Question about Sharp EL-2630P Calculator
HOW DO I SET THE TAX RATE ON MY SHARP EL-2630Piii CALCULATOR?
TAX RATE SET QUESTION, THANK YOU.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
Follow the instructions in the fourth column of the first page of this manual: http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL2630PIII.pdf
Posted on Jul 09, 2013
4 Suggested Answers
drknow
  • 44 Answers
SOURCE: set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Posted on Dec 19, 2007
  • 3 Answers
SOURCE: Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
Posted on Apr 10, 2009
SOURCE: NEED TO SET TAX RATE
Solution #1 has it backward..
(tax rate), STR, TAX+ (or TAX-)
Example- San Francisco sales tax = 9.5% you enter 9.5, STR, TAX+.
now it functions as (amount entered) plus tax. Example- find the total with tax for a purchase of $14.99 14.99, TAX+ Calculator will show 16.41
Posted on Apr 16, 2010
Sharp el-2630piii calculator setting to two decimal points
Slide the "F 6 3 2 1 0" switch to the "2" position.
Feb 28, 2013 | Sharp EL-2196BL Calculator
HOW DO SET TAX RATE ON SHARP ELSI MATE EL-2125
Easy. Press M- key [has RATE SET] above it. This will shown your current setting say 17.5. Amend to 20.0 and Press M- key again. Rate should now be set at 20%.
Test by entering:
100 and pressing +TAX key - Answer should be 20.
100 and pressing -TAX Key - Answer should be 83.33
Jan 04, 2011 | Sharp EL-330AB Calculator
Change date sharp el-2630PIII
"GT": Grand Total
"•": Neutral
" ": To set up date, time, conversion
rate, and tax/discount rate, place the
switch at the "RATE SET" position.
Date:
• Enter in the order of month, day
and year, then press to
complete the entry.
• Use to separate month, day,
and year.
• When is pressed, the number
entered is evaluated and displayed
as "date" if the value is within the
following range; "Error" is
displayed otherwise, and the
previously set date is restored.
Month: 1 - 12; day: 1 - 31; Year:
2000 - 2099 (in 4 digits) or 00 - 99
(in 2 digits)
Time:
• Enter in the order of hour, minutes,
then press to complete the
entry.
(There is no entry available for the
seconds value. The clock starts at
zero second.)
• If the hour/minute digit is less than
10, it is not necessary to enter the
first digit "0".
• Use to separate hour and
minute values.
as "time" if the value is within the
previously set time is restored.
Hour: 0 - 23 (24-hour system for
the hour entry), Minute: 0 - 59
Dec 19, 2010 | Sharp EL-2630P Calculator
Setting tax %
It is glorious!!!
Dec 18, 2008 | Sharp EL-1701C Calculator
TAX SET
Press +TAX
press the number you need to set it at
Press +TAX again then CA
worked for me!!
Hope this helps
Oct 21, 2008 | Sharp EL-1801P Calculator
Jun 05, 2008 | Sharp EL-2192Rll Calculator
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
May 01, 2008 | Sharp EL-330AB Calculator
It is glorious!!!
Jan 20, 2008 | Sharp EL-1701C Calculator
Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Nov 19, 2007 | Sharp EL-334AB Calculator
Sharp EL-2630P Calculator Logo
787 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
