Question about Zenith C27V36 27" TV
TV changes channel changed before all numbers entered in remote
My tv is changing channels before I have entered all the numbers into the remote. For example, if I want to go to channel 13, after I enter 1, the tv changes to channel 1 before I can enter the 3.
    Novelist:
    Champion:
  • 236 Answers
Possibly you're not putting the numbers in fast enough. If you are then there maybe a problem with the microprocessor responding too quickly to commands. I've never seen this problem before, but my TV will do the same thing if I don't get the numbers in fast enough. Stargazer
Posted on Mar 10, 2007
SOURCE:
We have an TRI remote and a pioneer tv. The remote will turn on tv and change volume but not change channels
You gave the wrong code for the tv entered for the remote, or the remote is set to change the channels on the stb-(set top box) instead of the tv.
Jul 02, 2017 | Pioneer Televison & Video
Same problem as above.Disney p1310ATV lost the remote. No Phone # in orginial manual.Television system NTSC (American TV Standard) I have tried other universal remotes also I have a Sony RM-V210 universal...
there may be a problem with the tvs remote sensor. most universal remotes you dont even have to enter any codes you just have to follow the same steps to enter the code but instead of entering a code all you have to do is press the channel up button after following all other steps, just keep pressing up until it turns the channel on the tv then press enter or similar button after it changes the channel and this should lock in the code without entering a specific code.And if all other remotes only half the buttons work on if it happens with every universal remotes then it probably a problem with the remote sensor or the tv . Good luck too ya!!!
Jan 02, 2011 | Disney 13" TV
Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
May 05, 2010 | Sharp 27C-240 27" TV
Channel buttons change input
Auto channel search is your friend. Once the tv has been through it and finds active channels, your channel button should work the way you envision.
Jul 06, 2017 | Toshiba 15LV505 LCD TV
I can't change the channels on the tv with remote or on tv controls. The channel up button on the tv only goes to channel 1 or aux. I need channel 73 to use satellite service. We have changed batteries in...
You will need to rescan for channals, or manually enter the number. Make sure your sat. box is on when you do this. Rescan can be found in your tv.s menu.
Jul 03, 2009 | Emerson EWF2704 TV
Akai LCT2662N Channel Changing Problem
there is a button that controls how many digits you can enter. it is located betwwn the 0 and source or below the 8 buttons
Sep 02, 2008 | Akai LCT2662 Television
Durabrand 13 inch tv
the remote need to clean pcb board ..... the chroma section pcb need to resolder loose parts such as resistor, capacitor or transistor that you may see on it.....
Feb 27, 2008 | Durabrand DWT1905 TV
Possibly you're not hitting the numbers fast enough or there is a problem in the delay circuit in the microprocessor. Stargazer
Mar 02, 2007 | Zenith H32G48S TV
Tv will not change channels
Sounds like an eeprom problem or a microprocessor problem??? Also make sure the tv didnt lose its channel memory by reprogramming the channels feature in the menu. Good Luck
Jun 23, 2006 | Sylvania 6427TE 27" TV
Zenith C27V36 27" TV Logo
112 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
