check the wiring inside the walls. Your telephone provider will fix this for a fee.
I hope this helps.
Oct 02, 2010 | Emerson EMSEM2646WH Phone
How to solve charging problem
Dear, Could you explain the problem like is there a charging error display on your screen or is this problem of your charging jack.
well i can help you, if there is charging errror display on your mobile screen so your charger or your battery must be corrupt or non-geniune.
OR if there is problem with your charging jack so it is very easy to fix this problem, you just need to buy a new jack it is very cheap. Then if you can change it yourself so it is better otherwise you just go to a cerified mobile phone repairer and let him chande your jack. Changing the jack is just like 1 2 3, you just pull the jack back after opening your phone and push the new jack.
Thanks
May 06, 2010 | Sony Ericsson P990i Cellular Phone
Speaker problem
you wont, it will sense off of the jack as to which output method to use. If the jack is bad and the device cannot communicate with it, it will remain in its current state.
Jun 14, 2009 | Palm Tungsten E2 Handheld
I would like to modify phone jack switch such that it does not cut out speakers when phone jack is inserted. How to open the unit so that I can get to the switch?
There's a good reason they designed it that way. If you get a feedback loop through the speakers to the mike and back you'll kill your tweeters.
May 04, 2009 | Audio Players & Recorders
No dial tone
Have you tried a known good phone in the jack, if that doesn't work take the phone to the demarc box provided by your phone company and open the door on the box. Under this door locate the mini jack and disconnect it, then plug your known good phone into that jack. If you get no dial tone at this point, then it isn't being provided by the local phone company so it's their trouble. Thank you. Jerry
Dec 18, 2007 | GE 26998GE1 Cordless Phone
SEH Computertechnik IC107-FAST-EPSON-TX (4037863030109) Print Server Logo
Top SEH Computertechnik Computers & Internet Experts
David Payne
David Payne
Are you a SEH Computertechnik Computer and Internet Expert? Answer questions, earn points and help others
