Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F_i on the cabrio washing machine at the rinse cycle
The machine does this at the rinse cycle
    Problem Solver:
  • 5 Answers
F is a code then another number or letter should pop up too that is needed. It will say F then a number like 50 or 51.
Posted on Dec 21, 2008
  • 209 Answers
SOURCE: Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Posted on Oct 04, 2007
  • 726 Answers
SOURCE: Whirlpool Cabrio High Efficiency Top-Loading
hey there i had a search F then 1 flashes there is a primary control failure. Replace the machine control assembly my best bet would be to call a service center or repair guy to advise you further what to do or even fix it as this will be a ongoing stuff around for you and you dont need that
Posted on Sep 15, 2008
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
SOURCE: cabrio drains water onto floor.
I took the back cover off of the machine and found that the drain pump had a hole in it. The hole was caused by a coin that had made it's way down to the drain pump. The replacement pump cost $90.00 and was very easy to put in. If you google the words cabrio tear down you will come across a web site that has a video that shows you how to take the pump out. I have not had any leaks since. Keep the coins out of the washer, remeber to check your pockets to avoid paying out cash.
Posted on Jun 12, 2009
  • 41 Answers
SOURCE: washing machine leaks from underneath after rinse cycle
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
Posted on Jul 11, 2009
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Stops during wash cycle
my cabrio agi washer will stop constantly during the wash and rinse cycle and it will say F51 and dL
Sep 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio agi stops after wash cycle
you may need a new timer. yes have it looked at.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I get an F1 error code at the start of the wash & at rinse cycle.
Your Central Control Unit is most likely the problem. It is the main board in the machine behind the control panel and they have been failing a lot. This is a major problem with the Whirlpool Cabrio and the Kenmore Oasis machines. You will most likely need to call a service technician. People have also called whirlpool and complained and got them to pay for the part. I suggest you try battling with them. The part is faulty.
Nov 17, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
167 people viewed this question
Dan Webster
Dan Webster
Sal De
