Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Finish on "stainless steel" door is deteriorating
Fridge was installed in April 2004, has not been abused, cleaned always with soft cloth and stainless steel cleaner supplied by Sears.   During the past year vertical streaks have appeared, as though a sharp knife has pierced the finish, there are some smudges also.  Cleaner would erase marks only to have them appear again in short time.  Problem is worsening, streaks are failing to disappear even for a short time, smudges are worse, very distressing for someone who takes pride in their home.   Refrigerator was sold as 'stainless steel', but is not, a magnet won't stick to it.  It must be plastic.   What can be done to correct this problem?   Replacing doors and handles are not an option.  Model # KSRA25KKSS12
  • KitchenAid Master
  • 5,568 Answers
There are many different alloys that are called 'stainless' steel but all of them have some chrome, some nickel and some steel. Depending on the strength of the magnet and the specific alloy, it may or may not adhere. Generally, the higher chrome and nickel content, the less magnetic it will be.
I think that the brushed surface of your fridge was coated with a kind of clear-coat to prevent fingerprints from adhereing to the brushed surface and that clear-coat is now missing in the areas of concern.
The only cure for tha would be the wholesale removal of the doors and the remaining clear finish and then respraying it with a quality clear finsh.
Ain't progress grand?
We considered all stainless stuff for our new home a couple of years ago, decided we liked black better and now hate that too.
Posted on Jan 08, 2009
I have the S201X how do I clean this oven/ micro combination. Does it have a self clean option?
From page 59 of the user manual:
Instructions for the user:
11. CLEANING AND MAINTENANCE
The oven must be periodically cleaned to maintain its working characteristics unaltered. Inadequate cleaning could jeopardise its appearance and above all its functioning.
Before performing any operations requiring access to powered parts, switch off the power supply to the appliance.
Do not use a steam jet for cleaning the inside of the oven.
11.1 Cleaning stainless steel
To keep stainless steel in good condition it should be cleaned regularly after use. Let it cool first.
11.2 Ordinary Daily Cleaning
To clean and preserve the stainless steel surfaces, always use only specific products that do not contain abrasives or chlorine-based acids.
How to use: pour the product on a damp cloth and wipe the surface, rinse thoroughly and dry with a soft cloth or deerskin.
11.3 Food stains or residues
Do not use metallic sponges or sharp scrapers: they will damage the surface.
Use normal non-abrasive products and a wooden or plastic tool if necessary. Rinse thoroughly and dry with a soft cloth or deerskin.
Do not allow residues of sugary foods (such as jam) to set inside the oven. If left to set for too long, they might damage the enamel lining of the oven.
11.4 Cleaning the oven
For best oven upkeep clean regularly after having allowed to cool.
Take out all removable parts.
-Clean the oven grill and side guides with hot water and non-abrasive detergent. Rinse and dry.
-For easier cleaning, the door can be removed:
11.5 Removing the door
11.5.1 removing doors with mobile hinges
Lift the levers B until they touch the hinges A and take hold of the two sides of the doors with both hand close to the hinges. Raise the door to an angle of about 45 degrees and remove it.
To reassemble, fit the hinges A into their grooves, then lower the door into place and release the levers B.
Oct 21, 2014 | Ovens
How do I clean the surface of my stainless steel refrigerator
Depends on what you're trying to clean off of the fridge. My husband uses carb cleaner to clean the inside of a dryer. Should work on the stainless steel as well. Spray it onto a microfiber cloth and try to clean it that way. I would also use some polish when finished. Hope this helps!!
Jun 14, 2012 | Samsung RB2155 Bottom Freezer Refrigerator
Rust spots appearing on the front doors of my Bosch refrigerator
Stainless steel does rust - or at least that is the theory.
There is in fact two types of stainless steel; the original categorised austenitic which is instantly recognised due to it being unable to attract a magnet due to the absence of iron. Austenitic is relatively expensive and difficult to work but adding iron in various quantities to the alloy produces a cheaper, lighter metal that looks good and is easier to work while still providing some resistance to corrosion. The more iron that is added to the ferritic type of stainless, the lighter, cheaper and easier it is to work but the corrosion resistance is substantially reduced.
Cars have been fitted with stainless steel exhaust systems of the ferritic type for many years and although they last a long time they soon show surface rust and sometimes will rust through.
I expect your fridge wipes are either acid or alkaline that are suitable only for austenitic and good grades of ferritic and Bosch have used a particularly poor grade of stainless. I expect fridge magnets stick very well...
Mild discolouration could be removed with a mild abrasive cleaner though that would tend to ruin the brushed finish. Clearly future cleaning should be carried out with a neutral ph cleaner and the surface protected with a hard wax polish.
I suggest you check the cleaning instructions in the Bosch instruction book. If you feel you have done nothing wrong you might be able to claim from your household insurer as accidental damage. It would be a good idea to inform the manufacturer of the cleaning wipes...
May 27, 2017 | Bosch B26FT70SNS
How to clean maytag stainless steel finish on appliances
HOW TO CLEAN MAYTAG STAINLESS STEEL REFRIGERATOR:
Do not use abrasive or harsh cleaners such as window sprays, scouring cleansers, flammable fluids, cleaning waxes, concentrated detergents, bleaches or cleansers containing petroleum products on plastic parts, interior and door liners, or gaskets. Do not use paper towels, scouring pads, or other harsh cleaning tools.
How do I clean and care my stainless steel surfaces such as refrigerator or any other stainless steel made appliance?
NOTE: Just because a cleaner is a liquid does not mean that it is nonabrasive. Many liquid cleaners designed to be gentle on tile and smooth surfaces still damage stainless steel.
> Avoid Citric acid
-it can discolors stainless steel. To avoid damage to the finish of your stainless steel appliance, do not allow these substances to remain on the steel finish:MUSTARD,TOMATO JUICE,MARINARA SAUCE,CITRUS-BASED SAUCES,CITRUS-BASED PRODUCTS.
If you want to clean safe and keep the sparkling steel you can purchase STAINLESS STEEL WIPES this wipes is ideal for cleaning food spills,grime and stains leaving surfaces shining like new. This wipes is for stainless parts only make it sure this stainless steel wipes to come into contact with any plastic parts.BUT THE SAFEST WAY TO CLEAN STAINLESS STEEL SURFACES IS TAP WATER WITH CLEAN WHITE CLOTH.
Jan 26, 2011 | Maytag Refrigerators
My houselady cleaned my fridge today with a stainless steel cleaner and now it looks like there is a blue residue on my fridge that will not come off. Is it ruined?
I am not exactly sure how to remedy your specific issue but I know of a site that sells decorative covers for your appliances. Check them out at www.applianceart.com These guys have covers for all occasions and even stainless steel. Hope this helps.
Sep 11, 2010 | GE Profile Arctica Stainless Steel Top...
What product to clean a franke sink
Stainless Steel use softscrub on Granite you can use soft scrub or vinegar
Oct 21, 2009 | Franke Home
Stainless steel cleaner damage to lacquered finish?
Most stainless products don't have a lacquer coating. That's why stainless is so nice. Go over it lightly with a soft scouring pad like scotch brite to remove the marks. Just follow the grain.
Sep 09, 2009 | AEG Refrigerators
Water marks on stainless profiles
I have used Bon Ami or Bar tenders Stainless steel cleaner (found in the section of Ajax or Comet Cleaner). Put some of the powder on soft cloth, wet it a little & scrub mark lightly; use clean rag w/water to clean off powder. Then use stainless steal spray cleaner (like the one found at Bath & Beyond) and rub in with soft cloth. I have found that the pull-out stainless steel cleaner wipes are too wet & just smear. Good luck
Dec 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
Stainless steel finish on Liebherr fridge
if you have scratched or damaged the surface, you can get a stainless steel foil product to cover your refrigerator from www.applianceart.com. If its not that bad, make sure you are using a stainless steel cleaner after you have washed it with a regular cleaner.
Jul 06, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
517 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
