Question about Sony KP-43T70 43" Rear Projection Television
Sony KP43T70 red/blue color separation.
I own a Sony Color Rear Video Projector Model number KP43T70 Manuf. November 1999. The red and blue are separated. Is there any way for me to fix this on my own?
  • guitarhero1 Jan 23, 2009
    I just got the TV from a friend, I helped her with some taxes, and some computer work, and cleaned out her garage...and i bring home the TV and the red is totally warped.
    How can we fix this??
  • Petert001 Jan 31, 2009
    My colors have separated on my Sony rear projection TV
5 Suggested Answers
  • 927 Answers
SOURCE: color separation blue and yellow images
Good Day;
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more. The part location : IC8C01&02; part number (gen) STK392-110. The parts are on center PC board. and the parts are located on the large silver heat sink.
I hope this information allows you to resolve this issue. If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Good Luck, Big Irish.
Posted on Nov 23, 2009
Slinteriors
  • 8617 Answers
SOURCE: philips model 60PP920217F
You need to replace both convergence ICs STK392-120 they are an easy repair you will also need (4) 6.8ohm Convergence resistors. You can get replacement ICs and the resistors at the following link and they will provide free installation instructions and free on line tech support so you will be able to do the repair yourself and save about 400.00 for a 45 minute repair. heres the link.
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
Slinteriors
  • 8617 Answers
SOURCE: It started separating the blue from the red so you see everything in double. and the color is not right
You need the panasonic convergence repair kit #1 which comes with instructions with pictures. Heres a link to the correct kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Posted on Apr 26, 2009
ArnelM
  • 153 Answers
SOURCE: Projector Alignment
You need to replace 2 convergence IC and picofuse :)
Posted on Dec 28, 2009
Testimonial: "Thanks!"
Ecollier2012
  • 3459 Answers
SOURCE: Sony Projector Color Display
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
I have a Sony Color Rear Video Projector Model KP-57HW40. Its blue color is not working anymore and noticed some burn smell by the set which controls such blue color.
It may be the CRT drive board which is attached to the bottom of the Blue CRT. I would check that Board for signs of being burnt it may need to be replaced.
Jul 08, 2011 | Sony KP-57HW40 57" Rear Projection...
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Apr 03, 2010 | Sony KP-57HW40 57" Rear Projection...
TV will not come on
i have a sony rear projection TV, model number kp43t70 screen went black and there was still volume but no pic so I turned it off and now won't turn back on
Aug 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53V25 Color Rear Video Projector Powering off unexpected
possible crt problem, they have to be reseated, if not then the convergence is failing expect to pay around $300-350
Jul 26, 2009 | Televison & Video
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony color rear video projector KP-43HT20
get the tv degaused that should fix the problem
Jul 23, 2008 | Sony KP-61V45 61" Rear Projection...
Sony KP-43T70 43" Rear Projection Television Logo
249 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
