Question about Epson Stylus Pro 10000CF InkJet Printer
00010006 error on epson 10000cf
Hi recently bought this printer and have had the capping station and heads replaced by epson but now the CR motor is playing up. I fix and maintain Xerox dc12,s for a living, Can I change this motor myself without running diagonistics engineering software?
there is a chance that the tab ont the carriage has pushed itself in when trying to load apaer, where do i locotate the tab they are talking about?
cheers
Simon (cardiff).
  • 43 Answers
SOURCE: Need to Reset Motor Counter
Good Morning:
Hope that you are wellJ
This link will help you to reset your ink pad counter.
Pleas read directions carefully before proceding.
http://www.ssclg.com/epsone.shtml
If I can be of further assistance, please let me know.
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful morning.
Posted on Sep 30, 2008
jacklee366
  • 541 Answers
SOURCE: Epson R320 "General Error" message - unable to clear
try downloading the ssc this will reset your printer
Posted on Mar 03, 2009
exil0r
  • 118 Answers
SOURCE: clear the Carriage Motor Counter epson stylus pro 4800
look for that here
Posted on Mar 26, 2009
  • 54 Answers
SOURCE: Service Call Error 0001001D
Hi poulin,
Click here to access your printer's manual
http://support.epson.ru/products/manuals/000909/spro798400rg_e.pdf
Page 327 on that manual will contain information on how to troubleshoot service errors. On page 115, it talks about adjusting parameters for better print quality.
Hope you may use the manual to troubleshoot your printing errors on your own.
Posted on Apr 09, 2009
SOURCE: Epson printer: print head not moving to replacement position
Click on Epson, then Monitor status then Properties then replacement. A page will come up saying To get carriage into position click O.K. on this page. When you do that the carriage moves into position and you can take out the old cartridges and replace them
Posted on May 23, 2009
Service call error 00010040
Common Error Codes
00000101 The CR Motor reached it's end of life. 00010000 PF Encoder Check Error. 00010005 CR Motor is out of step. 00010014 Pressurising failure. 00010027 Pressure pump micro air-leak error. 00010040 Printing position error. 0001002D The cleaning unit reached it's end of life. 0001003F The Pressure Motor reached it's end of life.
Servicing Levels
Three levels of servicing are available and detailed below:
  1. Basic 0040 or 0001002D maintenance procedure: This will return your printer from either the 0040 or 0001002D error to a working state by replacing only the relevant maintenance items.
  2. Advanced 0040 / 0001002D maintenance procedure: As well as replacing the parts relating to the maintenance error additional adjustments such as bidirectional/unidirectional alignment, 980mm feed adjustment, firmware updating and a general clean will be performed.
  3. Overhaul: All maintenance items as well as the PF, CR motor and belt, cutter cap, pressure assembly and cutter solenoid will be replaced. A check for any design defects such as a defective cutter cap and a defective pressure lever will be performed and any parts will be replaced if necessary. All head and feed alignments will be performed as well as any required software updates and sensor verifications. A thorough clean will also be performed on the carriage area and the print head. When the procedures are complete a survey will be performed to better understand your requirements and any recommendations will be brought forward.
info.gifIt is recommended that if you have recently come into ownership of a second user Epson Stylus Pro 9800 then you should assume that the counter values or service life levels are incorrect and choose the most thorough procedure detailed above. The reason for this is an increasing number of printers being "reset" without the actual parts being replaced or inexperienced owners trying to repair or replace parts incorrectly. In one such case a part was removed and replaced incorrectly causing a serious ink leak which was luckily caught early due to the undertaking of an thorough maintenance procedure, but unfortunately extensive damage had already been caused to the chassis and maintenance tank area.
I copied the error code and put it in the search bar in a web browser and came up with the answer. In the future just google the codes and see what comes up. Also you can download a Field Repair Guide PDF and a Manual PDF from Epson's website too.
Jan 25, 2013 | Epson Stylus Pro 9800 InkJet Printer
Tip
Epson Stylus Pro 3880
ERROR CODES CAUSES AND SOLUTION
1101
CR life error The CR scan path counter has reached a predetermined level.
(The end of life of the Ink Supply Tube)
Replace the Ink Supply Tube (INK, SYSTEM, ASSY) and reset the counter using the Adjustment Program. In addition, check the statuses of the CR motor (MOTOR ASSY.,
CR), the driven pulley, the Carriage Unit, and the Head FFC, if any abnormal noise or wear is found, replace the corresponding part(s) along with the Ink Supply Tube.1120
CR lock error The CR encoder failed to read the CR scale during a predetermined time period. Replace the CR encoder (BOARD ASSY., ENCODER, CR).
Replace the CR scale (SCALE, CR).The carriage unit does not operate due to a CR motor failure or some reasons. Move the carriage unit manually to check if it moves smoothly, and fix any abnormality.
Replace the CR motor (MOTOR ASSY., CR).1121
CR reverse error An abnormal operation (reveres movement) of the carriage was detected a predetermined number of times. Check the CR scale (SCALE, CR) for incorrect attachment, scratch, dirt, and fix any abnormality. Replace the CR scale (SCALE, CR).Replace the CR encoder (BOARD ASSY., ENCODER, CR).
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Feb 23, 2016 | Epson Stylus Pro 3880 InkJet Plotter...
Epson Stylus Pro 10000CF As soon as we start printing, the head travels then returns to its starting point, stops printing and displays :"out of paper" ???? Thanks in advance for any help.
Take a look at the service manual, I think you'll find a solution there..
http://www.file-upload.net/download-6754855/Epson_Stylus_pro_10000-10000CF.pdf.html
Mar 31, 2011 | Epson Stylus Pro 10000CF InkJet Printer
Is possible printing with eco solvent inks on epson stilys pro 10000cf, Thanks, Dragan
The 10000cf only takes Dye or Pigment type ink cartridges. Eco-solvent ink is a newer technology that is not compatible with this printer.
http://www.epson.com/cgi-bin/Store/jsp/Pro/InksAll.do?BV_UseBVCookie=yes
Mar 02, 2011 | Office Equipment & Supplies
What does error code 1000060 for the epson 7880 mean?
1. Measure the resistance value of the CR Motor. (5.8Ω)
If the CR Motor is found in short mode, replace the C472MAIN Board at the same time.
2. By visual inspection, check the T Fence for any defect, such as damage or soiling, which can cause faulty reading by the sensor.
3. By visual inspection, check the harness of the CR Motor for any problem causing a short circuit to the frame.
Dec 22, 2009 | Epson Stylus Pro 7880 InkJet Printer
Having reconnected recently the printer is operating normally except that nothing is appearing on the printed page
Please check for the capping station after powering on do you find any ink in the cap station if no ink found in cap station its p head nozzles may by blocked and try to clean from printer panel switch
May try to put some water in cap station and check water should be there until its try cleaning option and after force cleaning it will drain out if it’s happen properly its most chances are for p head nozzles may be block
P head need to be replaced for same
Nov 08, 2009 | Epson Stylus 680 InkJet Color Printer
Hello i have a service light on saying print head tempreture,would i need a new print head ,please help thanks
hi,
this service message just warns you that the print head temperature is not normal. just give it some time to get to room temperature and then continue printing. if the problem persists, try troubleshooting the printer or test print to check the condition of the printer.
cheers
Jul 26, 2009 | Epson Stylus Pro 10000CF InkJet Printer
Red warning lights remain on.....
Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
Jun 16, 2009 | Epson Stylus Photo R200 InkJet Printer
R 1800
where can i get a print head for my epson R1800 printer?
Mar 04, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Pro 10000CF InkJet Printer Logo
153 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
