Question about Panasonic PV-M1349 Combo
Quasar TV/VCR - how to UNDO autoset?
We have an old tv/vcr attached to a rooftop antenna, and our ability to receive channels comes and goes. Somehow channel 5 got eliminated, via the remote I think. In trying to get it back, using the remote, I went into the menu, to Channel, to Autoset... and when I was done, all we saw was our PBS channel. ONE channel. How do you UNDO autoset?
  • Panasonic Master
  • 2,750 Answers
I find that sometimes you have to turn the antenna a little to receive more channels. Do you have a good booster? I gained an extra twenty to thirty channels by installing a good booster to my antenna.
Posted on Sep 29, 2017
Kimi
  • 277 Answers
SOURCE: auto channel programming
The desgin of this unit is such that only the channel being recorded can be viewed. Try to manualy program channel 3 - p.25 in the user guide.. Good luck.
Posted on Jan 15, 2006
jomaru
  • 337 Answers
SOURCE: Can receive only channels 1 thru 27 although connected to cable with 70 channels.
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Posted on Sep 13, 2006
  • 93 Answers
SOURCE: cannot program cable to tv
if your are using a cable box,all of your channels will be control only on the cable box.so, what you are going to do is use the remote control of the cable box.
Posted on Nov 07, 2007
SOURCE: TV/VCR PV-M2023-R or PU-M2023-R 1995
if u stick ur bowo in it then it should do the job
Posted on Feb 25, 2008
SOURCE: panasonic omnivision tv/vcr combo
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Posted on Aug 22, 2009
I need a manual for a Quasar VV-1305 TV. I
I have a quasar model vv1305 t v -vcr combo. the vcr loads and ejects the tape, but when you try to play or rewind it prints on the screen vcr lock activated . need help
Apr 11, 2010 | Televison & Video
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Connecting Hitachi VCR to my Direct TV.
Connect your Direct TV to the Ant. In connection on your VCR. When you want to watch TV, just tune the TV to channel 3 (or whatever channel the Receiver is set for). When you wish to record, set your VCR to that same channel and set your TV to the channel that your VCR outputs to. For simplicity sake, I would suggest setting both systems to channel 3 and just watching your program through the VCR. If you are still using an "off air" antenna, then connect that antenna to the ANT. IN connection on your Direct TV receiver and when you turn off the dish, it will pass the signal through just like the VCR would.
Jan 28, 2009 | Hitachi VTF392A VCR
Connecting older model quasar to dvd/vcr player (magnavox)
Hi and welcome to FixYa,
Initially, the only reason you would need/use a modulator is when the DVD/VCR has no RF OUT and the Quasar TV has no Audio/Video IN. If this were the case, then connections would be:
  • yellow Video Out of DVD/VCD to yellow Video IN of modulator;
  • red/white Audio Out of DVD/VCR to red/white Audio In of modulator;
  • modulator RF Out to RF/ANT/CABLE IN of the Quasar;
  • TV has to be set to either Channel 3 or 4;
  • if Modulator has no RF OUT but instead has a small antenna, still the TV has to be set to either Channel 3 or 4.
If however, the DVD/VCR has an RF OUT, then a coaxial patch cord from this could be connected to the RF/ANT/CABLE IN of the Quasar. The TV has to be set to either Channel 3 or 4. There would be no need for the modulator.
Good luck and Thank you for using FixYa.
Jan 03, 2009 | Televison & Video
How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Jan 01, 2009 | Televison & Video
Playing vcr causes new digital tv to lose saved channels
Vizio representative suggested connecting antenna directly to TV and not through the VCR. In doing this, we lose the ability to record on the VCR but we record elsewhere and watch downstairs. The problem is solved on losing channels. I must add that we watch and record on a Sharp digital TV upstairs and do not lose channels. I don't know why the VCR had this effect on this Vizio TV.
Dec 01, 2008 | Vizio L37 Television
Quasar VHQ41M
I am not conversant with VCRs sold in the United states, but - a VCR is a VCR is a VCR. So, can i suggest an alternate solution to your problem? Why not use the AV out sockets of your VCR and hook them to the AV IN sockets of your TV? In this manner, you you also get a better image. And of course, you feed In the signal source (Antenna, cable Box, etc) directly to the TV, and use your remote to switch to AV mode whenever you desire to watch movies or Tape.
Aug 01, 2007 | Quasar VHQ401 VHS VCR
Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
May 24, 2007 | Quasar VV-2001 20 in. Combo
How to UNDO autoset (channel setter)?
If I am not mistaking this is the same set as the panasonic PV-c2020. I attached an owners manual link here this should help you. Good Luck. http://service.us.panasonic.com/OPERMANPDF/PVC2020.pdf
Mar 16, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
Panasonic PV-M1349 Combo Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
